Dump trailer doesn't have enough power
/ Dump trailer doesn't have enough power #1
retNAVY
Kubota BX23
I have a dump trailer with a dumping capacity of 3000 lbs, the trailer is 3 yrs old,can I increase the dumping (weight)capacity of this trailer? It has a single cylinder,not a scizzor lift.
I have had a few times where it doesn't seem it by looking at the load but the pump/cylinder won't lift.
The trailer is very well built,I can post the manufacturer if needed, the trailer is a 6x10 deckover,double axle.
/ Dump trailer doesn't have enough power #2
Dump trailer aren’t known for their strong dumping ability. Is it stalling the pump or hitting the relieve pressure?
/ Dump trailer doesn't have enough power #3
Do you know what pressure the system is supposed to operate at? Have you checked to confirm that it is operating at that pressure.
to increase lift capacity you have to either increase system operating pressure if your existing components allow increased pressure or install a larger diameter cylinder. You would have to determine if your existing pump reservoir assembly has the fluid volume for a larger cylinder.
example: a 2” diameter bore cylinder has 3.14 square inch area times 1000 PSI = 3,140 lbs of lift.
A 1 3/4” bore has 2.4 square inch area times 1,000 PSI = 2,400 lbs of lift
/ Dump trailer doesn't have enough power #4
^ and you'll have to be sure the larger cylinder will clear the frame. And of course, that the frame will stand up to the increase in forces.
Before you start changing things, check that your current system is operating up to spec.
/ Dump trailer doesn't have enough power #5
I’m betting the pressure is low. Boosting pressure would be far easier then trying to fit a bigger cylinder in.
/ Dump trailer doesn't have enough power #6
Mine is 14k lbs big tex. Pretty good trailer over all.
I can lift 6.5 ton if it isn't too far forward and that is it. Another 100 pounds and you are off loading with the x. I think it is by design. If it had the power to lift all the wet clay it would hold, it would break other stuff, possibly catastrophically.
They are slow and weak, but beat a shovel by a looooong ways.
Best,
ed
/ Dump trailer doesn't have enough power #7
Best,
ed
It’s more the limits of the 12 volt setup. Dump trucks will dump anything no matter how overloaded and they don’t go around breaking.
/ Dump trailer doesn't have enough power #8
It’s more the limits of the 12 volt setup. Dump truck will dump anything no matter how overloaded and they don’t go around breaking.
From 10 years working on hay wagons, and watching my dump with an overload, I whole heartedly disagree that they will dump anything you can get on them.
I do agree the system they have is designed to lift up to spec and not an ounce more.
Best,
ed
/ Dump trailer doesn't have enough power #9
Best,
ed
I said dump trucks not dump trailers. I’ve seen some ridiculous overloaded dump trucks and I’ve never seen one that wouldn’t dump. Dump trailers on the other hand are doing good to even dump the rated load.
/ Dump trailer doesn't have enough power #10
We are a bunch of mean motor scooters and bad go-getters here at TBN but without laying eyes and hands on,you are asking us for the impossible. If we could all get around it with torches,welders and your pocketbook we would having you up and going in no time. You need to make certain (or hire someone to) everything is working to capacity before re-inventing it.
/ Dump trailer doesn't have enough power #11
If it is power up and down check to ensure the pump is hooked up correctly to the cylinder. Mine was delivered to me with the down cycle hooked up to the up side of the piston which meant it would lift a load, but not what it should have. It took several trips back to the dealer before they figured it out.
/ Dump trailer doesn't have enough power #12
Ah, agreed, sorry.
Best,
ed
/ Dump trailer doesn't have enough power #13
The unit has been designed for 3,000#. Frame, floor, axles, Tongue, brakes and hoist assembly.
Make a couple extra trips or buy a larger capacity trailer. Short answer.
/ Dump trailer doesn't have enough power #14
A lot of good answers here on the hydraulic issues.
I will discuss the structure:
Some manufacturers over-engineer so they can sell an upgrade without redesigning the frame.
Very few do this anymore. They need to keep steel costs down.
They would rather you break a trailer and buy a new one.
If you watch the auctions you'll find a lot of broken trailers.
My first recommendation after checking your hydraulics out would be to call the manufacturer and ask. You may or may not get a satisfactory answer.
2nd recommendation would be to let an engineer or good fabricator look at it. You say it is well-built but I can tell you as an inspector, I see things in a different light.
You can also sell the trailer and buy a heavier duty trailer. Might be cheaper than modifying this one. Some trailer sales will sell for you on consignment.
Thank you for your input, a bit of personal background , I used to weld on nuclear subs, I have made and sold more than a few trailers(not dump trailers), I don't have any experience when it comes to hydraulics.
/ Dump trailer doesn't have enough power #16
My dad and I both have dump trailers. Mine is considerably heavier duty than his. Mine is slow going up and labors the pump hard going up with a heavy load. I put duel batteries in which helps. I still suspect the pump would stall before the relief was hit. My dads trailer goes up way faster than mine. We overloaded it once and the pump immediately bypassed to relive with practically no lugging the pump. Based on that experience I don’t think all electric pumps are created equal or have equal flow rates or pressure ratings.
/ Dump trailer doesn't have enough power #17
The biggest downfall of a single cylinder set up is the low angle at start up. I have often thought about installing one or two short cylinders vertically at the front of the trailer to get the initial lift into motion. I have built two dump trailers and two dump bodies on F350's, all dump fine but the first dump trailer was 5'-8" x 10' with a single 4" cylinder, it would struggle for the first foot or so with a generous load of firewood or gravel. The second one I built I used a 5" cylinder, much better but it was also a 6'-6" x 12' trailer. Both of the Fords got 68" x 9' dumps, the first one had a large (guessing 6" bore) and never struggled, this one I have now I used a 4" cylinder, I suspect it will behave just like the first trailer I built (I haven't tested it with anything heavy yet)
Some good advice about taking more trips with smaller loads, you have to respect it for what it is. Turning up the pressure or upsizing the cylinder will just transfer the weak link to somewhere else.
/ Dump trailer doesn't have enough power #18
A 6x10 bed, with 6 inches of gravel, is likely over 3000 lbs. 6x10x.5 = 30 cubic feet.
"A cubic foot of dry gravel weighs about 105 pounds whereas wet gravel weighs about 125 pounds."
Most dump trailer failures I've seen were way overloaded trailers.
Bruce
/ Dump trailer doesn't have enough power #19
I've thought about the same thing, that first foot of lift puts huge stresses on the frame and cylinder mounts, and I can hear the pump labor. I think there would be enough vertical room on a deck over trailer to get a vertical or nearly vertical cylinder in there.
/ Dump trailer doesn't have enough power #20
A friend mounted a 4X4 on the front frame to give it a "head start" on the lift. I think it rattles loads to the back on long trips, but, it does make it easier to lift.
Best,
ed
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2016 BOBCAT T740 SKID STEER (A62129)
2016 BOBCAT T740...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
2020 CATERPILLAR 289D3 SKID STEER (A62129)
2020 CATERPILLAR...
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A60736)
2014 ORTEQ ENERGY...
2019 CM TRAILER CARGO TRAILER (A60736)
2019 CM TRAILER...
