2515H Grease Zerks
/ 2515H Grease Zerks #1
Sooner79
Far North Texas
Branson 2515H
Does anyone know the exact number of zerks on a 2515H, excluding the rotary cutter? I feel like I may be missing one or two when I grease.
@Asteral I bought my tractor from your dealership (Big Tex Tractor in Caddo Mills) last year and my salesman told me how many and where they all were during my pre-delivery visit but I was on information overload by the time we got to the grease fittings. Can you help? I’m sure others here would appreciate the info.
/ 2515H Grease Zerks #2
If you have the manual, there is usually a diagram in them showing all of the zerk locations.
/ 2515H Grease Zerks #3
there is 10 on the tractor, and 14-16 on the front end loaders
2 on the tie rod ends, , 2 on the front axle supports, 5 on the linkages that pivot the shift levers( you can find them only from underneath the tractor looking up into the undercarriage)) one at the rear for the 3 point shift lever( this one may or may nor be present some models will have a slightly different setup), and one additional one for the adjustable linkage
16 on the front end loader all of these are visible none of them are hidden
hope this helps
6 Band Wood Barrel (A64557)
6 Band Wood Barrel...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
2006 Ford F-250 Knapheide Service Truck with Liftgate (A64556)
2006 Ford F-250...
ELECTRIC POWER WASHER (A64278)
ELECTRIC POWER...
2009 Volkswagon Jetta Sedan (A64557)
2009 Volkswagon...
40ft High Cube Shipping Container (A64553)
40ft High Cube...
