TC45D transmission issues
/ TC45D transmission issues #1
NM tractor
New Halland TC45D
Tractor has a hydrostatic transmission, it is stuck in reverse. The pedal for reverse will not move and the forward pedal will go the the floor without any resistance.
The PTO and 3ph work fine. When I start the Tractor a put it in high or low range it starts going in reverse, the only way to stop then is to turn off the key, I can't pull it out of range.
/ TC45D transmission issues #2
That kind of looks like a linkage came loose, probable related to the forward pedal, and jammed the reverse pedal down. Either that or a stick is jammed there somehow.
Have crawled underneath and check for any obvious broken or loose parts?
Got it in the barn this morning, don't see anything broken but haven't pulled anything apart yet. Cleaned the pump filter and changed the larger hydrologic filter. Did notice that the fluid was not clear, a bit milky.
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
500 BBL FRAC TANK...
