what brand
/ what brand #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
what brand welding rods do you use and why ?
I mostly burn 6011 here at the farm because most things are rusty,painted,or dirty.
I have found no difference in any of the brands Forney, hobart, Lincoln, etc,. So I usually just buy what's on sale at the time
I just picked up a 10# box of forney 5/32 6011 from HD for $27.00
I think the last rods I bought were Hobart
/ what brand #2
Also use 6011 on old iron clean iron 7018,I do like Hobart rods.
/ what brand #3
Usually buy what’s on sale these days.
Have to cut corners to compensate for tripling of fuel.
/ what brand #4
I use 7018, 7014 for old steel, 6011 Hobart and Lincoln mostly. Had a bad experience using HF flux core wire in my old Lincoln weldpak 100 amp, wire kept breaking and tangling up. I'll gladly pay the extra few bucks for the name and consistent quality. only welds that have ever failed me were flux core using a lower amp machine btw.
/ what brand #5
.. Had a bad experience using HF flux core wire ...
There was a batch of HF's 90A-AC 'mig' flux welders that came with flux wire so bad that a large number of those welders soon were listed on Ebay by a liquidator. 'Open box, as-new'.
I wasn't the only customer to return one. I couldn't get it to do anything but spit. Later, discussion on Welding Web identified the problem across that batch was just bad wire, so I bought the same model a year later. It worked ok.
/ what brand #6
Interesting, For me any way it had nothing to do with my Lincoln welder it was the cheap HF wire I was using as soon as I switched back to Lincoln innershield it worked perfect again.
/ what brand #8
And all those posts are from the one bad batch a decade ago... I've been running HFT flux core wire for a long time, the cheezy flux core welder (at least mine) doesn't care what wire you feed it as long as it's .035", it will NOT run .030", too hot even on low. The Titanium welder will weld with whatever it seems...
With 6011 I doubt you'll see much difference unless you get down to the 1/16" rods on a cheap welder... I have one of the old HFT stick welders that barely works and it was a pain with anything, I should try that thing again once it gets a little more unburied... but running a nicer wire feed or a stick welder on D/C is hard to beat so I don't run the others much...
/ what brand
I have tried several different brands with this everlast welder /tig combo unit. it's difficult to keep the rod lit no matter the brand rod. Holding a real close arc does pretty good, but it's not the best when trying to weld.
I can burn anything with my old tombstone welder
/ what brand #10
I have this Everlast unit
It runs every kind of stick I throw at it, BETTER than my old Solar 250 ac/dc copper wound stick welder. I typically set it for about 20% hot start and 15-20% "Arc force" (aka "dig") - no problems at all running 20 yr old 6011, 6013, 7014, 7018 (dry but NOT stored in a rod oven)
About half of these welds were done with the Everlast using mostly 7014, other half with the MM252/lincoln L56 .035 wire - I needed 6 different height pylons to level a pair of containers til I finally get enough $$$ to get a 48x60 slab done... Steve
/ what brand
I have the 210 machine. It doesn't come close to my old tombstone lincoln copper wound transformer machine. I set mine on the highest hot start and highest arc force it has.
It does ok, but when I need to get the job done, I use my 60 yr old tombstone
/ what brand #12
I don't do much with 6011. But I've done a bunch with harbor fright's 6013 and 7018, and also forney's 7014, it's all been fine.
/ what brand #13
Interesting that you experienced that. I bought some HF 6011 rod and it was the worst I’ve ever used. I thought I’d forgotten how to weld until I found some older Hobart sticks and they worked fine. Welding rod is really the only completely horrible HF product that I’ve bought. But full disclosure, that was 10 years ago. The newer HF products might be ok.
/ what brand #14
I have one of those old tombstone models also. Always does the job. Are they still sold?
/ what brand #15
Everything that I know about welding, I just learned from this thread. :)
I have done a little bit of soldering over the years however, for my model railroad
