deezler
Elite Member
- Joined
- Jan 30, 2012
- Messages
- 3,888
- Location
- Southeast MI
- Tractor
- Cub Cadet 7305, Kioti CK3510seh TLB
You're saying your XR4046 regens every 4 hours? For 32 minutes each time? That's horrible.
Hello Capt99. Welcome to TBN. Do I understand that post correctly - REgen with LS at every 4 hours is advertised by them and really is considered normal? For a couple years I have found it hard to understand why there is so much controversy relating to Teir 4. But it that is true, now I understand why. I think my tractor runs about 30-35 hours or more between regen. I thought that was normal.Yes that’s what is advertised and I talked to an engineer Regen doesn’t affect use I keep track of hours with grease maker so I don’t have to leave it running when jobs done
I have one injector that I strongly believe leaks a little bit while the engine is warming up as I have a slight misfire during warm-up and then when the engine does warm up to a proper operating temperature, everything seemingly works just fine. The tier IV spec is to have thermostats open at 160°F, which in any place that is cool or cold, puts the ECU into a warm-up, fuel-enrichment map. Compounding the issue, a lukewarm engine may not be able to burn all the fuel that is injected, spewing out what doesn't burn right into the lousy DPF and plugging it up far faster than designed. For this reason, the field-fix among fleet operators having overly frequent regeneration cycles is to install a warmer thermostat thereby getting the engine up to a proper operating temperature and off of the enriched warm-up fuel map.Though we never found out from the OP, the true cause of his short Regen cycles on his LS; I still favor a bad injector, that is providing far more fuel than normal as the probable cause. That also would account for the "strong diesel odor" from his exhaust.
Some of the older LS tractors have the Shibaura engine. The owners manual says normal regen cycle occurs about every 5 hours (+ or -). Newer LS tractors have an LS engine and normally does a regen about every 50 hours.Hello Capt99. Welcome to TBN. Do I understand that post correctly - REgen with LS at every 4 hours is advertised by them and really is considered normal? For a couple years I have found it hard to understand why there is so much controversy relating to Teir 4. But it that is true, now I understand why. I think my tractor runs about 30-35 hours or more between regen. I thought that was normal.
I must have misunderstood what was being referred to.
Again, welcome to the board.
Try blowing out radiator min regen is 4 hrs on non LS motor ie 2015-2018 models Mine was 2 things Very dusty radiator core and a small stainless steel seal on injector tough part to get but my dealer found a great substitute at hardware store and for 5$ replaced it blew out dust cleaned air filter, another big culprit for a very low price vice a 2300$ injector Part of regen problem is air flow sensors detect low flow which is interpreted as carbon build up thus requiring regen Things to try clean radiator, air filter and always run motor at at least 2000 + rpm these motors are designed to run hot and higher rpm Down side is fuel consumption but hey! Anything for the green environmental folks
Added note, my dealer has me blowing dust from engine area before every job Has worked great for me ReGeN is right at 4 hrs cycle with a regen of 32 min I have a 2015 XR4046
I bought my Kioti CK3510 with 103 hours on it. I have 165 now and I have never detected it regen once. I am a mech engineer who dyno tests engines daily, so I'm what you might call hyper sensitive to engine noises and modes. So either mine is doing all passive regens (likely, I keep RPMs up and occasionally work it hard) or I have a problem brewing, lol.
New FPT engine: Tier 4 Final compliant; higher torque riseLS SAYS A REGEN EVERY 2 HOURS IS NORMAL
Here's my regen history, the best I have record of it. I'm sure I missed a few early on before I recognized there was a real problem and started keeping track. I have been having excessive regens almost since the tractor was purchased.
Dealership has been great at getting the tractor in for service and trying a few things, but unfortunately the problem has not been resolved. They called me yesterday after hearing back from LS and informed me that LS’ stance is that regeneration every 2 hours is normal. If regeneration is occurring more frequently than 2 hours apart, there could be an issue.
I find that unacceptable. I use the tractor at home, it is not a business machine, but based on an 8 hour work day, what should be a normal regen cycle of around 50 hours, would give me 6+ days between regens, and LS is telling me that 4 times per day is normal!
First some qualifying information.
- Tractor is run consistently between 1800 and 2400 RPM
- Always used on road diesel filled from high turnover stations in 5 gallon cans, I fill 2 or 3 cans, 10-15 gallons at a time, so there has been a lot of fuel turnover, not the same, or old fuel being used. Tried with and without fuel additive (Power Kleen or Howes) no change. At one point LS blamed fuel quality, but refused to test the fuel in the tank to prove it.
- DPF switch left in regeneration mode, I have never inhibited regeneration.
Occasionally before a regen, the DPF regeneration indicator will blink on/off at 1 sec intervals indicating a >120% soot load, then soon after it will go through a normal regen cycle without me needing to initiate it via the DPF switch. I have not kept a detailed record of when the indicator flashes before a regen, but I have noticed it several times (and I’m sure I missed it blinking a few times too.) Normally it seems to go right into regen mode (solid light) indicating 100% soot load, not >120%, but not always.
I’ve also had a few regens complete and then within 5 minutes the tractor goes into limp mode which a restart clears. That has happened maybe 3 times or so. I don’t recall what was displayed on the instrument panel other than the red ! (Vehicle control error warning indicator.)
Another thing I have noticed more recently, this may be indicative or not; I have noticed a much more pronounced diesel odor in the exhaust than in the past. While nothing like my previous non tier IV motor which was sooty, the MT240 used to burn extremely clean with no noticeable exhaust odor, now there is a diesel exhaust smell, not horrible, but definitely noticeable. Maybe now because it has 300 hours that is to be expected. There is no visible soot or black smoke, just a diesel odor that was not there previously. I may also hear injector or valve chatter that is louder then before as well.
Additionally there were a couple regens run at the dealership during troubleshooting and maintenance which I don't have listed below.
Regen time on hour meter, all regens completed successfully after ~15 minutes:
4 (ran by dealer due to error code, day after I brought it home)
101
106
112
115 (Dealership replaced DPF Sensor, removed and cleaned DPF)
118
119
148
165
175
187
191
197
213
224
234
250
254 (Dealership replaced ECU and DPF sensor. Invoice notes “REGEN OCCURRING TO OFTEN WITH NO SOOT LOAD”)
259 (In Dealership for service, ran diagnostic, nothing significant noted)
262
269
276
300
307
I'm looking for advice on how to move forward. First I need to be able to get the dealer to move forward since LS who is paying for the warranty work says this is NORMAL OPERATION.
Next I see 2 different paths.
Comments?
- DPF System has a fault
- DPF system working normally, tractor producing too much soot
