3 point has no down pressure
/ 3 point has no down pressure #1
Coloradokid
JD 4710
My JD 4710 has no downward pressure on the 3 point lift arms, with or without an implement attached. However, they do lower overnight with an implement attached. Any suggestions?
/ 3 point has no down pressure #2
Turn the rate knob
Thanks. I'll try that.
/ 3 point has no down pressure #5
Been on a lot of tractors in my time. NONE have had down pressure on the 3 point hitch arms. They could lift only.
/ 3 point has no down pressure #6
Believe it or not but Belarus had down pressure. At least on the ones I saw.
/ 3 point has no down pressure #7
@Coloradokid , As mentioned several times, the 3PH on your tractor does not have "down pressure", but can you describe your issue differently in case we are not under standing?
/ 3 point has no down pressure #8
There is a 3Ph down pressure kit available for 4R series tractors. It might be backwards compatible to the 4720s?
2025 D39 Hydraulic Trencher Mini Skid Steer Attachment (A61567)
2025 D39 Hydraulic...
UNUSED KJ 25'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 25'X12'...
New/Unused 2 Post Car Lift (A61165)
New/Unused 2 Post...
2003 Ford Ranger Pickup Truck (A61568)
2003 Ford Ranger...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
2025 Pabreak 74in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 74in...
