Advice, rain down exhaust
/ Advice, rain down exhaust #1
NorthCountryJimmy
Deere 950
I have a deere 950 with a 3 cyl. yanmar diesel. A big storm blew through and caught the tractor outside with the pipe off the exhaust. Not sure how much rain got into the exhaust but a ball jar resting on a log nearby had about 3" of water in it. What should I do?
/ Advice, rain down exhaust #3
Pull the injectors, pour a little oil in each cylinder, crank for a minute. Reinstall injectors proceed as normal, if you have trouble starting, follow the purge procedure in your manual.
Above is what I would do. What you don't want is a cylinder full of water to hydro lock and bend a rod. I think you could accomplish the same by letting it sit for a few days for the water to drain into the pan.
I have had them caught in the rain, and never got any noticeable water out, and didn't get a lot in the oil, don't know why.
Best,
ed
/ Advice, rain down exhaust #4
Turn the engine over by hand. If you can do several revolutions, then try to start it. Other possibility is there's a drain hole in the muffler. Waiting might allow rust to seize the engine. If it starts, run it till the muffler is hot to dry it.
/ Advice, rain down exhaust #5
That's what I would do. Have done..
/ Advice, rain down exhaust #6
Not bad guidance, it won't seize in a few days, I promise.
ed
/ Advice, rain down exhaust #7
Whatever you do,don't roll engine with starter until injectors are removed. Don't take shortcuts or try lazy man approach in hoping water drain's into crankcase or dry's. Remove injectors as soon as you can get to it then use starter to blow water from cylinders. After injectors are reinstalled, if it doesn't start you might have to purge injector lines.
/ Advice, rain down exhaust #8
aaaaaaw, start it up to clear it out...
SR
Yes, it's not his tractor and it might be ok.
I don't see how 3" of rain down the muffler hole can get much water past the exhaust valves.
/edit - but then it's not my tractor either
/ Advice, rain down exhaust #9
Good advice, I am just curious, did you read post #3?
/ Advice, rain down exhaust #10
I read all replies but I don't believe you are curious to know if I read #3. What i think you are actually curious about is why I posted almost the same advice so here's the answer. Bad advice is and might again be posted so the best I can do is repeat what i believe is best for op. Satisfy your curiosity?
/ Advice, rain down exhaust #11
You answered the question, so yea satisfied, good work, we can out vote the bad guys:)
/ Advice, rain down exhaust #12
It's hard to give advice without knowing a bit more. Some Yanmars had a symmetrical 4 bolt mounting for the muffler to manifold connection so that the muffler could be mounted upright or horizontally. We had two and both were that way. You say that the pipe was off the exhaust, but don't say which way the muffler itself is mounted. If it is horizontal I doubt there is a problem.
Even if the muffler is vertical, some had a pinhole drain in the bottom. Our smaller Yanmar does. If yours does, check it. Maybe rain water in the muffler just drains through.
It might also be worthwhile to just have a look at the way the exhaust manifold is made. I don't know how your exhaust manifold is configured relative to the exhaust ports, but you can figure out the worst case by looking at the casting from the outside. That Yanmar engine has overhead valves. On our present tractor the exhaust gases go horizontally and then down in the manifold before connecting to the muffler. It would take a whole lot of water to fill that system up enough to wet the engine.
What I am saying is that without some more information all we can do is guess at how yours is built. And that not knowing how your particular tractor is built just leads to confusion about what to do. Posting some photos might help, too.
But regardless of what you decide, I'd turn it over by hand first. As said, that's what I do.
rScotty
/ Advice, rain down exhaust #13
You have two weeks before it sticks. Seen a guy hit the starter while I was saying no no no, bent rod at that moment. By hand is the only way.
The muffler is vertical, makes a 90* sweep to horiz. into manifold which is on the side of the engine, not top. No goosneck or pinhole in the muffler casting I can see. There is an extension on the muffler with a little rain stopping bend at top. I had that off for getting under some low clearance area when the tractor had a ground issue and stopped turning over. I broke for lunch before getting to cleaning contacts and that is when the storm blew in.
/ Advice, rain down exhaust #15
Just pull the compression relief and bump it over. If there is no resistance,then crank it .
OK, Where do I find the compression relief?
/ Advice, rain down exhaust #17
If it has it,it's under the left of dash,the later models don't have compression relief.
/ Advice, rain down exhaust #18
It's just fine, I had one sit out in the weather for months, it started right up and was fine.
He will probably need a therapist by the time all the "doomsayers" and "experts" get done with him in here!!
SR
/ Advice, rain down exhaust #19
I have two tractors with exhaust pipes that go straight up from the hood. When I bought them used, they had spent their life with the pipes open to the elements. It never occurred to me that there was any risk or danger of starting them up after it rained. Eventually, the mufflers rusted out, which was expensive, so now I put a coffee can over them when I'm not using them. If I forget to put the coffee can over it, and I'm surprised by a heavy down pour, I just start it up like normal and get to work.
I'm at a loss as to what the issue is?
/ Advice, rain down exhaust #20
I've seen lots of tractors sitting outside at dealer lots with vertical exhausts. Never seen one there with a coffee can on top of it. While I agree that it is good practice not to allow water in as best you can, surely tractors are manufactured to be outside in the rain?
1997 International 4900 Chip/Dump Truck, VIN # 1HTSDAAP4VH459252 (A61165)
1997 International...
John Deere 5101E Tractor w/ John Deere Loader (A64047)
John Deere 5101E...
300 GALLON PORTABLE POLY TANK (A62130)
300 GALLON...
Hustler Super Z 72in. Zero Turn Commercial Mower (A61567)
Hustler Super Z...
(INOP) 1991 INTERNATIONAL 4900 6X4 DUMP TRUCK (A62130)
(INOP) 1991...
UNUSED WOLVERINE HEAVY DUTY PALLET FORK FRAME (A62130)
UNUSED WOLVERINE...
