No more 'treadle pedal'
/ No more 'treadle pedal' #1
5030
Rest in Peace
SE Michigan in the middle of nowhere
Kubota M9000 HDCC3 M9000 HDC
I was looking at an new MX series with hydrostat drive and immediately noticed that Kubota got rid of the clunky 'treadle pedal' and replaced it with a much shorter 2 level cast aluminum pedal control that is 100% Drive by Wire. Never had a hydrostat but I've always not been impressed with the oversized 'treadle pedal'. Not there on the new MX series.
/ No more 'treadle pedal' #2
I assume you mean cables when you say 'drive by wire?' Not like 'fly by wire' in an aircraft which means electronics. Interesting. I need to go look at one...
/ No more 'treadle pedal' #3
Haha! But, but, .... but all these guys on here saying how great the treadle is (more like denial, because the rest of the machine is so great)
/ No more 'treadle pedal' #4
The treadle is sort of kind of OK once you get used to it and have a good right foot ankle, but I can certainly see a big problem for someone who has issues with the ankle movement in their right foot!
Has anyone done a conversion?
/ No more 'treadle pedal' #6
So this is gone on the 2022's and replaced by 2 pedals?
/ No more 'treadle pedal' #7
I hate the treadle. Sooooo much easier with the normal 2-pedal setup. At least for me.
/ No more 'treadle pedal' #8
Only thing on the B that is worse than JD. Sooo many other things are better.
/ No more 'treadle pedal' #9
I love the treadle pedal on my tractor and hate the JD I have to drive when I volunteer to cut grass at the Church camp. Every tractor should have a treadle pedal. The World would be a better place.
/ No more 'treadle pedal' #10
I agree, I would love to see a picture of the new pedals on the the MX line.
/ No more 'treadle pedal' #11
Not two pedals, just a smaller treadle.
/ No more 'treadle pedal' #12
What?! The church can afford a JD? Donations wisely spent?
Just kidding. I have a Deere mower and while it was expensive, it is bulletproof, never has an issue, easy to use, hates grass, lives happily with my negligent maintenance schedule, and is like the energizer bunny. Worth every penny.
/ No more 'treadle pedal' #13
They've been using that pedal for quite a while. The 2016 l6060 i used to run had it so I assume since the 60 series came out. I like it quite a bit despite usually hating everything that's electric over hydraulic. I'm really picky about control feel and response and haven't had any issue with it over about 3000 hours of use. I guess my leg feels slightly more extended than i'd want when going forward but thats being super nitpicky.
/ No more 'treadle pedal' #14
I'm liking the 4X3 with a clutch pedal the more I read this.
But I will admit, the two tractors I used today were both hydros. ;-)
I was moving sand and stone, preparing to put down walkway pavers, so leveling and grading etc. It was nice to be able to move the tractor while standing next to it by just pressing the pedal with my hand ;-)
/ No more 'treadle pedal' #15
That’s been around for a long time. My L3240 that was like a 2008 had that pedal. The economy tractors get the long mechanical pedal and the higher option ones get the shorter drive by wire pedal. I really don’t see why there’s so much hate for the long pedal. It works fine as long as you don’t put your whole foot on it. The short pedal is the better design though imo. I’ve never liked the 2 pedal setup.
/ No more 'treadle pedal' #16
My 2021 MX has the long mechanical pedal.
/ No more 'treadle pedal' #18
With a bad right leg the treadle on the BX and B series was a pain. Upgraded to an L with cab and the re designed peddle is a dream
/ No more 'treadle pedal' #19
This isn't new, in fact Kubota has had 3-4 different "treadle" setups for at least 10 years, probably longer.
The one shown here is more of a rocker, and tends to be on tractors with the HST+ and electronic (fly by wire) controls. Your entire foot can rest on that one and pivot at ankle, or use combo knee pivot and ankle.
There is also a longer mechanical treadle, completely above the floor, with front pad and rear peg. You operate that one by alternating heel or toe on the floor in the middle and opposite end of boot on the respective peg. Pivot at the knee, press with ankle.
Then a third mechanical design that works like the previous one, but the treadle is below the floor and only two foot pads stick above, so it seems like two pedals inline.
All of these operate a little differently. I see a lot of people try to use the mechanical ones like a big rocker and then complain how terrible it is, but they are doing it wrong. Should be obvious in my opinion (it's longer than even Sasquatch shoe size), but apparently not. If able to correct them, you can see a light bulb go off and they are happy. But I wonder how many people write off this kind of treadle and/or the brand because they are working it wrong.
I've said before, I have Deere and Kubota products and frequently go back and forth between twin pedals and single treadle, and both work fine for me. Unless you have a leg injury or handicap, either should work for most people.
/ No more 'treadle pedal' #20
Oh heck do away with the danged foot pedal thing a ma bob and go back with hand control on the dash or fender and a foot n inch pedal for the clutch foot.
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A67714)
2011 MULTIQUIP...
1998 MP CUSTOMS PRESSURE WASHER TRAILER (A67714)
1998 MP CUSTOMS...
2017 VOLVO SD115B PADFOOT ROLLER (A65056)
2017 VOLVO SD115B...
Unused 2023 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused 2023 Land...
2015 Freightliner M2 106 Ambulance (A66736)
2015 Freightliner...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
