I need a propane torch that works
   / I need a propane torch that works #22
I have the same problem with a Bernzomatic and with the one that it replaced. It just won’t stat lit. Won’t burn when inverted for more than a few seconds. Basically makes it useless. Sounds like the $20 unit is garbage and the $50 unit works as designed. I wish companies would stop selling things that they know are junk.
None of them burn inverted.
   / I need a propane torch that works #24
Bernzomatic for sure - I have an ancient one, non-self igniting, with blue cylinder for simple arson jobs (burning brush piles) and a self-igniting one with MAP gas for serious torch work.
   / I need a propane torch that works #25
I struggled with torches also and did several hours research. The Bernzomatic TS8000 had rave reviews and they are right. Don't cheap out on your torch. This one lights instantly, heats quickly, has a flow control valve, and with it's special "swirl" technology it even sounds aggressive.
It is important to understand the differences in torch and gases. Many retailers sell gas advertised as Mapp gas when in actual fact, Mapp Gas is now illegal in North America. The replacement gas is actually Map Pro Gas which burns only slightly hotter than Propane unless it is combined with the dual tank Map + Oxygen.
To summarize approximate gas temperatures-
5200°F- Mapp alone (now banned)
5300°F- Map Pro + Oxygen
4100°F- Propane + Oxygen
3700°F- Map Pro
3600°F- Propane
Note the torch head also affects the temperature significantly. The TS8000 burns hotter than any other torch. Great temperatures can be achieved using this torch with Map Pro + Oxygen but the oxygen tank will drain quickly (~15 minutes) and would wisely only be used if bending steel is desired or brazing.
So with the TS8000 torch, the difference between Map Pro and Propane gas is barely noticeable (see temperatures above) as verified by timing the heating of my branding iron. Also note that the TS8000 torch produces a hot but diffused flame, whereas the old propane torch produced a pointed flame similar to an acetylene flame (when tuned properly) that was better for soldering in confined spaces.
   / I need a propane torch that works #26
https://en.wikipedia.org/wiki/MAPP_gas has some interesting info here. I don't believe MAPP was actually banned. OSHA set safety limits (it's quite toxic at high concentrations) but apparently the only US manufacturer stopped production after their plant was damaged; it just never got enough traction.
   / I need a propane torch that works #27
As others have said, the self igniting feature is fantastic.
   / I need a propane torch that works #28
Just a simple, basic torch which screws onto a disposable cylinder and burns when you light it. Heat, solder, or start a bonfire, then turn off the valve until next time. That seems like an easy request but I haven't found one yet. I've bought two Bernzomatics and another brand (I don't recall the name as it went out in the trash.) Screw the tank on, light it and it may sputter for a few seconds but then it goes out.
Has anybody bought a torch in the last 5 years that worked?
I was a plumbing contractor for 35 years and we always used the basic turbo torch with no igniter, burns propane and map gas, even upside down, easy to clean the orfice by putting it in backwards and blowing it out...I retired 10 years ago so I don't know if the quality has gone down but I'm still using the one I retired with...
   / I need a propane torch that works #30
I'll second the Turbo Torch. Workplace has older ones, probably going back decades and the things last forever.
   / I need a propane torch that works #31
Get an old used torch at a garage sale, hock shop, or Habitat Restore.
   / I need a propane torch that works #32
The other minor detail about MAP-Pro (propene/propylene)gas which burns a hundred or so degrees cooler than MAPP, is that the BTU intensity is much higher than propane. MAPP/MAP-PRO deliver almost twice the BTU/area of propane, and slightly more than acetylene. Nice comparion table here; Fuel Gas/Mapp Gas_Aerosol Gas Company (AGC)
If you want it hot, fast, MAPP, or its replacements have some real advantages. Personally, it is worth the cost to me, especially in metal working and copper re-work.
I love my bernzomatic torch. It just works.
All the best,
Peter
i keep a Bernzomatic around; comes in handy, including in the winter when I need to melt ice on my snowblower fan.
you say that yours doesn't stay lit- do you have it turned up all the way?
Yes. Actually it doesn't even light anymore; nothing comes out the oriface. It's a brand new torch, it has about 1/200th of a bottle through it. I've played with it, tried different tanks yet nothing works. don't plan to spend a lot of time getting it going.
   / I need a propane torch that works #34
If you don't want something as big and bulky as the TS torches (I have both the fixed and adjustable, they're great...) and have a tractor supply around, pick up one of THESE, I have one and it's a good budget torch and has an igniter...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
2020 Chevrolet Silverado 1500 Pickup Truck (A59230)
2020 Chevrolet...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
