My solar set a new record yesterday
   / My solar set a new record yesterday #1
orezok
Super Member
Mojave Desert, CA
Kubota B7800
I have a ground mount 7.53 kW system that I installed. Yesterday it produced 56 kW with a peak of 7.1 kW at about noon. That’s a 94% efficiency. I set the panels at 25 degree so May and November produce my greatest outputs.
So far this month I produced more power than I used every day.
Gotta love that desert sun!
   / My solar set a new record yesterday #2
Congratulations! Who is the local utility?
   / My solar set a new record yesterday #4
So tell us what they are paying you for the overage? Bet it's not the billed KWH rate.
No, but it’s enough that last year my total usage bill was $165 and this year tracking about the same. 2460 SF all electric house except for the propane standby generator.
   / My solar set a new record yesterday #6
What works for you don't necessarily work for everyone. Up here we have more overcast days than sunny ones.
Curious as the what your system cost complete with storage batteries and controllers?
   / My solar set a new record yesterday #7
Where I live many people have home solar systems, but few are off grid with storage batteries. Most do net metering connected to a power company. When the system is producing power, it goes into the grid and the meter spins backwards. When the house demand is greater than the system is producing, the meter spins forward. The bill is adjusted accordingly. My neighbor gets a check from the electric company every six months because his system produces more than he uses.
   / My solar set a new record yesterday #8
It is sunny and dry in NM, much more so than here.
   / My solar set a new record yesterday #10
They still generate excess power during the rainy season. Cloudy weather still generates power. Only darkness shuts down the power generation. The systems are of course less effective during cloudy days. But that’s when some is purchased from the power company. Better to buy power sometimes than everyday. We get more cloudy and wintry days than I think most people realize.
   / My solar set a new record yesterday #11
How is the water supply doing?
I’m grid tied so no storage. Panels, microinverters and time of use meter. I’m in a 120 MPH wind zone so footings and structure are pretty heavy. If I was just 200 yards further north I would have been out of it. Footings are 24” diameter and 4’ deep. I’m a General Contractor and did the entire install myself so no labor or equipment costs. Total cost was just under $16K before 26% rebate. Call it $12K or $1.60 per watt.
   / My solar set a new record yesterday #13
Good job! (And great price!)
All the best, Peter
   / My solar set a new record yesterday #14
Dry this spring like every spring. In July the monsoon rains come and it greens up again. We get winter snow and summer rain, dry spring and fall. Like for the past 50 years I’m familiar with.
   / My solar set a new record yesterday #15
My install was more of a finish of an existing project started back in 2008 by the original owner.
6 kW ground array with peak about 4.3
Had hoped for better but that said the old 160W panels continue to produce all I use with a small check each year for excess production but the way that is calculated will be less favorable to me going forward.
Buying the place it was one of my priorities to to expedite commissioning and it does bring a smile to my face being a net producer...
   / My solar set a new record yesterday #16
Just looked at solar production:
7.5KW Rooftop array, fixed 18 degree (4/12 pitch roof)
20-375 watt panels facing south in near central Minnesota.
For May 1rst-24th avg 33.75 kwh per day, 810kwh so far
For 2020 and 2021 annual total output = 9120kwh per year.
25 kwh per day average.
This is almost exactly what we use for the year.
I like to open the electric bill.
The best part is when I find a light on and say to the one in charge of all things:
"Do you think we get free electricity around here?"
She says "as a matter of fact, yes I do."
R
   / My solar set a new record yesterday #17
R
So you solar system was free? If so, please tell me where I can get it.
   / My solar set a new record yesterday #18
If you live in MA it is free. My brother installed a panel system on his roof for $30K. Feds gave him back 30% that year so cost was reduced to $21K. MA pays him $2,100 a year for 10 years which is $21K which equals free. And he pays nothing for his electricity so that saves him $1800 a year, so after the first ten years, his $30K investment completely pays for itself and yields $18K return. So technically solar is not free. It yields a significant profit. I would have done the same but CT is not nearly as generous with solar.
   / My solar set a new record yesterday #19
Iman:
After applicable rebates and tax credits, (these credits directly
subtract income taxes owed) this system costs outlay is paid for in
less than 4 years.
A utility program pays 7 cents per kw production for the first 10 years,
in addition to the grid-tied production offset, (the meter running "backwards").
The array will produce power for 30 years.
That makes it not only free but a utility bill off the table
every month.
R
   / My solar set a new record yesterday #20
I confess to checking production several times weekly and the little tweaks I do to help production such as at least one each summer panel rinse in the dry spell and seasonally pulling the pin to adjust array tilt to better match the angle of the sun…
My system components date from 2008 and not efficient compared to higher output newer panels but each year continue to produce a surplus.
The only disappointment is the utility keeps adjusting the buyback price per kW lower.
Soon utility kW will be nearly free but the cost of distribution continues to skyrocket.
2007 KUBOTA KX121-3 SUPER SERIES EXCAVATOR (A60429)
2007 KUBOTA...
2015 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Peterbilt 579...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2016 Ford F-550 Altec AT233P 35ft Bucket Truck (A59230)
2016 Ford F-550...
2015 Forest River Rockwood Freedom S/A Pop Up Trailer (A59231)
2015 Forest River...
