Flattening mole tunnels
/ Flattening mole tunnels #1
jmc
Elite Member
SW Indiana
Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
i no longer have a mower suitable to pull my lawn roller. Anybody ever float their loader bucket and drag the yard? Did you have to add weight to the bucket?
/ Flattening mole tunnels #2
No I never have nor would I ever try that on a finished lawn imo. I have had some luck reducing mole tunnels by running a spike aerator not the plug type, which supposedly kills grubs, which moles eat. Good luck
/ Flattening mole tunnels #3
I just run the mower or tractor tire along the length of the tunnel.
  • Good Post
Reactions: JJT
/ Flattening mole tunnels #4
I wouldn't do that. I think it would damage the grass. If you have a loader bucket, I'm guessing you have a tractor. Why can't you pull your lawn roller with that?
/ Flattening mole tunnels #5
Try loaded in float.
/ Flattening mole tunnels #6
I was thinking this also. If you have a tractor with an FEL, it should pull your roller.
/ Flattening mole tunnels #7
I just shear them off
/ Flattening mole tunnels #9
I’ve taken my 1500lb ZTR and rolled over them. Of course, after I trapped the bastards. This place used to be riddled with tunnels, Ive trapped about 15 on our 2 acre lawn in the past three years. All of a sudden they are very rare 😂
/ Flattening mole tunnels #10
Amateur!
One year we had moles pop our above ground pool liner. This was in August. I got mad and decided to start trapping them. I got 29 that fall. The following spring I started trapping as soon as I saw activity. I stopped counting at 50 each year for the next 6 years. So that's over 329 in 6.5 years, in 1 acre. Sheesh. Finally, they started to dwindle, and I only get a few each year. Haven't had to trap them for a couple years now. It was just insane.
/ Flattening mole tunnels #11
Amateur!
What kind of trap do you use?
/ Flattening mole tunnels #12
I've tried them all, but came to realize that the Victor Out O Sight mole trap is hands down the best. I have 6 of them.
First, let me say that I don't enjoy killing these critters, and I don't want to see animals suffer. The Nash choker loop trap doesn't kill the mole very fast at all. I've had the moles dig themselves and the trap out of the ground and haul it across the yard. I then have to find the animal, and dispatch it to end it's suffering.
I've tried the traps with the spikes that shoot down. I've had many trips, but never found the animal. So it either missed, or the animal scurried off wounded, living or dying, I do not know.
The Out O Sight trap seems to kill them very fast. I've only found 2 moles still alive in that trap, and both of those were just pinched by the scruff of their fir and uninsured. I let them go out in the woods. The other several hundred were all dead.
The advantages of this trap are that it can be set at any depth of tunnel, not just on the surface, and, the trigger pan can be modified with a pop-rivet and canning jar lid to make it work better in sandy soils that might fall away from the narrower stock trigger.
They are also relatively inexpensive, around $10-15, although I imagine they'd go up in price as everything else. Here's some for $10.
It takes some hand strength to set them with the setting bars.
But, they work. Plain and simple.
OP here.
Thanks all, for commenting. I think my stunt might work if the very top soil is damp but below that is firm. We've had a week or so without rain and expecting a little tomorrow. I've got R4s, and my yard is not manicured. Might even try a little down pressure on the bucket and steer with the rears if necessary. Wish me luck.
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
2018 Keystone Outback Super-Lite 330RL T/A Travel Trailer (A59231)
2018 Keystone...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
207271 (A52708)
207271 (A52708)
