XR3037H RPM up and down after a few minutes of operation.
   / XR3037H RPM up and down after a few minutes of operation.
Thanks George2615. Got it ordered. I'll keep everyone updated on the diagnostic progress. Sure wish LS would find a better deaaler up here that would do service calls.
Got the adaptor and still getting a connection error. Also reads a bad barrery on the screen. Still dies before it re gens. Does a bad battery effect the diagnostic tool? Tractor starts just fine.
   / XR3037H RPM up and down after a few minutes of operation. #43
I'm not familiar with your Nexlink or how to set it up. I use an ELM plugged into the port (bluetooth connects it to my phone) and used a program Cummins Fault advisor (free download). It will read a lot of functions and most show a numerical value which I can take a snapshot and download on my computer but did not see any way to read or clear codes. I've pretty much given up since it seems all the stuff you want to read or reset is dealer only.
There is a company or two that do sell tractor diagnostic tools but the cost is $3500-6000 depending on which one you buy. Way to rich for me. I'll just have to save up for the day I have to take it to the dealer for a problem. I'll probably jinx myself but I guess I've been lucky with no problems the past 8 years.
Can you send me info on the ELM? I'm dead in the water unless I can figure out what I need to get this hunk of iron runnining. LS said they can't do anything about the dealer support from Daves Tractor up here. They basically said it's my problem. I just need to know what parts to order to fix this thing. LS dealer in Spokane WA said they would sent parts up if I know what I need.
   / XR3037H RPM up and down after a few minutes of operation. #45
   / XR3037H RPM up and down after a few minutes of operation. #46
I was just reading through this thread. First, I'm sorry for you're continued issues. There is a reason why LS moved away from those Shibaura engines. That doesn't help you though. I'm thinking that you might actually have a plugged up DPF. Though the temp sensor could also be at fault. For that fact, many things could be the issue. We need to methodically diagnose the issue, not simply shotgun issues. Start with the simple and move to the complex. Your tractor has a looping idle no matter what you're doing. It will not complete a regen cycle, it goes into limp mode. You have already replaced the fuel, filters, etc. Checked battery cables, and loose wires. Thats the simple and obvious, but didn't fix the issue. Lets move on.
At first glance, the pin hole in the fuel line might sound good. But typically that issue will kill the tractor and it wont start again. When a diesel sucks air, even a little, it dies. That was my first call to my dealer (Spokane Cascade Tractor). Tractor suddenly died while working, my basic diagnostics didnt pan out (I did check the fuel line, no leaks), called the dealer. They came out, we spent several hours diagnosing (with his laptop scanner tool too) trying to find the issue. It wasnt until the mechanic accidently touched the fuel line that we noticed a single small drip of fuel coming from it. Replaced the line, primed, and not had an issue since.
Eliminating the fuel leak sucking air, lets look at the ECT. The ECT or the Engine Coolant Temperature Sensor is located where the top radiator hose enters the engine block on your tractor. It is part number 40283508 from LS. Before ordering, you can check it for continuity. There should be a range of resistance based on actual engine temp that it will show. You will need an ohm meter, an IR thermometer, and a service manual. That might be an issue. If you don't know the resistance range for the coolant temp, how would you know what ohms are good? But, you can at least see if you're getting resistance. Unplug your ECT, put your meter on ohms, and probe the blades. Some resistance is good, a ton is bad, and none is bad. For example: the service manual for my tractor's ECT specifies the resistance to be 9.675 ohms at -10C to .148 ohms at 110C. Yours are probably similar. Your ECU should be throwing a code on your dash if your ECT is acting up. However, ECT's are cheap, and yours appears to be a chinch to replace. Simply replace it if you feel the need.
However, I suspect your tractor might have a plugged up DPF (among other DPF related issues such as your ACV (Air Control Valve) on the DPF system that is malfunctioning not regulating the proper amount of air/fuel mixture into the DPF during regen. Could be the DPF temp sensor being faulty (Ohm range on mine: 170.2 at -40C 849.7 at 1,000C EGT). If this is the case, a plugged DPF, you'll need to have it serviced at the dealer. I'm sorry. There are videos on YT that show how to clean them, but I cannot recommend them, and playing with them can seriously screw up your engine. Replacing sensors is one thing, taking the filter off and pressure washing it is another.
Before doing anything, give Cascade Tractor a call in Spokane and ask for the service manual for your tractor. If they can get it (which I'm sure they will, just depends on how much money), it will save you a ton of time an guess work. These government regulations on these tractors suck. It causes more issues that they are worth. But lets get you up and running, then complain.
Avenger you have been a wonderful help. Your information gives me some sort of direction now. I'll give Cascade a call and see if they can sell me the service book. I'm going to be out a ton of money if I have to have this thing air lifted back out during the summer so I really need to dig in and figure things out since the dealer refuses to work with us. I'm to the point of offering Cascade an all expense payed trip (fishing included) to Alaska to get this thing running. My son lives in Spokane so he could pick the service manual up and get it up to me. I will do the ohm test and keep you posted. Thanks so much for your help.
   / XR3037H RPM up and down after a few minutes of operation. #48
Here is some troubleshooting info from the Shibaura N843 engine manual.
   / XR3037H RPM up and down after a few minutes of operation. #49
Regen every 5 hours ? To me that seems very excessive ! My LS XR4155 has only regenerated twice in 180 hours.
Sorry, I missed your reply. Myself and the OP have older model LS tractors with the Shibaura engine. Yours has the LS engine. Shibaura engine regens every 5 hours, LS is supposed to regen every 50 hours.
Thanks inpo44! I'll print those pages out.
Its ELM327. I ordered mine off Ebay but it shows currently out of stock. Also link to Amazom also out of stock.
See post 44 in the below thread. If I recall it was under $34.
Found the code reader. Where did you find the Cummins Falt app so I can download it to my phone?
   / XR3037H RPM up and down after a few minutes of operation. #53
Cummins fault code advisor is a downloaded app for my android phone. I'm sure there should be other available downloads for other phones. Do a search on your phone for Cummins fault code advisor.
Got it. Thanks. I'll play with it as soon as the code reader gets here from Amazon.
Well got the code reader and hooked it up and turned on bluetooh , opened the Cummins app but the reader will not connect to the phone and just shows one light on. Wi fi or bluetooth was a no go. Tractor was running. Still doing the same thing. Goes into regen then won't complete regen then shuts down.
Found a dealer in Palmer Alaska that can work on LS tractors. 100 miles away but better than not having a running tractor. LS really needs to up their game as far as getting a decent dealer up here. Pioneer Equipment said they have had alot of folks trading in the LS because of lack of support. I'm still at a loss on how Daves Tractor even got the dealership and is still in buisiness. Sorry for the rant but 6 months and they still can't find time to work on it is way beyond reasonable. I'll keep you posted on what they find.
   / XR3037H RPM up and down after a few minutes of operation. #57
I was thinking the same thing. I am about every 60 hours but I dont run it at PTO RPM a ton.
   / XR3037H RPM up and down after a few minutes of operation. #58
Sell it and get a machine that has the support you need in the area.
   / XR3037H RPM up and down after a few minutes of operation. #59
The difference is the XR3037HC (3000) series uses a Shibaura engine which was designed for regen every 5 hours. The newer 4100 series has the LS engine designed for regen about every 50 hours.
   / XR3037H RPM up and down after a few minutes of operation. #60
Regen every 5 hours seems like a massive waste of fuel. OP should sell it and get a more suitable machine.
404 (A52706)
404 (A52706)
2016 KENWORTH T680 TANDEM AXLE DAY CAB (A59905)
2016 KENWORTH T680...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
2019 KOMATSU D61PXI-24 CRAWLER DOZER (A60429)
2019 KOMATSU...
2019 JCB 457 (A60462)
UNUSED FUTURE HYD THUMB CLAMP (A60432)
UNUSED FUTURE HYD...
