Electric Fence?
/ Electric Fence? #41
I bought this one - after I kept losing or misplacing several others. It seems to work - and it also provides information on how much the charge is - unlike the ones that just light up. So far so good.
/ Electric Fence? #42
Did it perhaps ship with the battery disconnected?
Is it clicking when you turn it on?
Aaron Z
/ Electric Fence?
Aaron Z
No neither one is clicking. I did take the battery out of the Zareba and put it back in. So, I know it is hooked up. But did not look at the other battery but guess I should. But again, neither one is clicking. Oh, it lights up the battery must be connected,.
/ Electric Fence?
I just brought it in the house and banged it around a little. (how I fix most stuff) Believe it or not, it is now showing voltage & shocks to the touch. But the shock is not real offensive to me. Just touching both terminals, not like standing on the ground touching it,. and a deer has four feet on the ground. Will put it back on the fence tomorrow and see what it does.
/ Electric Fence? #45
Is this the fencer that you have ?
/ Electric Fence? #46
If you are not getting much of a shock touching both terminals you might better just take it back.
It's not working.
/ Electric Fence? #47
If you takeing your stuff back for refund consider these options . Once again most "big box store" fence chargers are generic junk . Theres an option here cheap you can run with a deep cycle . Or charge it on occasion with your long run.
/ Electric Fence?
Yeah, thanks , I might see if i can find one of those local.
/ Electric Fence? #50
Did you check the battery voltage while you had it out?
Not sure how that one is setup but the solar charger we had (granted that was 25 years ago now) clicked just like the plug in ones do.
Aaron Z
/ Electric Fence?
Aaron Z
Neither one of these click. The lights just flash. I don't think these are designed to click, like others I have seen. I never checked the battery voltage. The tractor supply one is working now , the light blinks and it does shock some, but not as hard as I Remember getting hit by electric fences over the years. It does light up the tester now.
/ Electric Fence? #52
If you are grabbing directly on to the terminals of the solar energizer that thing should light you up to the extent that you wont even want to walk by it. something is wrong with the energizer.
/ Electric Fence? #54
/ Electric Fence? #56
My fence around my garden is only about 8 in high, been doing this about 20 yrs, no deer problem and I live in west central AL deer country. It works for me and that's what counts.
John Deere 6125R (A64126)
John Deere 6125R...
2023 Kubota L6060HST Compact Utility Tractor (A63688)
2023 Kubota...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
Lincoln SAE-400 Shield-Arc DC Arc Welder - Inoperable (A63689)
Lincoln SAE-400...
2014 John Deere 1025R (A64126)
2014 John Deere...
