Wheel and tire swap for L4760
/ Wheel and tire swap for L4760 #1
fishpick
The part of NY with high taxes
L4760 & BX24
So - I have an L4760. When I got it I bought it with R1 wheels and tires because it was doing a fair bit more farming type work.
Now - the R1’s are just pizza cutters on anything in the spring and honestly the tractor has become mostly a snowblower and deer getter during hunting season.
I’m thinking of swapping out the wheels and tires for an R3 turf setup. Then I think I can get more use out of the tractor around the property without destroying the lawn. I think they would be easier on the gravel drive in the spring. Certainly spread out the weight more.
In the winter if I needed to I could put chains on and not really lose any real traction for snow and muddy deer season duties.
Am I missing something. I kinda feel like turf with the option to chain them is the most versatile option…
Except almost nobody does that!
the floor is open for opinions.
/ Wheel and tire swap for L4760 #2
I’ve never had any problem with R4s tearing up my yard just going across it and I haven’t had any issues with traction in the fields or woods. I don’t think turf tires would cut it for going back my trails.
/ Wheel and tire swap for L4760 #3
Your task list for the year and what is highest priority for your situation drives it. Depends mostly on what you need to do, how much and priorities. Since you opened the floor for opinions I'll throw in just a couple.
  • I have used both turf and ag tires when snowblowing. Turf tires are lousy for snowblowing giving poor traction and turning snow to ice as if made to do so. R1s do drastically better.
  • Putting chains on is a laborious nuisance which I think of as an emergency bailout, not a planned practice.
  • How big of a fraction of your tractor use is running on your lawn? Maybe some other machine is better there allowing you to keep the L4760 mostly off the lawn
  • What do you cut? How big is your property? What are the primary chores ? I can't think pulling in deer and snowblowing take up all that many work days.
  • Swapping tractor tires is significant expense & hard to justify unless you have a lot more reason for doing it than I have heard so far.
/ Wheel and tire swap for L4760 #4
I'm not sure what the turf options are for the L4760, but I believe they are same as the L3240 I have. I have the 44x18-20rear and 29x12.5-15front turf option.
Other then the fact they are lot loaded, they give good traction in most conditions due to the large lugs on the rear tires.
I've plowed pretty heavy snow with a heavy 7ft blade and would say they did decent, if they were loaded and had chains they would have done outstanding.
I also have loaded R4's and they typically do better pulling a box blade, but I think that is due more to the added weight.
Plus I think they look pretty meaty on the grand L!
Sent from my SM-G715U1 using TractorByNet mobile app
/ Wheel and tire swap for L4760 #5
My tractor came with R1s and I bought turfs since I have to drive through my yard a lot and the difference is amazing, perfect choice for me. Turfs were great in snow for me and surprised the other person said they are worse than R1s because that wasn’t my experience and while researching my change lots of others said turfs are better on snow. I also kept the R1s so I can use them if I need to but not sure that will ever be necessary. The rears are 41x14-20 and even loaded I can swap them out myself pretty quickly. I agree chains are annoying and cumbersome. R4s and R14s are very popular and for good reason but turfs were best for me so I don’t think you’re wrong to consider them.
Re: @JWR - so being completely frank... the L4760 was bought at the end of our time farming... it was a replacement for a New Holland TC45DA - same size - but with a cab and mid-PTO - for snow-blowing - which we have a really long drive and this tractor makes a "chore" a hella lotta fun now. But - the tractor is way more machine than I need. I have an old BX24 that mows the lawn - so the L4760 lives a pretty sheltered life right now - it gets used with a land plane to fix the driveway in the spring and again in the fall. I use the loader / forks for a few task here and there. And I have a Bush Hog that goes on the back - but at this point it's more a rough finish mower for established trails - nothing new is being knocked down. So to your point - yeah - the L4760 sits idle a lot of the time.
WHICH is why I'm seriously considering turfs.
With turfs I would not have a single reservation pulling the tractor out to do other chores around the house (case in point - this last weekend we were moving a bunch of deck furniture from a shed to the deck - and hand carried all of it - in the fall we use the tractors loader to move it because the ground is usually hard. That's just one simple example of where I think the L4760 sits idle.
Honestly - I should have sold the TC45DA & the BX24 and gotten something like the LX3310 at the time with all the attachments - except that model didn't exist and the 30hp one back then had the new particulate tech and the dealer said don't do it... AND - at that time - thought the bigger tractor was needed.
Also - turfs are fine for snow blowing.
@AaronD81 - I have had fine luck with other tractors in the snow with turfs too.
As for chains - I agree they are not a simple on and off ordeal - but putting them on in the fall and taking them off in the spring is, gain, something I used to do with a JD at a cabin we had. It had R4's but the soil was almost pure clay - so they would load up anything - the only solution was chains to be able to skid logs out... so - I'm not "chain adverse" and if I did go turfs - would mount the rears "wide" so they were easier to get on with clearance between the tire and the cab.
I really am annoyed - I just dont need a tractor this big - but I think it's a hella lot cheaper to buy turfs & chains (or R4's but even on BX - where we live with super fine silty soil - mowing the yard in the spring leaves mess) vs a whole new tractor...
I'm just trying to get the L4760 out of the barn a bit more often...
(sigh)
You know - I myself have said buy the biggest you can... but in this case - the tractor is just bigger than I need... tires are an attempted rescue.
/ Wheel and tire swap for L4760 #7
Sounds like you have a bigger question to ask first, whether you'd really be happier with a smaller tractor. If your implements will work with an LX you might want to price one out and get a trade or sale price for the L, you can probably downsize without paying anything out of pocket. It looks like you may come out with some cash in your pocket based on a quick tractorhouse.com search. If you decide to keep the L I think you'll be happy with turf tires, it's allowed me to use my tractor a lot more.
/ Wheel and tire swap for L4760 #8
That is near blasphemy!.
Why didn't you move the furniture with the B24?
If you are at ALL contemplating selling it's definitely a good time to sell.
/ Wheel and tire swap for L4760 #9
fishpick -- I have a much better picture of your circumstance based on post #6 above. I just don't see how swapping ag tires for turf tires improves your situation at all. I do not say what is right or wrong, I just don't see it. I have yet to meet the person who is happier with smaller tractor -- but again maybe you would be.
Every case is different.
$ wise it would make a lot of difference if you had some deal available (another person willing) to swap wheels and tires with you. Those deals are almost impossible to find unless you already have one lined up. Your case is puzzling enough that I can't vote strongly for any solution for you. Best of luck sorting it out and finding the sweet spot for what you need.
Well @JWR - the turfs would get me able to use my bigger tractor (than I need) at least from March - May when things are so wet the R1's rip it all up...
But - I agree - I'm feeling like buying turfs I'm almost throwing good money at bad at this point... I do agree about most folks not being happy with a smaller tractor - but - I have tamed our 34 acres... don't move round bales anymore, don't have livestock trailers to drag through a pasture, don't use the Bush Hog for anything other than finish mowing of trails... Any tree I'm dragging out is not gonna be huge nor something I can't cut into smaller chinks if needed.
While we do get 80+ tons of gravel every few years for the driveway - waiting for those big jobs with the L4760 is - waiting... And a smaller tractor can pull a land plan to smooth out the seasonal pot hold that the driveway gets too.
I'm starting to explore the notion of selling/trading the L4760 (its so nice tho) and the older BX24 for something like an LX like @AaronD81 suggested - and seeing if I can "simplify" life down to a single tractor to rule them all...
I could blow the driveway in warmth in the cab with a front mounted blower, have a bucket and forks for about 2000# or lift, have a 3PT finish mower to take care of the yard and get back a bunch of space under the leanto and barn not having 2 tractors...
Just gotta see if I want to do that - if I like the platform of an LX - if I can even find one locally in stock to look at... etc, etc, etc... But I'm thinking about that route...
I hate posts that never come to a conclusion (especially when folks offer input and advice)... because I always seem to the be the guy who finds said post for my question and never get an answer... so - here's where I'm at.
Went to a local Bobcat dealer right down the road - and talked "trade". I could unload my L4760 + FEL + front snow blower + Land Pride land plane for a CT2535 (or CT2540) + FEL + front blower + bobcat FEL attached land plane (this is so cool) + several other things + a Bobcat Zero Turn mower... and only pay a few grand out of pocket... I could ALSO trade in my older BX24 and get a additional attachment / options as well and be done - nothing out of pocket. So 2 tractors nets me a smaller tractor, added remotes on said tractor, some newer implements and a zero turn...
The thing is - the CT2535/40 chassis isn't THAT much smaller than my L4760... and the CT2540 weighs about as much - so - same issue with the yard (except R4's) - and life does not distill down / simplify to one unit - would have the zero turn... that ONLY mows. I did legit love the lever on the back of the Bobcat to raise and lower the lift arms when you are back there getting an implement on - I saw one of those on a Mahindra years ago - and can't believe it's on on every single tractor ever made since then.
So - while the deal is really good and I love the dealership (bought my first TC45DA years ago from them and that is still my favorite tractor ever) - I dunno that it changes much except I lose the small BX backhoe (gets used once every couple of years but when you have it - its great) and small loader if i need to get into tight spaces - and i get a zero turn to make mowing "faster".
So this got me reconsidering the tire swap math...
So - being a bit nerdy and attempting to quantify the choices based off input above and numbers... here's the numbers by the tire.
Front WidthRear Width
Ag (R1)8.3"14.9"
Turf (R3)12.524"
Industrial (R4)10"17.5"
I then took the current ag tire and tractor weight - assuming a physical 3" wide contact patch of the tire on the ground - and did math... calculating the tractor weight per square inc of the tire - and then normalized to a numerical value I'm calling GDF - or ground destruction factor... This should give a mathematical representation of the impact of changing a tire on the amount of carnage endured on soft lawn surfaces - so here we go:
So for example - my current R1's - the front tire is 8.3" wide and I'm using the 3" wide contact patch - (yea I know lugs change it, load changes it, just relax) - that front tire has a contact patch of 8.3 * 3 = 24.9"... rear math is 14.9" * 3" = 44.7"
So - the L4760 is 4222 pounds + the loader on the front adds another whopping 1411# for a total of 5633. AND... I have Rim Guard in the rears... so let's say for just simplicity and sake of argument that plus me and any tools puts us at a conservative 6200#.
Now - again - just for simplicity - we are going to assume a 40/60 split on weight distribution with the loader on and bucket attached... it might be a little different but we will keep this ratio consistent for the sake of the comparison. That puts 40% of 6200 = 2480# on the front axle and 3720# on the rear... then take each axle number and divide by 2, beacuse there are two wheels per axle... so that's 1240 per wheel in the front and 1860 per wheel in the rear... and now we have all the numbers we need for some fun!
We can start calculating the Ground Destruction Factor that the tires have - again - omitting the impact of lugs which make it worse by effectively reducing the contact patch until the lug has bottomed out and not accounting for turning or other factors... This is just a straight line point A to B with loader on across wet lawn calculation...
First we need to know the pounds per square in the tire conveys to the surface via the contact patch.
PSI R1
49.7991968​
41.6107383​
PSI R3
33.0666667​
25.8333333​
PSI R4
41.3333333​
35.4285714​
And then we can normalize the R1's to assume their Ground Destruction Factor is GDF = 100 (by dividing it by itself * 100)... and then we divide all the other weights per tire by the standard we have in the R1 - so see how much more or less their GDF is - mathematically.
GDF R1
100​
100​
GDF R3
66​
62​
GDF R4
83​
85​
So - "math" says the R4's should be about 35% less destructive on the front and the R4's should be about 15% less destructive. Realistically the turfs are probably better than that by a fair bit and the R4's by a little bit - because - back to what I keep saying... "LUGS".
Thinking about the R3's - adding chains if needed - gives you the lugs.
So for about $3K - I can get a full set of R3's (probably not loaded) - and likely NOT destroy the yard to such a degree - and if needed - add a set of chains.
I am going to go look at a LX2610 and see what that looks like - It's a LOT lighter than the Bobcat - and when I do my GDF math on that with the R4's - it looks like they come out to about 25 PSI and a GDF of about 60 in the front and 62 in the rear...
I dunno - was a slow morning - spreadsheets are fun - now I gotta go do something useful...
/ Wheel and tire swap for L4760 #12
Interesting analysis -- and obviously you are deep into it which resembles me and things I do... Sometimes the detailed analysis and elaborate numbers can obscure the actual outcome. Sometimes. I've made that mistake more than once. I like the idea you have a good friendly/cooperative Bobcat dealer nearby. Worth it's weight in gold. If you are going to make the move I weight that very heavily.
Working my way up to a suggestion: Why not try out one of these machines on your property ? You have the numbers, now go get the actual feel/touch/smell/see.
Here's the conclusion to my story (almost)...
I looked at a Kioti and was impressed (obviously same as the Bobcat) - they have come a long way and I wouldn't be scared to buy one - they should really give Kubota & JD a run for their money - since a Kioti seems to categorically have more features for fewer dollars. That little CX2510HSTC comes loaded with remotes!
I also saw a guy in a church parking lot with a LX2610... I pulled in and talked with him for a while - he let me in it, drive it, screw around with it.
While the LX is a nice platform... and if it was my first cab I might think it was the best... Man ohh man does the LX NOT compete with the L4760 in terms of the HST, layout, general comfort. Perhaps the single most "this is not a deluxe cab" feature - IMHO - was the fact the freakin fuse box and battery get kicked when you move your feet across the platform. Like - honestly - my 20 year old BX has a crappy plastic shroud covering that... and inside the cab - to not cover that is just cheap on Kubota - it very much diminishes the inside of the cab space... and there are other "super silly to anyone who does not own a Grand L" corners cut. Like - the steering wheel tilt pedal doesn't have a nice little grippy rubber cap on it, the loader joysick is just a little high, the dash is just less feature-full... the engine itself was noisier - but - it was also the LX2610 - so no electronic injection / DPF... more old school for sure - if that's your thing - but also less refined. To each his own tho. Nothing wrong with the LX but...
Bottom line - anything I found I didn't like on the LX is because the Grand L spoiled me - simple. (the only thing that would make me consider NOT buying an LX is the fact the HST is not very good - it's loud AF and it's got way too much "jerk / lurch" - not as bad as my BX24 - but way closer to the BX24 than I'd like)
The Kioti dealer guy and the Bobcat guy both would let me do a consignment of my tractor - taking 8% and 5% respectively - giving me the cash before sale on a Kioti CX2510HSTC or a Bobcat CT2535 (with loader and blower on both) - and let me keep the extra cash.
I did talk to my Kubota dealer who rocks - and they will do an even swap for me - my Grand L4760 + FEL + 72" snow blower for a LX3311 + FEL + 60" snow blower... fairly good deal to downsize and not spend out of pocket... losing about what you would expect on a trade in general.
In my conversation with my Kubota dealer - after he went through the work of getting the quote and knowing where some components of the deal could be sourced from - I asked him "if you were in my shoes - what would you do" :
(laughter)
"Well - every single time I get in a Grand L I think how comfortable and nice this platform is. I honestly think it's probably the best HST the company makes. It's just so comfortable. Also the older I get the more I find I use the forks to lift and move everything. If you are telling me the only real reason you are looking to downsize is because of the lawn being destroyed - if I had the 4760 and that was my only issue to using it - I'd lighten the 4670 as much as I could and if I could swing the $3 grand for turfs - I would try that before I got rid of the L. Hands down. I wouldn't personally be happy going form an L to an LX. They are nice but from an L to an LX is not an upgrade in anything."
Sooooo, I'm doing none of those deals above to start.
I'm gonna see if we can get a set of R3 turf wheels and tires to start (he got pricing - now we have to look at supply chain BS). If we can - I'm going to have them take the tractor to the shop and pull the Ag wheels - and drain the rim guard out of them - making each rear wheel at least 500# lighter - I'm keeping the ag wheels / tires (unless they have someone who wants to buy them becasue they don't want them sitting around their shop) - In theory then I could swap them back on if I ever need the heavy traction without needing a forktruck to put them in place... If I go a year and never think I need them - I'll put them on craigslist or this forum or something for a reasonable price. I suppose if we CAN'T get turfs and CAN get R4's... then I'll need to do a bit of soul searching on that as the price tag is gonna be the same... but 100% will not be as kind to the lawn... And my experience with R4's on anything other than hard ground (read : in mud) is rubbish - like abhorent why am I stuck so bad so fast where is the hell is the wheel it's a ball of clay - what happened? that sort of bad. Of course chains on that JD made them just fine - so it's not completely off the table.
So - back where I started with some fun along the way!
/ Wheel and tire swap for L4760 #14
I'm with ya. I'd sure try to find a set of turf tires/wheels by beating on eBay and Craigs list , etc. before buying them. That is going to cost up the yingyang. But the idea of having BOTH is a great option. You already have a good tractor, probably BETTER than you would trade into, and tires/wheels solves your problem as you perceive it. Having both lets you experience it both ways & is win-win if you can afford it.
You might contact some of the salvage yards [like Wengers of Myerstown in NE PA] which dismantle all sorts of tractors for parts which they warehouse. They MIGHT either have a set of wheels/tires you need or point you to someone else who does. Wengers are really good to deal with and help in oddball circumstances. I've had much help from them over the years. It would be worth a pickup truck trip down there for you if they came up with the wheels/tires.
That L4760 is one nice machine in so many ways, sort of in the upper end of compacts -- weight, HP, size, and apparently you like the cab (I never owned a cab.) I had a JD4700 about that size & it was one of the best all around I have ever seen. I sold it only because of want/need for a larger machine.
Sterling AT (A61307)
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
2022 TOP HAT TRAILER HYDRAULIC BUMPER PULL DUMP TRAILER (A60736)
2022 TOP HAT...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
CFG Industrial H15R (A60463)
CFG Industrial...
