Broken fan blade
/ Broken fan blade #1
tradosaurus
Super Member
Texarkana, TX
Kubota MX5400 HST, heavy duty bucket, 3rd function, R1 tires (rears filled), 2 remotes
Out on my 2021 MX5400 in my woods cutting brush and had a small stick come up underneath and shear off all the fan blades.
I'm within my 2 year Kubota warranty but I would be surprised if that covers it.
I'm pretty sure my home insurance will cover it but will see where the repairs goes with costs.
/ Broken fan blade #2
A fan is isn’t that expensive. Unless the radiator is damaged as well I’d pay out of pocket and go on.
/ Broken fan blade
It's replacing it that I'm more concerned about. I need to do a more detailed inspection to make sure nothing else is damaged.
/ Broken fan blade #4
Yep, 4570 is right. Also, the Homeowners Ins probably has a deductible on it 20 times the size of the price of that fan.
/ Broken fan blade
My deductible for the homeowners insurance for the tractor is $250. I had a truck repaired under home insurance because an animal camped out in my fan shroud and destroyed my fan blade and radiator. Equipment works different than house damage under my home owners policy.
/ Broken fan blade #6
I hear you. I'll rephrase my comment: Yep, 4570 is right. Also, the Homeowners Ins probably has a deductible on it 10 times the size of what that fan SHOULD cost. Surely to H that fan is not over $250. I suppose labor can be claimed too so it might be close.
/ Broken fan blade #7
$189 on the Messick’s website or an aftermarket in the $50-100 range.
/ Broken fan blade
I found the part for a MX5200 HST. Monday I will call dealer to see if that will fit my MX5400 HST.
  • MX5200_Cooling_System_Parts.pdf
/ Broken fan blade
Anyone have a workshop manual that would show how to access the coolant fan?
/ Broken fan blade
Took tractor in last Friday. Estimate is $400 to replace fan blade.
Not filing under homeowners insurance unless repairs are greater than $800
/ Broken fan blade #11
Time to replace the dealer.
/ Broken fan blade
They were able to get it done today.
Price is high but the part itself is $190.
/ Broken fan blade #13
Wow. Freak accident. Glad you got it fixed for less than $200.
I had some brush remove the oil dipstick on my Gravely once. Saw it happen and retrieved the dipstick. Turned it to have the "O" top of the dipstick up against the block.
/ Broken fan blade #14
That’s a pretty fair price if it included the fan, tax and labor to install it.
/ Broken fan blade #15
I'm certainly missing something here. Installation looks like 4 bolts. Is there that much sheet metal to move ? And you said there were aftermarket possibilities in the $50 to $100 range... I guess it is impossible to get anything done these days without spending hundreds of dollars.
/ Broken fan blade
Have to remove a few other parts (maybe radiator?). The only Utube video I saw was on a L3301 and it took the guy about 2 hrs.
$400 included parts/labor.
/ Broken fan blade #17
The dealer isn’t going to use the aftermarket fan, they’re going to use the OEM that cost $190. While I’d install it myself $200 doesn’t seem unreasonable to have the dealer do it.
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 KENWORTH T800 (A60736)
2019 KENWORTH T800...
MULTIQUIP LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
