New GC2400 Owner
   / New GC2400 Owner
Thank you blackd for the advice. I am going to look into that since I plain to do some woods work with this tractor. Do you have a recommendation for a manufacturer or a place to buy one?
I picked up the case/ ih hy-tran from southeastern equipment last night. All reviews I read are high and the price was worth it to me. Last question on the trans... Is the screen filter something I just clean or do I replace it like the hydro filter?
   / New GC2400 Owner #22
you talking about the transmission suction filter?
if you have owers manual for gc2400 its page 54 first item
looks like this:
for skid plate call these guys tell them you have GC2400, they say they will make for older GC series. they have small vent holes for air flow (cooling as fan is right there) while the bro-tek ones do not.
I've been meaning to buy but every time I have money something around the house breaks...
edit:fixed missing ilink
   / New GC2400 Owner #24
Forgot to put link in for the sentinel plate
They said need to drill 3 holes in factory skid plate and provide instructions. 150$
   / New GC2400 Owner #25
looks like this:
I found this to be even more interesting: Broken hydraulic filter rescue kit. I wish I had seen this before asking to get the tractor repaired.
   / New GC2400 Owner #27
That is why I put on the skid plate as soon as I read about it here, tractor was not even a month old. I did do it because of reading an thread about the hydro fan replacement, something that I want to avoid at any cost. Rather prevent it ahead of time.
   / New GC2400 Owner
At idle, by tractor has a lot of vibration. Is this normal for these machines? Is there something I can fix to lesson this issue?
   / New GC2400 Owner #29
Yep, seems to be normal. I generally don't run mine at less that 1500 RPM, which is a bit more than idle. Reduces the vibration significantly.
   / New GC2400 Owner #30
wait until you start in -20f weather...first few strokes around 500rpm...oh yeah she vibrates.
mines (2010 GC2400 with 375 hrs on it) not too bad when warmed up (comparable to the 2015 GC1710 I got few hundred hours on, the 2020 GC1723TLB I got 20 or so hours on, and the 2021 GC1725M TLB I got about 10 hours on so far) and sitting at idle around 1050 rpm, most vibration there from dl100 loader pins. lift up a touch it goes away.
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2018 INTERNATIONAL...
80in HD Tooth Bucket with Side Cutters (A52128)
80in HD Tooth...
2013 Chevrolet Caprice (A50324)
2013 Chevrolet...
NEVER USED FECON 74in Deck Mulcher FDM74 (A52128)
NEVER USED FECON...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
