Grader Scraper
   / Grader Scraper #11
   / Grader Scraper
   / Grader Scraper #15
Larger means wider as well, which will distribute that weight over a greater area. Besides if weight becomes an issue, I have a couple of 100lb. wheel weights that will fix that problem.
I pull a 5' BB with my JD2210. If doing heavy work I'll add two 110lb suitcase weights to the front. I always want the tool to exceed the width of the tractor pulling it if possible.
   / Grader Scraper
Well, I got it off the truck today.
   / Grader Scraper #17
Nice. Will serve you well!!!!
   / Grader Scraper #18
Good find. (y)
   / Grader Scraper
I finally got to use the new Landpride grader scraper. As you can see old man winter kicked the **** out of my driveway. I think it worked way better then the box blade I have for my Deere.
   / Grader Scraper #20
Nice work!!!! Patience and repetition are your friends!!! Thanks for posting the pics.
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
BAT WING SHREDDER (A58214)
BAT WING SHREDDER...
2015 Nissan Pathfinder 4WD SUV (A56859)
2015 Nissan...
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
2014 Freightliner MT55 Step Van (A56858)
2014 Freightliner...
