Foton 254
/ Foton 254 #1
Big Randy
2012 Foton 254
I’m having trouble finding the lever to disengage the PTO. It’s a 2012 model 4x4. The seller bought it new and wasn’t able to locate the manual. Any help would be greatly appreciated.
/ Foton 254 #2
It is probably down low on the right side of the transmission near your right foot. It moves up and down. Down is engaged, up is free. It does not move very far. I don't have pictured to post but can take one if needed.
Also you might look at the online parts catalog for your tractor. You can find these at dealers like Affordable Tractor or Circle G Tractor.
/ Foton 254 #3
Should have a label on it 540/1000 or 720 depending . Middle being neutral or disengaged. Some may have a separate lever for disengaging .
/ Foton 254 #4
Here's a thread someone just did one
/ Foton 254
Oops sorry wrong thread
That’s quite alright. I haven’t found where it disengages yet. I’ll try to look again today. Thanks for everyone’s help.
/ Foton 254 #7
For some reason there aren't any diagrams for the Foton on the Circle G site. However taking a leap of faith that it is the same as the Jinma 254 you can find diagrams for that. If you look under Drive Gearbox there are two images. The main engage lever is shown on the first image and the two speed selector is on the second image.
At one time the two speed (540/1000 RPM) was an option so your tractor may not have that lever if it only has a single speed PTO. The speed select lever does have a neutral position but that does NOT disengage the main PTO shaft that is driven by the clutch (2nd stage if you have that).
IF the clutch is out of adjustment you may have trouble getting the PTO to engage without grinding the gears a little but you should always be able to dis-engage just by pulling on the lever.
I'll try to get some photos of my Jinma 284 and get them posted later today.
/ Foton 254
Thank you very much sir! My tractor does have 540/1000 selector.
/ Foton 254 #9
Ha! There was a picture in my files that actually shows a better view than taking a new one.
The red circle is the main PTO engage lever and the yellow circle is the speed select lever
/ Foton 254
I have a rod sticking up through the floorboard on the right side. I thought it was differential but I may be mistaken. I’ll check it out in the morning. Thank you very much sir!
/ Foton 254 #11
On my 2006 504 it's a chrome lever on the forward side of the left rear fender well.
In other words, left of the driver. Push more or less up and down. Low is 540 rpm. Can't remember if it's labeled 540/1000 but I think it is.
Hard to find diagrams for these things. I have a bunch but you have to read between the lines for everything.
My experience so far, there's not much similar to a Jinma. I had a wiring problem I was chasing and someone
provided me a jinma diagram but not the same at all.
/ Foton 254 #12
I have seen a t-handle rod sticking up on both right and left side floor but it was in an 85hp.
Mine has an unlabeled t-handle at my left heel which I eventually found out was to engage 4wd.
A small pedal at my right heels is for temporary diff lock.
Hope I'm helping and not just yammering.
/ Foton 254
My 254 had a lever on left of seat. It is the 540/1000 selector. I can’t find anything that shuts the pto off. My neighbor says it may be live, idk.
/ Foton 254 #14
By can't shut it off do you men the pto shaft turns when there are no implements attached?
The stub shaft always turns on mine and I never worried about it, but I suspect if I had a safe way to hold it, while disengaged,
I could stop it from turning.
I've never got out and checked with an implement on, but the few inches of drive chain I can see on my snow blower stops with
the pto off, but again, the stub shaft turns with no implement.
/ Foton 254
It does turn with no implement. Maybe this is the way it’s supposed to be. Thank you sir
/ Foton 254 #16
My theory is there is just enough drag through the clutch/gears that it turns a bit.
I guess one of us could jam a stick beside the pto output shaft and see if anything still turns??
2011 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2011 Caterpillar...
Small Cow (A64557)
Small Cow (A64557)
10000LBS Two Post Auto Lift (A64194)
10000LBS Two Post...
2007 Ford E-250 Cargo Van (A64556)
2007 Ford E-250...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
TRUCK RAMP (A64556)
TRUCK RAMP (A64556)
