Need cattle advice
/ Need cattle advice #1
rbstern
GA
LS MT225E, Yanmar 2210
We're teaming up with a neighbor who has some empty pasture, to buy four bulls. The bulls are from a local farmer, and are between 6 and 9 months old. Three are red angus/charolais, and one is a long horn. Our only goal is raising them for meat/food security. We've purchased half cows, processed, from another local cattle farmer in recent years, and have had good experience. So I guess we're taking this to the next level.
Key questions: Should we steer the bulls? How important is grain finished vs. grass finished?
Anything you care to chip in from experience, I will happily read.
/ Need cattle advice #2
Castrate the bulls to make them more docile. Grass finish takes longer, cheaper if you have pasture and adds favor to beef
cattle like shelter from sun and weather , access to fresh water
frequently Check on cattle to catch problems before they get big
/ Need cattle advice #3
Grain grass fed seems to be a preference thing. Pretty well everything is grass fed here, not much of a grain area. I do cow/calf and never leave bulls intact unless I want a breeder.
I'd want steers for beef, 4 bulls are going to be aggressive. Horned one will likely know how to use them as well. I have polled herd.
/ Need cattle advice #4
Polled steer
Low stress
Grain finish to marble the meat
/ Need cattle advice #5
if they drop CHOP em
I have mentioned my bull experience in a couple of other threads. I do not think I will have an intact bull beyond about 6 months old on the farm again.
/ Need cattle advice #6
I recommend Storey's Guide to Raising Beef Cattle as a starter book.
I would definitely castrate them. ASAP. The longer they stay on, the more bullish they will become. If the testicles are of any size, the bulls will also need tetanus shots, and prudent in any case. For older bulls, I recommend a "California castration bander". Unless you and your buddies are really good with ropes and horses, you will need a cattle squeeze. If you don't have one, I would ask the neighbor who is selling them to castrate them for you.
We intentionally have only polled cattle, so I am personally unfamiliar with the damage that a Texas long horn can inflict, but I would be very careful handling him, and I wouldn't crowd him with the other bulls, ever.
We do 100% grass fed, but raise belted galloways that marble well on grass. If you keep them on grass, do harvest them when the grass is still green and lush for best flavor, and try for longer hanging of the carcass that will produce more tender beef. If you do finish on grain, 60-90 days is pretty common, but remember what you feed will affect the flavor.
Have fun!
All the best,
Peter
/ Need cattle advice #7
I have family nearby. Cattle ranchers. My property borders theirs. They keep a few cows/steers for their own consumption. Almost entirely grass fed. And it isn't good. They don't even like it. When we would have a cookout and they would bring their own burgers their now grown kids would watch the grill and try to get our grocery store burgers.
We recently bought half a cow. Grain finished. So far it has had very good flavor. Not high end tender but tender enough.
I have never understood the grass fed craze. In my mind that is the oldest marketing tool in the book: try to make folks believe the opposite of what is true about your product. It is probably more healthy for you.....and that's why it tastes bad.
/ Need cattle advice #9
I've killed them in the pasture and butchered them in their own hide spread out on the ground. We have a banding tool for the castration process. Used to do them just a few days old. We have a 100 Or So longhorns cows and black Angus bulls.at one pasture.
Just grass feed and then put them in a smaller pen and grain feed for a couple or few weeks. Exactly how my papaw did it.
One main reason the home processed meat tastes not as good is aging of the meat. Beef should be hung for 10 days at least. Or, it will taste like the deer you shot this morning. I hang my deer, it tastes good. I think the main difference is aging or hanging. I just had some fresh grass fed and it was good.
When you render it down, and you will if you use all of it. Fat from grain fed is clear. Fat from grass fed is golden. So I've rendered fat down from store bought. It was golden so that tells me grass fed and finished on grain. Hanging or aging is the difference. You can do It in ice chests. Just keep ice on it and change the water when it turns red. Took 25 ice chests last time but was a large cow. When you age it and grind into hamburger it will be pink, it will be bloody slop otherwise. I always cube the meat I'm gonna grind and chill in the freezer until it's stiff. Grinds like a dream.
/ Need cattle advice #10
The neighbors beef always tastes better.
/ Need cattle advice #11
Castrate the 4 yearlings and give them a tetanus shot if you band instead of cut, if you cut check the farmers almanac and ideally you would like for the signs to be in the knees to the feet, they will bleed less and recover quicker, let them free graze in the pasture and 75-90 days prior to butchering start feeding them grain cow feed or steer finisher, they will be ready to butcher in 75-90 days, hanging time is personal preference but I hang mine for 14 days.
/ Need cattle advice #12
We do this every few years when the freezer gets low. Buy steers not bulls or castrate them. I buy 500# calves, feed hay for six months, then beef finisher grain mix with free feed hay for three months. This usually gets them in the 1100-1200 pound range. Then it’s off to the packers.
/ Need cattle advice #13
I think that @ROUSTABOUT is right on the money about carcass aging being important for flavor. We try for 21 days hanging, and end up with flavorful beef. It is always a bit of an arm wrestle with our butcher as he doesn't like to have it in his cooler that long as it means he can't get another carcass in.
I would also say that if your steers don't fatten up on your pasture, they will be lacking in flavor, so let them get fat before you harvest. Lean meat not hung for very long is the worst. For burgers, much as my wife hates it, I think that a base of 20% fat is the way to go for flavor.
I have tasted good and bad beef over the years, some grain, some grass fed. I do think GIGO applies; great pasture makes for great flavor. I hear that there are some lucky dairy cows near Hershey, PA that produce an outstanding milk. 😋
All the best,
Peter
/ Need cattle advice #14
Finish ‘em on molasses!!!! (y)
/ Need cattle advice #15
Yum. Ever tried it? I hear stories about hogs fattened on all sorts of interesting things, but I haven't ever been lucky enough to taste it. I have had beef that had been fattened on odd items and for the most part the flavor was very delicate, if at all. I had some once that had some sort of seaweed/fish meal feed, and that did taste like it was cooked in sardine oil. Yuck, and I like sardines.
We drive by a herd of cattle periodically that are near a "baby" carrot and juice factory and all of the dross, skins, pulp gets laid out in a bright orange strip in a field for the cows, and they clearly love it. I have often wondered how orange the resulting milk and beef is.
All the best,
Peter
/ Need cattle advice #16
I've heard of pigs getting fed waste from lobster treatment plants. They say it's not very palatable.
/ Need cattle advice #17
Once about 15 years ago a farmer friend gave us two T-bone steaks that he raised.
That was the best piece of meat I have ever eaten.
I have no idea how it was raised or butchered.
/ Need cattle advice #18
Yup as above, cut em as early as feasible. Free range with a nice does of 12% everyday. If you have a vet work em with ya, tetanus/worm/antibiotic when you cut em. Get em to 1,000 lbs and enjoy.
Best.
ed
/ Need cattle advice #19
In my meat cutting class years ago one of the labs was a taste test. Everybody agreed on the grain finished beef except for one classmate. He had been raised on a farm and preferred the grass fed meat.
/ Need cattle advice #20
For the castration at 9 months they are already pretty old to not casted them, my Dad would get them in early spring at 3 to 4 months and letting them graze during the summer wile still giving them some grain at night and morning, their diet consisted of 3/4 grass 1/4 grain, then the last three week he would kept them inside and increase their grain portions and process them at 11 to 12 month old so he didn't castrate them and didn't have too much problems ... higher grass diet make the meet more red (higher Iron content) and a more beefy taste ( gamey taste )... obviously more grain you give them the more expensive it is to produce your meant and the animal growth taper off as it get older so you get less bang for your buck sorta speak, there is a sweet spot there ...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
Paladin 12in Bucket w/ Teeth Excavator Attachment (A64194)
Paladin 12in...
2009 PTSN TRAILER (A65643)
2009 PTSN TRAILER...
2016 Ford Flex SUV (A64557)
2016 Ford Flex SUV...
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
2013 FREIGHTLINER CASCADIA (A65643)
2013 FREIGHTLINER...
