No start troubles
/ No start troubles #1
General Lee
Mid-Atlantic
Kubota L4400, B2401
I have a 2010 L4400. Intermittently it wont start, most times right after using it and shutting down, then a short time later it wont start. I have to jump the starter and starter solenoid and it fires right up. Doesn't appear to be the Hydro pedal not finding center. I'm thinking maybe the safety switch under the seat, but I don't know. Anyway to trouble shoot some things to narrow the issue down?
/ No start troubles #2
Your problem sounds intermittent - the worst kind. It also sounds as thought one of your safety switches is not making contact part of the time so yes, it could be the seat switch. While you're looking at switches look at how they're mounted and the stability of the device being checked. My Kubota early on had issues with the seat safety switch. The seat pivots forward on a rod. One end of the rod had slipped out of its mount allowing the seat to shift. This affected seat position slightly and the associated switch decided I wasn't in the seat. In short, don't assume a switch without checking out what makes it work.
  • Good Post
Reactions: JWR
/ No start troubles #3
Smaller subcompact tractors (of several brands) have a problem where attempted starts result in clicking but no cranking. Most of those are lack of a full 12v to the solenoid with all sorts of remedial actions you can imagine.[There are several threads on this for Kubota and John Deere, etc.] I have that disease with my BX2200 which seems to happen only if I am in a hurry and need it to start immediately.
Does your L4400 have high hours or sat outside a lot? I have a B2150 (bought used with suspected poor care) that sometimes will not crank even with a known good battery, etc. No clicking, no cranking. That one always responds to rapping it soundly on the starter body with a socket extension rod driven by a gentle hammer. Then starts right up. There are several threads speculating about what that starter problem is.
Yours sounds a little more like the "low voltage to the solenoid" variety though maybe one of the safety interlocks acting up. Suggest using a voltmeter at the small wire to the solenoid (might have to nick the insulation to get on it.) When you turn the key to start if you get zero volts then you have an interlock problem in one of several places like the seat or the transmission lever or the PTO, etc. If you get voltage but not quite full battery voltage you have the "voltage drop to the solenoid" disease more common on the smaller machines.
/ No start troubles
Only 150 hours, but it does sit outside a lot. Original battery too, so maybe it is a voltage problem. When it decides not to start, glow plugs click on and all other electrical systems seem to work, keep turning the key to start and nothing.......no clicking no trying to start, just dead.
/ No start troubles #5
Couple things to try (besides using the voltmeter as I previously mentioned.) I find that if I connect a battery charger that raises the voltage headed for the solenoid and causes my BX2200 to crank when it otherwise has decided to sit there and click. Since yours is not even clicking I'd try the shaft of metal tapped with a hammer on to the starter motor and then turn the key and see if it starts. However, since you said it starts right up when jumped you probably just need a new battery.
/ No start troubles #6
Go at things with a multimeter. The only other option is to just start replacing or bypassing parts.
The 1 easy exception would be to remove, clean, inspect & reattach grounds & battery cables. Those aren't super likely to be that erratic of a problem, but are often a problem. After an hour or 2 with a multimeter ripping the whole dash appart on a 2-3 year old tractor the second I started removing a clean ground cable bolt my hazards started working. I immediately flashed back to tons of TBN posts saying to check the grounds first. Should have done that rather than checking & chasing wierd voltage readings under the dash.
/ No start troubles
It starts right up by jumping the starter solenoid, taking a pig tail to the positive bolt on the starter and the other end to the solenoid connection. I haven't simply tried jump starting from the battery. Worth a shot though
  • Good Post
Reactions: JWR
/ No start troubles #8
I cannot find the older posts centering around "low voltage to the solenoid" failures to start using the BX2200 and similar Kubota subcompacts. I know that in previous chases about the problem I found that the same disease exists with small John Deere machines and others. The basic problem is that so many safety interlocks exist and each contributes some amount of voltage drop before the battery voltage reaches the solenoid. To me all the manufacturers should EITHER provide relays to bypass all that crap as std equipment OR start using 10v triggered solenoids instead of 12v ones. That design change would save a lot of grief and expense to hundreds of thousands of people for sure. I do know that Deere sells a relay kit to cure this problem which people said would work ok on the Kubota's too.
What triggered this posting NOW is that I hauled my BX2200 to the tractor hospital for a split/worn through hydraulic line to the loader and the tech told me they (closest Kubota dealer here in So MD) now sell and install what they call "hard start kits." These kits are electrically the same as Deere -- uses an extra rely to put full battery voltage on the solenoid when trying to start by bypassing all the safety interconnects. The tech also mentioned that each interconnect is considered "in spec" if half a volt is dropped across it ! That means for 4 safety interconnects a total of 2 volts drop end to end is in spec. No wonder the solenoid is only sometimes happy !
/ No start troubles #9
I would also caution you troubleshooters that a digital meter is not always the best choice to check for voltage problems. A test LIGHT is much better in these situations. (An old tail light bulb and socket is my go-to test light)
The problem with the digital meter is that it is so sensitive it will read a full 12-13 volts at some test location, but when load is applied, the voltage that arrived is less than that. If you use digital, be sure you read the meter while under load.
The test light bulb requires some current flow to illuminate, whereas the digital meter will show full voltage, for example, thru a flashlight bulb filament. Or a wire much smaller than a hair.
Dont get me wrong, the digital meter is an EXCELLANT diagnostic tool--if you know it's limitations.
/ No start troubles #10
OK, BX2200 is back from the shop. I may jinx myself but I doubt it: The new "hard start kit" is listed on the dealer invoice as an "AM107421 Quickstart" costing me $89. I just searched the AM107421 Quickstart using Google and found out they are on Amazon for $30. So I was "had" on the parts price but I will say the result is outstanding so far. Starts up quicker/more immediate response and SO FAR never fails to crank when asked to do so. Well worth it even at the rip off parts price.
Sick that the manufacturers don't include this feature on all of them from the factory (not just BX2200 but the small Deeres and many others.
Who would not pay the $30 extra in machine price (probably 1/10 of that if put on at the factory) if they knew it was going to prevent the countless times of being hung trying to start the thing !!!
/ No start troubles #11
I wired up my own relay on my ZD mowers several years ago. I had the miscellaneous connectors and wire, so the only expense were the relays and time. Both mowers worked great afterwards, but I still seemed to need to replace the solenoid after 500-600 hours on the machines (about every two years).
I haven't added the relay to my current ZD1211 with 700 hours on the clock.
I agree that it's definitely a worthwhile modification even at the marked up price.
/ No start troubles
Bumping this thread as I have not found a solution. Only now instead of the problem previously being intermittent, it now simply does nothing when the key is turned all the way to the right to start. Turning the key left will engage the glow plugs and I get the standard click sound when that happens. Go to turn the right to start....Nothing. So it seems the ignition switch works for the glow plugs but not to start the tractor. The tractor will fire right up though by jumping the starter through the starter solenoid with a pigtail. If I can jump start the tractor through the starter, could it really be a battery issue? I'm thinking No.
/ No start troubles #13
Yeah, if it starts by jumping the solenoid, it's not a battery or battery cable or battery connection problem. It's a failure of the system to supply an adequate voltage signal to the solenoid.
Somewhere back in this thread, someone suggested to check for full voltage at the SOLENOID terminal when the key is activated to the "start" position. I cautioned everyone to be aware of the shortcomings of a digital meter. I prefer a test light in this situation.
So did you check what kind of signal you are getting at the solenoid?
If you want to take a couple WAGs at things, hook your test light ( in any order but easiest switch first) to one, then the other terminal of the HST safety switch, the PTO safety switch and the seat safety switch. When you twist the key, both terminals should be hot.
Or you can unplug the wires from the safety switches and connect them. I use a piece of a large paper clip. Cut it so you have a U-shaped piece of wire, and jam each leg into the wires you unplugged. Don't hang onto it, in case there is a short. The paper clip can turn red hot and you will have a perfect U-shaped brand on your thumb and finger.
Again, did you have power at the solenoid when you tested that location?
There are more troubleshooting strategies (a bit more complicated) I can explain if you can't get this figured out.
Good Luck!
/ No start troubles #14
No, of course not. I told you in post #3 what the problem is with near certainty.
/ No start troubles
Good Luck!
I simply am not good at electrical diagnostics. Unless I had an how to video on which connections to poke around with and how to test them......I'm lost. Like you mentioned, I'd be the one burning a U shape on my fingers with the paper clip. Only reason I know how to jump the starter, is because I was shown how. "Put this alligator clip here, and the other end here" and whola. If I had a known problem part to replace, I can do that. But poking around with multimeters and test lights.......Don't know what I'm doing.
/ No start troubles #16
If you can, have a trailer or can borrow or readily have someone do it, take it to a [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] dealer and ask them to install a "hard start kit." Describe to them your experience. Mine cost $89 at a dealer including installation and Amazon sells the kits for 1/3 of that but it takes some savvy to do the install. Doing it this way (haul to dealer) will also flush out the (very unlikely) case where something else is wrong.
/ No start troubles #17
I support the idea of temporarily bypassing some of those safety switches, especially all of them at once, like the "hard start" thing does. However, there are several easy, no-cost tests you cannperform first, if one knows how or can be coached thru the process.
To test if the solenoid is being energized, hook one wire of your tester (voltmeter or test light) to a good ground. Touch the other end to the big starter terminal right there on the starter. This is a "test the tester first" strategy I follow. If the meter or light reacts, then un hook that lead and hook it to the small "energizer" terminal on the starter solenoid. Then hit the key. The meter or light should indicate the presence of power at the energizer terminal.
If power is present when you twist the key, you can pretty much assume that all the safety switches and the key switch itself is OK.
If no power is present when you twist the key, then we will go further into some tests you can do easily, and probably learn some basics to help yourself out next time.
/ No start troubles #18
The "hard start kit" installed by [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] dealers is not a temporary bypass of anything. It is permanent. Same function sold by John Deere.
/ No start troubles #19
I somehow assumed that it was a system that the operator could activate as needed. Don't know how I arrived at that conclusion.
If I were to develop such a system, it might have a master switch that could be placed in BYPASS or switched (locked?) into PROTECTED. Then one could choose when to bypass and when to assure protection, depending on circumstances.
/ No start troubles #20
Let me clarify: These kits do not bypass the safety interlocks in any safety sense -- FOR EXAMPLE if the tractor won't start because your PTO is engaged before the kit, it still will not after the kit is installed. That is because the TRIGGER signal to the factory solenoid is still used to trigger the new "bypass relay." It just takes way less oomph (voltage) to trigger the new bypass relay in the kit than it takes to trigger the original solenoid which after all is just a relay itself. That said, many hobby-minded tinkerers do all sorts of things ! Such as one attractive innovator in another TBN thread a few years back just took into account that no one really uses the tractor key as a secretive private special key (they are all the same) and so he just installed a big old START button that triggers the solenoid bypassing everything including all the safety stuff. In his innovation you hold the key in the start position and then hit the START button if the thing did not start as it should anyway. Many variations.
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
KBH Tender Trailer (A61307)
KBH Tender Trailer...
KAESER COMPRESSOR (A60736)
KAESER COMPRESSOR...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2013 Dodge Challenger Sedan (A60352)
2013 Dodge...
