If there are aliens, what will they look like?
   / If there are aliens, what will they look like? #601
Is this where the gravity is kept?
   / If there are aliens, what will they look like? #603
According to this video, there are ‘men at work’ in the land down under. There is thunder and also a strange food they make sandwiches out of.
When the song came out none of us knew what "Vegemite" was, and Al had yet to invent the internet. A friend told me a "Vegemite sandwich" was what we call a "Knuckle sandwich."
Obviously he hadn't watched the video.
   / If there are aliens, what will they look like? #605
That's what happens when a nation is "on the edge"
I'm a Marmite* fellow myself. Oh! So good on toasted and buttered wheat bread. ;-)
I'm to understand it is nutritious, and a product of beer making!
   / If there are aliens, what will they look like? #606
Toasty warm in winter. ;)
From what I've been told, and if its true, I'll have to simmer for a while myself.
Not to worry, You will be among friends! ;-)
   / If there are aliens, what will they look like? #609
I hope "The Land Down Under" is something like Alcatraz, where they keep the crazies.
   / If there are aliens, what will they look like? #610
Splain this one Skippy...
Instead of cut and pasting answers that you might not understand a little common sense goes a long way.
The explanation the fellow gives is assuming nothing else is moving in the universe.
When in fact, in the globe earth universe, you have the earth moving around the sun at 66,000 mph, the sun hurtling through the solar system at 666,000 mph, the solar system expanding outward at even more ludicrous speeds all the while Polaris is 323 light years (and moving further away). A light year, by the way, is given to be 5,900,000,000,000 miles in distance. So if you can wrap your mind around 323 of these units, good luck. :ROFLMAO:
Polaris being the focal point while all the "stars" are rotating around the fixed point ONLY works with a stationary earth.
Beam me up Scotty!
   / If there are aliens, what will they look like? #612
With all these relative motions, and I'm sure there are some we are yet to become aware of, isn't it a wonder.
Considering as much in the light of Einstein's works with time and motion etc. it is amazing that time passes at all.
Perhaps distance is not so important to our extraterrestial friends in another system. "only a couple of starjerks over".
Perhaps no time at all. Only through that door. That one! The door of perception.
"All things come to the man who waits".
   / If there are aliens, what will they look like? #614
   / If there are aliens, what will they look like? #615
We know by observation that lighter things float and heavier things fall or sink.
Okay, we have some common ground, we both observe the same thing. However when posed with a direct question to explain your world view's driving mechanism for the "fall" vector, you instead explain what you observe and do not offer further explanation. I, on the other hand, say that gravity in conjunction with differential density is what causes the stratification and the bolt to "fall".
You may have missed my post earlier.
Post 273
Can you through logic or mathematics explain why accelerometers react the way they do to acceleration and as you would put it "density". I say gravity.
Gravity is not a constant. The variations are consistent and mathematically supportable in a way that density would fall apart. Gravity varies with:
latitude - the Earth's equatorial bulge means that surface gravity is lessened as you mover further from the equator.
Centripetal force - counteracts gravity differently for differing place on Earth at differing radius from the center.
Elevation - the higher the elevation, the farther from the Earth's center, the lower is gravity.
Local anomalies - due to the mass density variation of landforms. Rock vs. ocean, etc.
When I ship an instrument from Connecticut to Kennedy Space Center. I have to make corrections in the gravity factor in order for the instrument to pass its self diagnostics tests. These instruments happen to be center of gravity instruments. My occupation, my company, my customers, are not frauds. If what I did for a living was a fraud, if gravity were a fraud, many of our country's most sophisticated weapon systems would simply not work. They do work. See Ukraine. Hundreds of thousands of people around the world would have to be "in" on the scam. Puck-ass college students would have figured it out years ago and the gig would be up.
   / If there are aliens, what will they look like? #617
Now here is an "alien" idea to consider.
IF a very deep, straight hole could be put down to the " Center of the earth", and through to the other side
What would happen to an object "tossed down the hole"?
yo-yo? resting where?
please disregard any logic of intense heat, molten cores and other such nonsense . It's a cased hole, land to land for sake of consideration ;-) ;-)
   / If there are aliens, what will they look like? #618
Along the same lines, I was wondering,,, if this whole gravity thing is real,,, let say we threw a person in that hole CalG was so nice to dig for us. What would they weigh when they came to the center of the earth? Perhaps the earth's gravity pulling out on them in each direction would make them have a negative weight causing them to explode outward? I am not sure.
Thinking of those kind of things kind of makes me kind of like the flat earth theory where one can just make up physics as they go. In that case one would fall all the way down through earth.. Down to the next flat earth that is directly below us. People down there are far more intelligent than we are, they don't pass gas, and they have much nicer tractors than we do. It is great not to be bound by logic.
   / If there are aliens, what will they look like? #619
You guys should follow the Nooasphere threads on the internet. A friend of mine is making these, and I don't agree with many of it, but it might make many people happy. Beginning happy is better than the alternatives. :)
   / If there are aliens, what will they look like? #620
From watching that, my first impression is that those Nooashere guys are well-intended wackos who are combining science with mysticism.
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
2023 RTVXG-850 SideKick (A56438)
2023 RTVXG-850...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-350...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
