If there are aliens, what will they look like?
   / If there are aliens, what will they look like? #601
Is this where the gravity is kept?
   / If there are aliens, what will they look like? #603
According to this video, there are ‘men at work’ in the land down under. There is thunder and also a strange food they make sandwiches out of.
When the song came out none of us knew what "Vegemite" was, and Al had yet to invent the internet. A friend told me a "Vegemite sandwich" was what we call a "Knuckle sandwich."
Obviously he hadn't watched the video.
   / If there are aliens, what will they look like? #605
That's what happens when a nation is "on the edge"
I'm a Marmite* fellow myself. Oh! So good on toasted and buttered wheat bread. ;-)
I'm to understand it is nutritious, and a product of beer making!
   / If there are aliens, what will they look like? #606
Toasty warm in winter. ;)
From what I've been told, and if its true, I'll have to simmer for a while myself.
Not to worry, You will be among friends! ;-)
   / If there are aliens, what will they look like? #609
I hope "The Land Down Under" is something like Alcatraz, where they keep the crazies.
   / If there are aliens, what will they look like? #610
Splain this one Skippy...
Instead of cut and pasting answers that you might not understand a little common sense goes a long way.
The explanation the fellow gives is assuming nothing else is moving in the universe.
When in fact, in the globe earth universe, you have the earth moving around the sun at 66,000 mph, the sun hurtling through the solar system at 666,000 mph, the solar system expanding outward at even more ludicrous speeds all the while Polaris is 323 light years (and moving further away). A light year, by the way, is given to be 5,900,000,000,000 miles in distance. So if you can wrap your mind around 323 of these units, good luck. :ROFLMAO:
Polaris being the focal point while all the "stars" are rotating around the fixed point ONLY works with a stationary earth.
Beam me up Scotty!
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
1453 (A57192)
1453 (A57192)
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
2020 Kinze 3505 High Speed 6/11 Planter (A56438)
2020 Kinze 3505...
207282 (A52708)
207282 (A52708)
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
