Cool Or Creepy Things Found In The Bush Or On Your Property
/ Cool Or Creepy Things Found In The Bush Or On Your Property #41
All I ever seem to find in the woods is old fence lines and bits or small spools of barbed wire.
Grrrrr. 😡
I bought an inexpensive metal detector once to play with. It just goes nuts around the place. Now I understand why treasure hunters like beaches, so much easier to dig in sand. 🙄
/ Cool Or Creepy Things Found In The Bush Or On Your Property #42
Grrrrr. 😡
I bought an inexpensive metal detector once...
I've had many of those over the years, but never an inexpensive one. Usually they're made by Husqvarna but I currently own three Echos. It's amazing how quickly they can find barbed wire... especially after putting on a new chain. ;) :eek:
/ Cool Or Creepy Things Found In The Bush Or On Your Property #43
Here's the one I found with the tiller in our garden.
/ Cool Or Creepy Things Found In The Bush Or On Your Property #45
/ Cool Or Creepy Things Found In The Bush Or On Your Property #46
Yuck! That's appears to be a 1000 gallon poly septic tank.
Maybe new construction up stream, recently buried, and never used?
Patrick
Our largest ever flood down along the creek left this big tank down below. I probably should have bought some clamp on forks to bring it up the hill. Instead, I just used a sawsall and cut it up.
Had a 120v pump inside.
Tried for find the owner. No luck.
/ Cool Or Creepy Things Found In The Bush Or On Your Property #48
I bought a metal detector to find those @#$% nuts/bolts that fall onto my lawn and get lost in the grass. Works well right around my outbuildings.
If I go out where the original homesteader had his buildings - WoW!!! Nail & spikes of all sizes, small metal cans, nuts & bolts, old dry cell batteries, bits and chunks of metal - you name it. It would be a never ending task to find one specific item if lost over there.
/ Cool Or Creepy Things Found In The Bush Or On Your Property #49
Patrick
Had the little bit of liquid in it sampled. It was just water.
/ Cool Or Creepy Things Found In The Bush Or On Your Property #50
Grrrrr. 😡
Oh yeah, a thousand pieces of barbed wire and rusty mangled oil cans. Sadly, Curly’s gold was nowhere to be seen.
/ Cool Or Creepy Things Found In The Bush Or On Your Property #52
Used to be an old car in the woods on our farm. Then dad put his old truck in the woods. Several years back when steel prices were high, someone paid him for the scrap.
/ Cool Or Creepy Things Found In The Bush Or On Your Property #53
I don’t understand people letting junk cars sit until the tire rot when someone will come drag it away *and* give you some cash.
/ Cool Or Creepy Things Found In The Bush Or On Your Property #54
Pretty much any house of a certain age here in New England has its own private dump on the property. Maybe someone buried it, other times it's just disappeared under rotted leaves but most of 'em have it. Both my previous and current houses do.
Never found anything valuable...lots of rusty metal, broken glass, rotted shoes, etc. I did find an early-50s Chevy grille ornament/logo a couple years ago while excavating to rebuild a stone wall, closest thing to anything cool I ever came across.
I don't get it either but it happened a lot, even into the 70s. Maybe attitudes held over from the depression that there might be something on it that might come in handy someday.
/ Cool Or Creepy Things Found In The Bush Or On Your Property #55
A lot of people, including myself, get the thought that "I'll fix that up some day." We don't.
It rots.
It goes to the scrapper eventually, but rarely gets fixed up.
/ Cool Or Creepy Things Found In The Bush Or On Your Property #56
The old car on our property was in the woods in the 60s, so not sure what year it was. At least from 40s, as dad bought the farm in late 40s
/ Cool Or Creepy Things Found In The Bush Or On Your Property #57
Kind of cool. Almost every year I see a small metallic green snake out on my lawn. It's about a foot long, metallic OD green scales. Finally check on it. It's a Rubber Boa. This is definitely larger than the one I see in my yard. They are not poisonous and move very slowly.
/ Cool Or Creepy Things Found In The Bush Or On Your Property #59
Neither had I - JDZ735M. The only Boa I'd ever heard of was a Boa constrictor. And the really slow part - I thought is was some sort of act. This photo does not show - but the tail is blunt, like a cigar. This little fellow eats mice, voles and shrews.
Considered to be one of the most friendly snakes. I know the naturalist at Turnbull Nat Wildlife Refuge was very excited when I called them. She immediately identified the snake after I gave them a description. They wanted me to get a picture. Like I carry my camera everywhere with me. Next time - I'll get a picture.
/ Cool Or Creepy Things Found In The Bush Or On Your Property #60
Carrying a camera is a sure-fire way to never see anything interesting.
Leaving it at home is a sure-fire way to see something unique which you will never see again.
2025 40in Tilt Bucket Mini Excavator Attachment (A61572)
2025 40in Tilt...
APPROX (12) 8" & 10" I BEAM UP TO 12' (A64280)
APPROX (12) 8" &...
2011 CATERPILLAR TH337AG TELESCOPIC LOADER (A64279)
2011 CATERPILLAR...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
