Land Plane
/ Land Plane #1
Red Horse
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
Anyone have experience with land planes? Specifically the ABI 7'. I from time to time take care of a couple of gravel common driveways that are basically gravel or graded base (3/4 bluestone/stone dust). Usually I use my Land Pride Power rake-old school model with 3/4" wear bars on the roller, not "nubs" like are the only thing available on the new models. I'm thinking though a land plane is much quicker in particular if done on a frequent basis.
Opinions?
/ Land Plane #2
I use mine quite often. It's one I built. Can't beat it for leveling drives, etc.
/ Land Plane #3
Best tool for gravel driveway maintenance. Can easily pay for itself in maintenance time, road durability and gravel cost.
Long sides and angled blades work best.
/ Land Plane #4
My home built plane is six ft wide by six long, weighs in at just over 900 lbs. Four passes on the half mile drive gives great results.
/ Land Plane #5
Nice job. I’d hate to price the steel to make that today though.
/ Land Plane #6
I use one at work and like it real well. Little wet on this video, I've broken two ripper tips so far. I haven't tried it yet this year with the new hydraulic top link so I'm thinking I'll like it even better.
LPGS try out
/ Land Plane #7
Landplanes are GREAT ,, BUT,, there is one MAJOR problem with them.
I re-did my driveway in 2018, and other than moving snow a couple times,,
there has been no other gravel moved in 4 years.
If you have the landplane, it is difficult to see it parked in the weeds.
The LESS you move gravel on your driveway, the better.
That landplane is a MAJOR TEMPTATION to regrade, even when the driveway is fine.
/ Land Plane #8
I have a 150 foot section on my mile long gravel driveway that needs regrading - every year. It's a spot where a large field drains down onto. This year, I've promised myself, I'm going to ditch that side of the driveway and drain all the water away from the driveway.
I have an seven foot wide Land Pride LPGS. First I use my rear blade and scrape the ditches back up onto the road surface. Then with the LPGS. I end up with the driving surface as smooth as a babies behind.
/ Land Plane #9
You have the absolute right idea and where I’m missing the mark - getting the gravel back up and onto the road. Backblade is my next purchase ;)
/ Land Plane #10
pokey - like all land engagement equipment - WEIGHT is your friend. Get the heaviest rear blade that your tractor can handle and your pocketbook can afford. My rear blade is a 96" Rhino 950 @ 1050 pounds. When I "do" the ditches - it's offset, angled and tilted. It's all manual - hydraulic costs $1250 more and that was five years ago.
When I plow snow it just offset and angled. Five years ago the blade cost $3700. Buy once - cry once.
If I need to do surface grading on the driveway and move material - I add a 400# block of concrete to the blade. Otherwise - it's plenty heavy for snow and ditches without the concrete block.
/ Land Plane #11
Thanks oosik I've perused the Rhino products. I don't think my GL4060 could handle that size blade though? I've bought some implements from GWT as I can drive and pick them up. I bought a Dirt Dog tiller from him and will check on Dirt Dog blades. I'm thinking a 7' would be ok, I've got the 7' land plane.
/ Land Plane #12
Nice build!!!! I've considered building one for several years but have very limited need. I think they are the best tool for driveway routine maintenance.
If you built another one would you do the opposing blade method again?
/ Land Plane #13
I have a heavy eight foot rear blade for two reasons. I have my rear tires set out at their widest( 80" - outside to outside) and blade weight. I offset the blade to the MAX when I clear out my driveway ditches and clear snow off the driveway.
Some here on TBN use the next size bigger( 108") on my size tractor. My Kubota Op Manual says - max is 72". I do some pretty heavy grading with this rear blade. I don't think I would ever need anything bigger than what I have.
I don't feel I need to find what the absolute max is by breaking/damaging equipment.
I don't think I will EVER get good enough with my rear blade to equal what my land plane grading scraper can do.
Unfortunately - each implement ( land plane grading scraper vs rear blade ) is best for specific jobs. The LPGS will smooth a driveway - like a babies butt. Mine has scarifiers - so I can easily get rid of potholes and the like. However - it won't do much else.
A rear blade is a truly multi-use implement. Grade material up out of the ditches - spread it across the driving surface - reverse & drag for a truly smooth surface. But it's not really the implement to repair potholes and the like.
If you get a rear blade - look for one that will offset - angle - tilt.
My LPGS is out in the weeds and between some of my smaller pines. It's "day in the sun" is rapidly approaching.
/ Land Plane #15
Absolutely. No question. There's no other way to build one in my opinion.
/ Land Plane #17
Right now I'm in the process of straightening out my one "mud hole" on my driveway with my LPGS. I hit it a little too soon but I can now drive thru the area without splashing mud everywhere. When it dries out more - one last go at it to make it smooth as a babies butt.
Maybe in my next life - my driveway will have nice gravel - like Xfaxman.
/ Land Plane #18
14 tons of crushed concrete, cheaper than gravel:
/ Land Plane #19
I just finished with the LPGS on the "mud hole". Smooth as a pool table. Tomorrow - pat it down with the Taco Wagon. At 10,100 pounds the tractor is heavier but I like it to harden up smooth - not with all those chevron marks.
You know what - those @#$% weather forecasters say we are getting snow - middle of this coming week. Mayhaps I'm just getting old but this has sure been a long, cold spring.
/ Land Plane #20
I have a cheap China made 5' box blade from our local auto, farm store..
I plan to add bolt on 4x4 angle iron skids and a cross blade behind the box blade to make it somewhat more a land plane like attachment..
It may not be the best, but it surely will be useful and cheaper than 2 individual attachments..
