2017 DK4510 Shifter Linkage Leaking at Transmission
   / 2017 DK4510 Shifter Linkage Leaking at Transmission #1
SSF556
Member
Woodruff, SC
NONE
I have had a small leak for about a year now. Happens to leak when the transmission is hot.
- Does anyone have a part for the seal that surrounds the shifter linkage going into the transmissio?
- Does anyone know where the vent tube is for the transmission? I would like to make sure that is not clogged with a dirt dauber or other debris
- Lastly has anyone experienced this issue? If so do I need to take to the dealer or fix it myself.
Thanks
   / 2017 DK4510 Shifter Linkage Leaking at Transmission #2
Mine leaked around the boot. I slipped a hose clamp down the shaft and worked it onto the boot. With enough socket extensions, I was able to tighten the clamp. Problem solved. It took 6 attempts holding my phone up in the cavity to get this photo!
Mine leaked around the boot. I slipped a hose clamp down the shaft and worked it onto the boot. With enough socket extensions, I was able to tighten the clamp. Problem solved. It took 6 attempts holding my phone up in the cavity to get this photo!View attachment 736227
Awesome! Do you think removing the diesel tank would give me more room to work?
   / 2017 DK4510 Shifter Linkage Leaking at Transmission #4
I did not need to. You can loosen the bottom tank brackets and tip the tank down a couple of inches if needed. I would not recommend removing the fuel lines (and tank) as that requires you to purge the air out of the system after which can be a pain.
   / 2017 DK4510 Shifter Linkage Leaking at Transmission #5
Thanks
Did you get it fixed?
Not yet but it is on the list of things to do before I start cutting grass this spring.
Thanks again for the heads up
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
Hose Reel (A55758)
Hose Reel (A55758)
John Deere 6120M (A57148)
John Deere 6120M...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2013 Ford Explorer AWD SUV (A56859)
2013 Ford Explorer...
40' Connex Box, Asset# 32 (CONTENTS NOT INCLUDED - DELAYED REMOVAL, CONTACT SITE MANAGER) (A59076)
40' Connex Box...
