2017 DK4510 Shifter Linkage Leaking at Transmission
   / 2017 DK4510 Shifter Linkage Leaking at Transmission #1
SSF556
Member
Woodruff, SC
NONE
I have had a small leak for about a year now. Happens to leak when the transmission is hot.
- Does anyone have a part for the seal that surrounds the shifter linkage going into the transmissio?
- Does anyone know where the vent tube is for the transmission? I would like to make sure that is not clogged with a dirt dauber or other debris
- Lastly has anyone experienced this issue? If so do I need to take to the dealer or fix it myself.
Thanks
   / 2017 DK4510 Shifter Linkage Leaking at Transmission #2
Mine leaked around the boot. I slipped a hose clamp down the shaft and worked it onto the boot. With enough socket extensions, I was able to tighten the clamp. Problem solved. It took 6 attempts holding my phone up in the cavity to get this photo!
Mine leaked around the boot. I slipped a hose clamp down the shaft and worked it onto the boot. With enough socket extensions, I was able to tighten the clamp. Problem solved. It took 6 attempts holding my phone up in the cavity to get this photo!View attachment 736227
Awesome! Do you think removing the diesel tank would give me more room to work?
   / 2017 DK4510 Shifter Linkage Leaking at Transmission #4
I did not need to. You can loosen the bottom tank brackets and tip the tank down a couple of inches if needed. I would not recommend removing the fuel lines (and tank) as that requires you to purge the air out of the system after which can be a pain.
   / 2017 DK4510 Shifter Linkage Leaking at Transmission #5
Thanks
Did you get it fixed?
Not yet but it is on the list of things to do before I start cutting grass this spring.
Thanks again for the heads up
2018 Freightliner M2 106 AWD Terex Hi-Ranger TC55 55ft. Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
COPPER POT & COIL (A58374)
COPPER POT & COIL...
2016 Isuzu NPR-HD (A56858)
2016 Isuzu NPR-HD...
2012 BMW 328i Coupe (A56859)
2012 BMW 328i...
2012 Jeep Grand Cherokee SUV (A56859)
2012 Jeep Grand...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
