2017 DK4510 Shifter Linkage Leaking at Transmission
   / 2017 DK4510 Shifter Linkage Leaking at Transmission #1
SSF556
Member
Woodruff, SC
NONE
I have had a small leak for about a year now. Happens to leak when the transmission is hot.
- Does anyone have a part for the seal that surrounds the shifter linkage going into the transmissio?
- Does anyone know where the vent tube is for the transmission? I would like to make sure that is not clogged with a dirt dauber or other debris
- Lastly has anyone experienced this issue? If so do I need to take to the dealer or fix it myself.
Thanks
   / 2017 DK4510 Shifter Linkage Leaking at Transmission #2
Mine leaked around the boot. I slipped a hose clamp down the shaft and worked it onto the boot. With enough socket extensions, I was able to tighten the clamp. Problem solved. It took 6 attempts holding my phone up in the cavity to get this photo!
Mine leaked around the boot. I slipped a hose clamp down the shaft and worked it onto the boot. With enough socket extensions, I was able to tighten the clamp. Problem solved. It took 6 attempts holding my phone up in the cavity to get this photo!View attachment 736227
Awesome! Do you think removing the diesel tank would give me more room to work?
   / 2017 DK4510 Shifter Linkage Leaking at Transmission #4
I did not need to. You can loosen the bottom tank brackets and tip the tank down a couple of inches if needed. I would not recommend removing the fuel lines (and tank) as that requires you to purge the air out of the system after which can be a pain.
   / 2017 DK4510 Shifter Linkage Leaking at Transmission #5
Thanks
Did you get it fixed?
Not yet but it is on the list of things to do before I start cutting grass this spring.
Thanks again for the heads up
2006 Ford F-450 4x4 Service Truck (A56858)
2006 Ford F-450...
2019 DODGE RAM 3500 (A58214)
2019 DODGE RAM...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
LOT: (4) Jack Stands (A59076)
LOT: (4) Jack...
