Specialty Tractor
/ Specialty Tractor #1
presnewt
Thomson, Ga
Steiner 440,Kubota MX5400 HST cab
I have been on the forum recently asking some questions about compact tractors. My search for a new tractor came about because I am so unhappy with my current tractor, a Steiner 440. If you are not familiar with these, they are a niche tractor, similar to a Ventrac. They are great at mowing on slopes and on wet ground. Up north they are popular for moving snow. I cannot keep mine running so I am planning on getting rid of it. A traditional tractor will work for most of my mowing but will still not be nearly as safe on hills and not nearly as adept on wet ground. The ventrac is an option but I am not sure it is much better than a steiner. I have seen some italian tractors that are designed for hill work but there are very few dealers around. Does anyone have any other suggestions on where or what to look at? The steiner and ventrac are 25-30 hp which is really underpowered and they are so low to the ground that they are subject to damage. The obvious answer is to have two tractors, but I cannot really afford that especially when one will be the unreliable steiner. Thanks for any suggestions.
/ Specialty Tractor #2
There are people on this forum that think Powertrac is better than any Compact Tractor ever built.
Power Trac Products
/ Specialty Tractor #3
What engine is in your Steiner?
/ Specialty Tractor
25 HP diesel engine, dual wheels, rough cut mower and ventrac power rake.
These are considered by many to be the best orchard tractors. Turning radius like no other and a very low profile. Factory quality control is second to none. Prices seem reasonable. Now the cons: 1 or 2 dealers in the USA. California and Oregon.
I have looked at those and also at Carrero tractors, they are very similar. They come in much higher HP than the steiner or ventracs but the problem is the dealer network. They are pricier than my tractor, but they are much more tractor also. I like the looks of them too. The neatest thing about them it the reversible seat so you can mow either in front of you or behind you.
/ Specialty Tractor #5
May I ask what specifically is failing on your Steiner? Maybe you already did a review of it here.
/ Specialty Tractor #7
Specialty tractors tend to come in either narrow and lower stance or wide and lower stance. There companies like NH that offer some of these specialty tractors, however I don't know what they offer in the US.
Isodiametric tractors, like Ferrari, Antonio Carro and others, are great to use on hills, after all those were made for hills and not even comparable with Ventrac or Steiner. Antonio Carraro is a couple steps above Ferrari/BCS/Pasquali (all made by BCS) in quality and finish but as you may imagine, in price as well.
There are two dealers that I've read nothing but absolutely great things about them. One is in PA and the other is in Florida. I'm sure there is plenty more, but I'm not aware of those.
Forum member @Tunin from Bosnia and Herzegovina dealt with the AutrUSA dealer and had a very good experience.
/ Specialty Tractor
How much diagnosis have you done to your Steiner diesel. "Keep it running" doesn't sound like a replacement reason to me...yet.👍
It has been in the shop since labor day of 2021. In 2020 it was in the shop for almost three months. The curreny problems (hydraulic) have taken the dealer four tries to fix and it is still not fixed. In 2020 it took them three tries to fix it. Before that, I had lift problems and I also have had bolts on some of the engine parts shear off causing it to completely tear up radiator and all kinds of other stuff. I do not use the machine commercially so it is not worked very hard and does not have an overabundance of hours on it. It is a model 440 which I have been told by dealer after dealer was a disaster of a tractor. The majority of the work is I do is mowing during the spring and summer. It has never made it more than two or three months before breaking down. There has been plenty of diagnosis done on it by the dealership over the last three years. It has not helped. I have finally gotten Steiner corporate to step in and try to help but you can only waste so much time and money on a piece of equipment that will not run.
/ Specialty Tractor
Right now it is hydraulic issues but it has been one thing after another for 5 years. The model I own is widely known in Steiner and Ventrac circles as the absolute worst model they ever made. I have posted about it in the Ventrac forum in years past.
/ Specialty Tractor
I have spoken to some people about the Ferrari and Carraro tractors. They are top notch but they are not cheap and dealers are few and far between. I am talking to New Holland dealers near me now about their specialty tractor but they don't really know much about it and I am not expecting much from them.
/ Specialty Tractor #12
I was thinking the same thing. There are lots of good reasons to get a different tractor, but not being able to keep one running doesn't sound like something that a different tractor would cure. But maybe so....I'd have to know more about the problem and what's been done. Otherwise he might just end up spending a lot of money to end up in the same place.
One dealer not being able to fix something isn't uncommon at all. Mechanics come in all degrees of good and not so good. The old time diagnose and repair guys are fast fading away. Their replacements are parts guys. Our local new imported tractor shop doesn't have welding, machine tools, or hydraulic diagnosis equipment in their service shop. I'd suggest that you look for a shop with all those things. Particularly a hydraulic flow and pressure test stand. Without that, hydraulic diagnosis is just about impossible. It's guesswork instead of knowledge.
Those square-body US made tractors are more oriented toward the home mechanic and standard industrial parts than the imported compacts are. I like that aspect; it gives people a choice of what to buy. For some people being able to fix what they buy is still important. Otherwise its a new model of one of the more popular compact tractors. They cost a lot, but are also very reliable.
/ Specialty Tractor #13
Well, sounds like you have some pretty good reasons to seek out another machine.
Ventracs have a pretty good reputation for grounds work like mowing on hills and such. Do you have any need for a front end loader? If so, then ventrac might not be ideal for you. But they have scoops that are OK for moving mulch and loose gravel/stone around.
How big are your hills?
/ Specialty Tractor
I don't understand your reasoning. I think having a tractor that does not work is the perfect reason to look for a different tractor. What other choice do you have when the dealer cannot fix the problems with your tractor. I have had these issues for 5 years. So your suggestion would be to keep it and hope it begins to function like it should? That does not make much sense to me.
/ Specialty Tractor #15
If you'd like to get work done and your machine is again broke, now your fixing it instead of the job you planned to do. I'd say dump it.
/ Specialty Tractor #16
Speaking from personal experience, I'd not recommend a tractor like that with no dealer/repair network unless you are willing to do the work on it yourself, or have a very trusted and competent mechanic, and be assured of a reliable parts source.
I have owned a PowerTrac PT425, for 21 years now. They are factory direct with very good tech support over the phone, and excellent parts service via shipping. However, I do all of the work myself. There are no dealers. I enjoy working on machinery and am confident enough and capable enough to do the work, so it's not an issue for me.
So that's just some things to think about with a specialty or unique machine:
Parts
Support
Labor
/ Specialty Tractor #17
Don't be so pissy. Just because your dealer cannot fix it doesn't mean it isn't fixable. It just means that he can't fix it. What do you do when you hire someone incompetent? Throw up your arms and walk away? Or take the more logical course of either fixing it yourself or finding someone who can?
There are as many good mechanical shops as poor ones. Sometime during those 5 years you must have considered either fixing it yourself or finding someone who can. I gave you some hints on how to evaluate a shop. But I bet you can figure that out yourself.
However, your point is accurate when you say that if what I am saying doesn't make sense to you it's my shortcoming. So Let me try again by saying this:
"Whatever machine you get is going to require mechanical attention. That's the nature of mechanical things. You need to figure out how you are going to provide that mechanical attention or else you will end up with a similar problem."
No, I'm not trying to be mean. You didn't get a very good model last time. I hear that. I figure you can fix that.
What I'm doing is working on the more general mechanical part of the problem.
rScotty
/ Specialty Tractor
Parts
Support
Labor
I agree 100%. Steiner has a dealer network and have used a Steiner dealer to repair it. They can't do it for some reason.
/ Specialty Tractor #19
I'll give the example of my mother in-law's Toyota minivan. A bunch of dashboard lights came on, and it started running rough. She took it to her family's much trusted mechanic. He could not figure out what was wrong with it. Diagnostic machine could not figure it out. He said "It's either the engine, the transmission, or both. I can't narrow it down enough to help you. You better take it to the dealer."
The Toyota dealer ran diagnostics on it, and they told her the same thing. "It's either the engine or the transmission or both. We can't figure it out without starting to replace everything, one thing at a time. That could get expensive. A new engine is $5K. A new transmission is $4K. The van is only worth $10K. You'd be better off getting a different vehicle."
So yes, you can spend time and money and eventually repair everything. But at a point, it's not worth the time or money or aggravation of having it fail again and again and nobody can seem to determine why.
I'd think after hearing the OP's reasoning for wanting a different machine, most people would agree with him. Get a different machine.
/ Specialty Tractor
rScotty
Not being pissy, just don't understand your comment. If the dealership cannot fix it and I cannot fix it, then for all intents and purposes it is unfixable. They are the ones trained, they are the ones I have already paid for the repair work. At some point, it is time to move on from a machine that does not work. If this was a car and the certified mechanics could not keep it running then I would be a fool to keep driving that car in hopes it will all of sudden get better. I have been trying to fix this model for five years. I have done a lot of the work myself (I am an accountant, not a mechanic) but things like hydraulic or engine problems are above my paygrade. If the experts can't fix it, then it is time to move on.
2016 Dodge Charger Sedan (A66738)
2016 Dodge Charger...
2026 Unused CID SNLB84-S 84in. Snow/Ice Skid Steer Bucket Attachment (A66734)
2026 Unused CID...
2013 GMC Seirra 2500HD Ext. Cab Knapheide Service Truck (A68183)
2013 GMC Seirra...
2013 INTERNATIONAL PROSTAR+ 113 (A67714)
2013 INTERNATIONAL...
PALLET OF MISC WHEELS (A67714)
PALLET OF MISC...
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
