Starlink
/ Starlink #2,141
So frustrated, a work friend just got his dish, he put in an order after I was talking to him about it. He is a town over. :(
Availability is by cell, which is an approx 13 mile wide hexagon. Depending on how the company has laid them out your next door neighbor might be in a different cell and have the same situation.
That said, it seems like there have been tons of new orders in the last month or so, so I think things are opening up a bit. Remember though, Starlink has only about 2000 out of the eventual 12,000 sats (maybe 30,000) they will eventually have. This is why they are throttling the number of users. If they flooded the system with too many new users the service would crap out and that wouldn't serve anyone well.
/ Starlink #2,142
The Starlink Ridgeline roof mount would have been an alternative but it's no longer available.
I did not want the dish on the roof ridge, or on the roof at all, and I did not like the looks of the mount. Having said that, my temporary installation is made from scarp 2x4s and is weighted down with heavy concrete edgers that are much heavier than bricks or pavers. It kinda looks like the photo but it is sitting on the part of our roof with a low slope.
It is ugly, but very hard to see, and it works. :D We had a nasty front come through this morning with very high wind gusts. Dishy was still up there and working. After the rain stopped I went and checked on Dishy and it had not moved. (y)
Shame Starlink is not still selling the ridge mount. Maybe people do not like the looks and were not buying. If my hacked mount works, that one would work.
Later,
Dan
/ Starlink #2,143
Exterior Wall Cable Pass Through / Removable?
I'm getting a replacement dish and need to my recently received SL system. The initial installation was done by a satellie tv installer on a very cold and snowy day. He drilled a hole through the exterior wall, put the cable through and sealed it will silicon. Once I get the old cable back out through, I would like some kind of cable grommet or other solution that will allow me to remove the cable without damage if I should decide to send back the second dish (not all all sure it is going to work long term). The last time I looked the SL kit for doing this was back ordered and I need a solution sooner than it is likely to be available. One solution that might work is this cablecar pass though for boats.
Any other ideas?
/ Starlink #2,144
Any other ideas?
The blue sea systems work well. I have used them a couple of times, but for home use, I think that you really want the cable going into a conduit that is waterproofed to the exterior wall, and won't drip inside the wall and rot it. You can use flexible conduit to make life easier, and then foam the conduit inside when you are done to waterproof it.
For my recent rewire, I terminated Starlink in an exterior box, like this;
But I used cable passthrough big enough for Ethernet, which I now have to redo for the new Dishy router as the cable end is so much bigger. I may use the Blue Sea version. I then drilled a conduit hole from the back of the box into the house (using lots of caulk around the conduit penetration!). My router needed to be some distance from the house, so it needed its own box.
All the best,
Peter
/ Starlink #2,145
Keep in mind current events has SpaceX tied up with starlink security issues.
/ Starlink #2,147
Some satellites got jammed so he has the SpaceX troubleshooting and reprogramming and I would expect looking at hardware solutions. Follow SpaceX if you're interested.
/ Starlink #2,150
Is there anyway to see what cell your in?
Short answer, no.
Slightly longer answer, if the delivery dates in your adjacent cells are different than at your house, it can be done. You may be able to plot it, by trying different locations (using Google plus codes) and seeing where the delivery date changes. It is time consuming. I did it to see how far away we were from a boundary into a cell that I knew had fewer than five residents as a plan B. Why? To see whether placing a second order for an address in that cell, and leaving it in that cell might work. Rumor has it that if you are within 1-2 miles of a cell boundary with a good sky view, it can work in the next cell over, but not to expect Starlink to help. In actuality, our Feb 9th 2021 order date, with an estimated ship date of "mid-2022" turned into a mid-February 2022 shipment, so we didn't go with plan B. Our boundary turns out to be about a mile as the crow flies, and I was able to get the cell boundary to within 100 yards.
Definitely a YMMV thing.
EDIT: @forgeblast brought up a really important point. Do not try other addresses when logged in to your own account. I did the above as a guest, with a new, private, browser window for each location. (See below)
All the best,
Peter
/ Starlink #2,152
Short answer, no.
All the best,
Peter
does changing the shipping location change your date, or can you just mess around with out it updating every time. I would hate to loose my place in the cue.....
/ Starlink #2,153
THANK YOU!
This may be a really important detail. Let me clarify; don't do this when you are logged into your account. Do it as a guest, using your browser in private/incognito mode. I used a new private tab for each address, and the address for where I was going to use it.
Starlink shifted a bunch of delivery dates in late December '21 for people, like me, who had adjusted their use location. They moved mine from late '21 to "late '22/early'23" There was a huge outcry. They later readjusted the shipping dates and said it was a glitch. I wouldn't trust them not to mess with mine, even if it was a "glitch" or an "accident". So don't do this from your account, and absolutely use stealth/incognito/private mode on your browser. It might not matter, but why run the risk?
All the best,
Peter
/ Starlink #2,154
This is about the 40 new Starlink SpaceX satellites that recently fell out of orbit because they got bogged down in space mud.
All vehicles tractors etc that have computer chips to make them work are at risk of emf storms.
/ Starlink #2,155
Guess they needed the R1 satellite tires.
/ Starlink #2,158
For those of you who are curious, here is a great post on how the ethernet adapter is put together. It appears that the router does have a two port switch on it, and sends signal back up the cable to the Ethernet adapter, where the ethernet is broken out.
The author speculates that this was done as so many users weren't using the port, which is certainly possible. The design would also be one way to have dual Ethernet channels for a higher bandwidth, say with premium. Fun to speculate.
Oh, and for anyone who is hiring telecom engineers, he is open to relocation. Currently he is in Kyiv. His CV is here.
All the best,
Peter
/ Starlink #2,159
Oh, and for anyone who is hiring telecom engineers, he is open to relocation. Currently he is in Kiev. His CV is here.
All the best,
Peter
That's not the way I am interpreting it, its a 2 port switch, one is used to go out to dishy with poe, the other is for the aux ethernet connection, there are no other connections available.
/ Starlink #2,160
Can the second generation router be placed in a sheltered place outdoors? Browsing the SL Reddit several folks report placing their router in a sheltered outdoor location. However, the specifications for the second generation router on the SL website are:
  • Operating Temperature: -22°F to +122°F (-30°C to +50°C)
  • IP54 rated (water resistant), configured for indoor use
I Interpret this to mean the router is not outdoor rated. I just received my replacement dish and router (the first one died) and I want to test it but my best option is to place the router outside because of issues getting the cable into the house. I can put the router on a sheltered porch where it will not get any exposure to rain or snow. What do you think?
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
UNUSED WOLVERINE TDB-11-78W-78" BUCKET (A64281)
UNUSED WOLVERINE...
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
Shamrock 8ft. S/A Enlcosed K-9 Transport Trailer (A61574)
Shamrock 8ft. S/A...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59912)
2018 VOLVO VNL...
