Case IH 275 Loader Control Valve
/ Case IH 275 Loader Control Valve
So I pulled out the plug that you circled and put normal plug in and 3 pt hitch seems to be working fine. I have not put a load on it yet, but believe this fixed the issue. I reached out to Brand support during this and kept saying I needed PB setup. I was suspicious since it was not on other control valve. LD1 thank you because your input help me better understand the problem and resolve the issue.
/ Case IH 275 Loader Control Valve #22
That sure looks like a CC plug to me.
You really should get the appropriate PB cartridge from Brand. Then instead of feeding your 3PH off the tank passages of the new valve (which can possibly damage it if you put something heavy on the 3PH)....feed the 3PH off the PB. Then add the tank line and dump it somewhere to the tank/case of the tractor
A suggestion on how to feed back to tank, since no additional ports?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
Club Car (A59231)
Club Car (A59231)
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
CAT D8 (A58214)
CAT D8 (A58214)
