Swollen Ford Lug nuts
/ Swollen Ford Lug nuts #1
gsganzer
Elite Member
Denton, TX
L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
Anyone else deal with this! Holy swollen nut batman!!! I have a 2014 F-150 and my buddy and I went to do a rear brake job today. Out of the 12 rear nuts, we could only remove 6. That's with trying PB blaster, using a 1200 ft/lb pneumatic impact wrench, 20V Dewalt impact wrench and (3) 1/2" breaker bars with 3' cheater bar (broke all three breaker bars), and trying a micro butane torch. WTF??? We still never removed both rear tires. If I was on the side of the road with a flat and ran into this issue, I probably would have set fire to the dang thing. WOW! I can't believe the level of effort we've made and still not succeeded. Has anyone else gone through this? What was the solution? I'm about to drill all the studs and snap them off, then replace them.
/ Swollen Ford Lug nuts #2
They're tough if 1200 lbs won't break them. Hopefully the PB Blaster will work it's way in overnight, then try something with a little more heat tomorrow to help it along. Otherwise you will indeed need to drill them, at least enough to get the penetrating oil onto the threads. Or find somebody with cutting torches...
Good luck.
/ Swollen Ford Lug nuts #3
Run it down the road dragging your brakes. This will heat up the rotors and stud bolts. Stop and try to loosen them. If it does not work run them a little more dragging your brakes to heat them up again and get out and spray wd 40 around the lug nuts. It will get sucked up around the threads. You should be able to bust them loose then. As much force as you say you put on them the studs should have snapped. If above tricks do not work get a longer cheater bar. They will eventually brake loose or snap off.
Apparently, this is a known issue, and a class action lawsuit was filed against Ford. Man, this is ridiculous trying to remove these blooming things! Apparently, they're 2-part lug nuts with a steel nut and aluminum over wrap. The aluminum swells and galls against the alloy rim. Good grief man, what a PITA! Drilling is looking like my only option.
/ Swollen Ford Lug nuts #5
I can remember when I was younger some cars had left hand threads on lugs on one side of the car. I can remember being frustrated by having to guess which way to turn the lug nut.
/ Swollen Ford Lug nuts #6
Several years ago I read a few posts, here on TBN, about folks having troubles with loose lug nuts. I went out removed one lug nut at a time - applied Blue Lok Tite - re-tightened. Lug nuts are not about to loosen on MY tractor.
So - last year, I went out and checked one lug nut on the tractor. It was tight, darn tight, but I was able to break it. I used my 3/4" breaker bar and impact sockets.
I would suggest - mild heat, WD-40 or the like, wait a few days - try again. When you finally get them off - Ford should have retrofit lug nuts to replace the OEM.
/ Swollen Ford Lug nuts #9
I learned my lesson years ago.
whenever I change tires (ie: summer to winter tires), I spray a liberal amount of WD40 on both the hub and studs (lug nut threads) before putting the tire back on. Never had any problems since.
breaker bar works though in situations like this; just tap/hit the breaker bar with a 10 lb sledge hammer to break the bond. Usually works.
/ Swollen Ford Lug nuts #10
Friend of mine had the same problem. After fighting with the dealer they finally gave him new ones.
I don't use an impact on mine, power bar only as I don't want to deform the s/s shells if they're two piece nut's or beat them to pieces if they not.............Mike
/ Swollen Ford Lug nuts #11
Google it!, horrible problem, wife’s 13 Escape is on its 4th set of lug nuts. Finally bought some aftermarket all steel ones that don’t swell or corrode. 9 of them had to be destroyed last time the tires were rotated.
/ Swollen Ford Lug nuts #12
buy this. make sure the right size is here. mechanics use these for this issue.
https://www.amazon.com/Steelman-5-P...1fdabc3596cbf&language=en_US&ref_=as_li_ss_tl
Interesting, I never knew these were made. I'll add them to my wish list (the breaker bar too, that looks cool). Around here in "salted road country", swollen lug nuts means the lug nut's decorative caps swell out from the steel lug nuts rusting away. What we do is alternate between metric and SAE sizes. All my vehicles have 22mm lug nuts, a 7/8" will fit them once they start swelling.
22mm
0.8660​
7/8"
0.8750​
22.5mm
0.8858​
23mm
0.9055​
15/16"
0.9375​
1"
1.0000​
/ Swollen Ford Lug nuts #13
I don't own a ford.
But the only lug nut swelling issue I have is when the chrome skin of the lug nut wants to come loose or swell from the steel part of the nut. Can be a royal PITA.
Only twice in my life have I resorted to drilling through the stud/but enough to snap it and then just replace with a new stud and nut.
It does work though
/ Swollen Ford Lug nuts #14
Use CorrosionX on about all threaded fasteners. Helps makes maintaining equipment easier years later.
/ Swollen Ford Lug nuts #16
My go to solvent is to mix about 25% transmission fluid with 75% acetone. The acetone thins the oil enough to penetrate and then evaporates leaving the oil.
If soaking doesn't work my experience as a boat mechanic dealing with bimetallic corrosion tells me the only real alternative is heat. Heat the stud with a torch, let them cool, try to loosen; no luck? reheat and try with them hot.
If you peel off (or melt)the aluminum outer nut you may be able to move the nut with a chisel or just cut them off with a chisel. Either way it will be a major PIA and time consuming.
/ Swollen Ford Lug nuts #17
Swollen or stuck?
Swollen means finding a socket to fit. Not always easy. And then new nuts
Stuck? Put a good deep impact socket on. Swing a large hammer(sledge) as hard as you dare, hitting the socket into the wheel. Use care to not miss and hit wheel. A few hits, then use impact wrench. Normally will come right off.
/ Swollen Ford Lug nuts #18
CorrosionX is an oil based product. The use of any lubricant on a stud is a non-no since proper torque cannot be achieved with a lubricant present. If a bolt is lubed and then brought to the proper torque the bolt will be overstretched and subject to failure.
This ultimately did it. It took a fair number of hits and a few stiff sideways smacks were also needed.
/ Swollen Ford Lug nuts #20
I think they are still trying to get them apart. At this point putting things back together with proper torque is a future project.
I agree on the oily threads. From what I've seen in books, typical mechanical practice is to reduce the torque by 10% for oily threads. After all, everyone does it.
I figure that 10% more or less torque is something I'd rather deal with than torn threads and corroded fasteners. So I smear my wheel fasteners with a blob of chassis grease. Threads and faces both. Using anything except that sticky messy moly lube.....
rScotty
2023 KUBOTA SVL 97-2 SKID STEER (A65053)
2023 KUBOTA SVL...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
