10 Hours In, found this laying in front of my bucket (see pic)
   / 10 Hours In, found this laying in front of my bucket (see pic) #1
saxon11
Minnesota
TYM T474
This pin fell off my new T474. Anyone have an idea what it's from? FYI I've done a lot of loader work since I bought it (10 hours on tractor). thank you
   / 10 Hours In, found this laying in front of my bucket (see pic) #3
on tractors I own (sorry don't have one like yours) the only place I have lynch pins is on the back end to hold implements to the 3pt hitch arms and the top link.
Sometimes I have someone use one of my tractors, take off top link and leave a lynch pin on the top link bracket.
check your 3 pt implements and lift arms and top link and maybe you can see one side or end is missing a pin otherwise I wouldn't loose any sleep over it.
   / 10 Hours In, found this laying in front of my bucket (see pic) #7
I buy them and loose them in quantity.
So do I, but I’ve noticed that most cat 2 implements don’t use them. The one inch pins have the slide through pins so I don’t have much need for lynch pins after replacing my cat 1 tractor.
   / 10 Hours In, found this laying in front of my bucket (see pic) #8
Look on the back side of this pin, both sides.
Bruce
I have the RK which is made by TYM and the pin on my FEL that is referred to here isn't a lynch pin. The onl;y lynch pins I have are on the 3 point assembly. I would look over that area to see if you're missing one. Could ne on the top link or a stabilizer bar.
   / 10 Hours In, found this laying in front of my bucket (see pic) #9
If that lynchpin is from your tractor better stock up. That is a lot of wear for 10 hours.
   / 10 Hours In, found this laying in front of my bucket (see pic) #10
BCP is most likely dead on... I have purchase some and I cough a few where the ring of the lynch pin would open with the sightless touch, make sure its not your issue, my brush hog disconnected on one side of the three point and snap the shear pin because of it.
   / 10 Hours In, found this laying in front of my bucket (see pic) #11
All my Cat 2 implements use those finger-eating Lynch pins. jyoutz - you must have some pretty fancy Lynch pins.
   / 10 Hours In, found this laying in front of my bucket (see pic) #12
Replace with a bolt and nylon lock nut.
   / 10 Hours In, found this laying in front of my bucket (see pic) #13
Any practical jokers nearby? We used to throw some random bolts/nuts under the fire truck to drive the operator nuts when he/she did their daily check.
   / 10 Hours In, found this laying in front of my bucket (see pic) #14
I agree, hoses or something must have been caught on it as the loader was used.
   / 10 Hours In, found this laying in front of my bucket (see pic) #15
Broken bolts are more fun.
   / 10 Hours In, found this laying in front of my bucket (see pic) #17
Don't get me going on what we did to the rookies... :)
Blinker fluid.
Flight line.
180lb hose puller.
Box of spare fallopian tubes.
I'm just getting warmed up.
   / 10 Hours In, found this laying in front of my bucket (see pic) #20
I picked up some of these at tractor supply. At least when you forget them or they fall out you don’t lose it lol.
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
iDrive TDS-2010H...
2018 Chevrolet Camaro 1LT Coupe (A59231)
2018 Chevrolet...
John Deere 5055E (A53317)
John Deere 5055E...
2009 Cadillac CTS Sedan (A59231)
2009 Cadillac CTS...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
