3 point
/ 3 point #1
cheesehead22
Ferguson T20
3 point will not go down /only up when engaged after being in storage all winter. fluid milky.
/ 3 point
Sorry I should have added its on a Ferguson T 20.
/ 3 point #4
Hi, and welcome to TBN. The three point goes up under hydraulic pressure. It goes down from gravity. There is usually a valve centered on the operator's seat between your feet. It must be opened to lower the three point. How far it is open adjusts the lowering speed. If the fluid is milky it has probably taken on some water.
/ 3 point #5
An old to20 won't have a drop speed knob.
Try putting some weight on the arms. Stand on them or something.
That or the draft control rod/spring may be frozen preventing lowering. Try w couple taps with a hammer
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
2025 Swict 66in. Bucket Skid Steer Attachment (A61567)
2025 Swict 66in...
500 BBL WHEELED FRAC TANK (A60736)
500 BBL WHEELED...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2025 Hercules 14 Gun Safe (A61569)
2025 Hercules 14...
