Stamped marking on chain
/ Stamped marking on chain #1
Tony H
Summit, NY lots of Lake Affect snow
JCB MIDI CX / 1985 Cub Cadet 782
When discreet start stamping chains? I have a 30-40 year old 3/8 chain. Maybe zinc plated, never used. Trying to decide whether I want to spent $40ish for grab and slip hooks to make a pull chain if I ever need one. Don't know the grade of this chain, not sure when stamped chains became a standard
/ Stamped marking on chain #2
Chain grades have been around as long as I remember. If it's zinc plated, it's probably Grade 30. In which case I wouldn't use it to pull more than a riding lawn mower. ;) Here's a chart.
I know the weights for the grades and sizes. Just wondering when chain markings began.
/ Stamped marking on chain #4
Just a rough guess here. Chain marking began with the use of chain. This would make the system pretty darn old. I would guess it started with marks that indicated - maker of the chain - type of chain - strength of the chain.
/ Stamped marking on chain #5
I wonder if it is an old anchor chain? They were often stamped and proofed and hot dip zinc plated.
My old industrial pulling chain has got to be 50 years old and it is not stamped.
I keep arguing with myself as to whether I should replace it. An alternative would be to have it proof tested. Maybe I'l look to see if there is someone local who does that.
It IS an old anchor chain. It was a spare anchor on an old 43' trawler. I can't imagine a place by me that has those qualifications. I used to work by and use a UL facility to test my electronics designs.... Many hours away from There these days
/ Stamped marking on chain #7
Well, if it has stampings, someone knows what they mean. With anchor chain is normal to proof test the chain to it's rating everytime they renewed the zinc Ask around and see if the markings are familiar. That will be a place to start. Somebody local probably tests chains if there is trucking or construction where you are.
I use old untested chain myself....but then I know I'm stupid that way. And I never, ever work under a chained load. Not even my toes.
rScotty
/ Stamped marking on chain #8
With a 3/8 anything you should be fine pulling anything you find pullable. It ain't like you are un sticking bull dozer with trac hoes. Pulling out log trucks. Though it will probably still work fine. Jerking is what breaks chains, shock loads.
/ Stamped marking on chain #9
I have an unmarked 1/2" chain w/slip hook on one end and grab hook on the other. Just like the old logging chains when I was a kid. I'm 80 now.
/ Stamped marking on chain #10
I found the most often used chain I have; is a 6 foot chain with a grab hook on one end and a slip hook on the other end. Used for pulling shrubs, chain harrow behind tractor (to move it away from rear wheels when turning), pulling tee posts with loader, etc. Makes using tractor to lift or pull stuff quick & easy. It's easy to make too.
/ Stamped marking on chain #11
Most of my chains I picked up out of the road. The nicest is a metric, 16 foot binder chain which I suspect came off a Canadian flat bed trailer. He must have been going at a pretty good speed around a curve... when I found it the chain was all in a big ball, like you had dropped one end on the ground and let the rest follow.
/ Stamped marking on chain #12
Most of my chains are 5/16" grade 70 cut to 10' with a slip hook on one end and a grab hook on the other.
Two chains here are 20' 9/32" and probably grade 120. They were overhead chains at a paper mill and had to be changed on a regular basis.
/ Stamped marking on chain #13
A friend gave me several chains he used when securing loads on his flatbed semi trailer. They were used to on-load/off-load and secure loads. They are 3/8" and really quite heavy. I very rarely use them - but nice to have, just in case.
/ Stamped marking on chain #14
I have many chains, mostly grade 70's. But I wanted a chain I could safely walk under, so I bought this 20 footer,
It's a grade 100.
SR
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
40' Shipping Container (A66285)
40' Shipping...
20 gal Oil Collector (A66408)
20 gal Oil...
Covered Livestock Mineral Feeder (A66408)
Covered Livestock...
(2) Tool Boxes (A62613)
(2) Tool Boxes...
Bestway 750 Sprayer (A66285)
Bestway 750...
