Did I bust something on the loader hydraulics?
   / Did I bust something on the loader hydraulics? #101
Moving some large oak logs and heard a loud TIC.
Loader was down a little on the right. No broken welds, by measuring not twisted. Tried straightening by lifting and bumping the left side. When running the tractor it would level. When parked it would drop always to the right but while running be level. Never could figure out what got tweaked.
   / Did I bust something on the loader hydraulics? #102
What Tx Jim said, that ain’t right, for a couple of reasons. As he stated the valve shouldn’t let fluid pass while its in the neutral position. Also, the cylinders should have enough drag on them just from the seals that they should take a bit of force to move in and out. But if that were happening they should also be slobbering fluid from being to loose. I’ve worked on alot of cylinders and that is very weird.
I disagreed, so this afternoon I went out and tried it on our Kubota. It has excellent hydraulics and no problems. So I drove it around to warm it up, put the bucket down in the same position as the OP did with his in the video on message 1 page 1, turned off the engine, and then worked the loader control stick to take all the pressure off the hydraulics.
Then I went around to the front & put my foot on the bucket lip. Guess what? I found that it works up and down just exactly like the one in the video.
You tell me why.
rScotty
   / Did I bust something on the loader hydraulics? #103
You tell me why.
rScotty
It has to be air in the cylinders. See posts #22, #28 and #47.
Edit: and your post #26
   / Did I bust something on the loader hydraulics? #104
It might be air. We know that all fluids have some entrained air. It could also be something as simple as the elasticity of the hoses. Or something we haven't considered yet.
If it is air, then the next question is how much air is normal? I've always wondered about that. I don't like bouncy loaders, so in an effort to change things I've tried many different ways to empty the hydaulics of air. Near as I can tell, no combination of nose up, down, level, raising, and lowering has made any difference at all. Maybe trapped air is what makes a loader bucket bounce, but if so, it doesn't seem to affect FEL ability to lift and hold loads.
Speaking of doing experiments, I've always felt that experiments were worth more than opinions. We are now over 100 posts in this thread. I encourage others to try the experiment on their own tractor. It's easy. Put the bucket onthe ground, shut off the engine, work the stick to let the hydraulics relax. Now go step on the bucket lip to get it rocking and see what - if anything - happens with the bucket and lift cylinders.
rScotty
   / Did I bust something on the loader hydraulics? #105
rScotty
A video or photo of the experiment is a plus also. So did you leave the bucket tilted up so the cutting edge was a couple inches above the surface and then step on the cutting edge to make it tilt down to the surface?
Did any of the cylinders move when you took the pressure off the hydraulics? Did the boom cylinders move also when you stepped on the bucket? What besides air in the cylinders would let the bucket tilt down by simply stepping on it?
I think that loader cylinders are especially vulnerable to air that is sucked in when tilting the bucket or lowering the boom especially when loaded. This is exacerbated when the load is dropped quickly and with lower engine RPM as the hydraulic pump cant replenish fluid fast enough behind the rapidly moving piston.
Dropping the loader slowly overcomes this issue by allowing the pump to "keep up".
Edit: corrected spelling
   / Did I bust something on the loader hydraulics? #106
rScotty
I've owned 7 Kubota tractors over the years and ALL of them did this to some extent. It does no harm and FEL performance isn't affected at all so I've always assumed it is normal.
It certainly doesn't warrant a service call or even a complaint since the issue goes away as soon as the engine is started.
   / Did I bust something on the loader hydraulics? #107
I've noticed, also over the years, is that it takes a second or two to start lifting the front of the tractor off the ground, after the valve is pushed forward, especially at low idle. This is another result of air in the cylinders that has to compress enough, with piston travel in the cylinders, to start lifting the front of the tractor.
As a side note, lifting the front of the tractor off the ground is not something one would do routinely but rather, for example, as a way to change a front tire or perhaps to make shifting in and out of FWA easier.
Yes, I would encourage folks to experiment, safely, to become familiar with hydraulics in general.
   / Did I bust something on the loader hydraulics? #108
Does the issue go away when the engine is started or when the valve is operated and does it really "go away" or just not noticed?
   / Did I bust something on the loader hydraulics? #111
Yepper I like my morning coffee only I'm not the one beating the AIR in hyd system dead horse!:D
  • Good Post
Reactions: JWR
   / Did I bust something on the loader hydraulics? #112
One thing I’ve noticed on the M59 is when lowering the loader there is a notable load on the engine. This is confirmed by an slight increase in loader lift pressure by gauge.
Given the loader capacity I thought this maybe a hydraulic feature to better control heavy loads by controlling the opening of opposing cylinder valves? This prevents low pressure or vacuum on the lifting side of cylinder.
Don’t know if this is a design feature, adjustable valve function or fluke? Haven’t noticed this on other Kubota tractors to this level.
Seals on hydraulic cylinders and pumps do well of preventing oil loss or leaks under pressure. Do little to prevent air leakage into system if there is internal vacuum.
   / Did I bust something on the loader hydraulics? #113
I would suspect that the better tractor hydraulic systems sync the load checks with the pump output (slight increase in pressure as you mention) to prevent the overrunning and subsequent cavitation.
Large industrial hydraulic presses with heavy rams use what is called a counterbalance valve to achieve a similar result. They "power down".
Edit: "Load checks", for anyone unfamiliar, are check valves in the loader's control valve that prevent the load from immediately free falling when the valve is shifted to the "down" position.
   / Did I bust something on the loader hydraulics? #114
I was carrying a 16' log in my grapple and I clipped a standing tree on the left side. It wasn't crazy hard, i.e. the tires didn't come off the ground, but the left side of the tractor dove a bit. After it was over the loader was no longer level side to side, the left side was down about an inch and a half to two inches. I guess I was hopeful it'd be a bent SSQA torque tube which seems fairly straight forward to correct, but the SSQA faces are square. I can see nothing bent visibly.
Looking at the loader arms, one is definitely higher than the other. In use, It seems I can lift to max height evenly (as best I can tell) and I can press down so the implement sits flat on the ground, but I can also dig in more on the left side since it is uneven. I really don't know what's wrong. After I shutdown, I always relieve the hydraulic pressure by lowering the 3pt hitch, and the loader arms, I also toggle the loader joystick to release any remaining pressure once completely shut down. We often use the bucket top as a seat, and it's always been solid. This morning I noticed this (shutdown overnight and not started this morning), there is no pressure in the hydraulic system, all 4 rams move when I step on the bucket. Any ideas, and it is related to my uneven issue?
Video of what I am seeing New video by JCoastie
If you bent something, understand that the design engineers design all the components for an equal stress.
It is possible that a sum of tolerances has accumulated.
This meaning there is now, "a little bit off here and a little bit off there" There a lot of other good ideas posted but if you cannot find anything wrong, it is possible you have just tweaked the whole assembly.
  • Good Post
Reactions: JWR
   / Did I bust something on the loader hydraulics? #115
Is that type of design common now? With computers I guess it might be. A simple steel loader frame would be the kind of place it would happen first.
But just because a new technology can be used doesn't mean it is.
You know, analyzing stresses on any component used to be the most expensive part of a design. A designer would pick two or three places he felt were critical and ballpark the rest. Quality & reliability meant accepting that something was overbuilt in many areas. But with 3D computer drafting programs all of a sudden defining stress anywhere in an assembly suddenly becomes trivial. It's as simple as pick a load, choose whether to optimize for profit or reliability, & push a button.
Much as I hate it, you do have a point. I wonder how that will affect repair?
One thing is for sure, that type of design could sure change how lightweight tractors are built.
rScotty
   / Did I bust something on the loader hydraulics? #116
rScotty
What I am very reluctant to post, When you have a "tweak" you can often push a counter load on the structure.
That might mean putting the loader under an immovable object and restressing it the other direction.
That should be done carefully and slowly and patiently.
I would do it but I would not recommend it!
   / Did I bust something on the loader hydraulics? #117
One member suggested, several posts back, to chain a very long pole across the top of the bucket then, with the bucket clearing the ground, apply down force manually at the far end of the pole. This would seem to be a reasonably safe method as opposed to using tractor hydraulic power but even with this method care must be taken to prevent an accident.
   / Did I bust something on the loader hydraulics? #118
So I did the bucket movement test. I curled the bucket back and lowered it to the ground. Jumped on the bucket edge, and very little movement. Both the curl and lift cylinders were locked. Pushed the loader valve forward to float. Jumped on the bucket edge and there was a fair amount of movement. The curl cylinders were locked, but the lift cylinders went up and down, which makes sense because they were in float.
   / Did I bust something on the loader hydraulics? #119
Exactly what I tried to say in post #66. Almost certain to be the whole issue. Nothing to do with 'air' or other things.
Keep in mind that the OP said it works just fine. He has no operational issue at all, just the 'out of level.'
   / Did I bust something on the loader hydraulics? #120
How could air in the hydraulic system possibly cause the loader to be twisted?
  • Good Post
Reactions: JWR
2017 KOMATSU HM400-5 OFF ROAD WATER TRUCK (A60429)
2017 KOMATSU...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
2014 GMC Sierra SLT 4x4 Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
