Connecting 1/2" NPTF
/ Connecting 1/2" NPTF #1
Oldtoad
Kennebec County, Maine
Kubota L4310, Bolens-Isiki
Got some hydraulic hoses in the mail with fittings.
Is there goo needed? Just crank 'em down?
Teflon tape can get into the system so care has to be taken with that.
/ Connecting 1/2" NPTF #2
NPT is generally tapered to ensure leak prevention. A small amount of thread tape will smooth the tightening of the fittings. Of course you could use "goo" to help by lubricating and sealing the threads.
/ Connecting 1/2" NPTF #3
I will catch some flack over this, but I never use tape. Too much chance of a bit coming loose and causing problems.
I only use the Teflon "dope" that comes in a tube and is available in most every big-box store.
/ Connecting 1/2" NPTF #5
'Dopes/tapes' are lubes to allow tightening tapered threads to an interference fit. They are not meant to be stand-alone sealants.
My choice for NPT hydro lines is Permatex #2 non-hardening. It is fuel-proof & approved for high temps and steam fittings. Anything that leaks/weeps wasn't tightened enough.
/ Connecting 1/2" NPTF #7
To add a bit more to my "no tape" policy, most times, with careful application of tape, the first assembly is just fine.
It is the subsequent disassembly and reassembly that pushes used tape ahead of the male part and into the oil-stream.
/ Connecting 1/2" NPTF #8
Use this on water, fuel, oils, and anything with tapered threads...
/ Connecting 1/2" NPTF #9
NPTF is made to be used without any type of lube or sealant. It is also known as Dryseal. The thread has sharp crests that bite into the mating fitting which helps with the sealing. So thread goo isn't needed. If you later take it apart you may find that the thread is galled badly.
Eric
/ Connecting 1/2" NPTF #10
And to really kick off the discussion teflon tape is not a sealant it is a thread lubricant.
A good thread lubricant will allow NPT threads to distort and seal with no damage,
so they can be broken apart and reassembled without leaks.
How much do we put on the threads?
Put a call in to the vender, Discount Hydraulic Hose, they agreed.
/ Connecting 1/2" NPTF #13
The old standard was 3 wraps
/ Connecting 1/2" NPTF #14
LocTite 545. My NPT hydraulic fittings leaked when I used teflon dope no matter how hard I tightened them. 545 and a day to cure and they are dry.
NPT is made for 60 psi water pipes, not 2500 psi hydraulics. It needs something like 545 to work.
/ Connecting 1/2" NPTF #15
+1 on the 545 Loctite
/ Connecting 1/2" NPTF #18
Farmed for 25 years. I found out that, at least for me, only Teflon tape would seal NPT hydraulic hose fittings. Any thing else leaked.
/ Connecting 1/2" NPTF #19
Eric
Hydraulic NPT fittings are not the same as normal NPT fittings. Only hydraulic NPT fittings should be used, not hardware NPT fittings.
If you examine a female fitting you will see there is an inner mating surface. Then on the male fittings you will see that the end is perfectly machined.
There is easy to find information on the difference with a simple Google search.
/ Connecting 1/2" NPTF #20
NPT is tapered thread. The threads deform to form the seal. That's true for NPT water pipe and hydraulic fittings. You may be thinking of one of the 20 or so other hydraulic fitting types, most of which do not use the threads to form the seal. For example JIC. It uses conical mating surfaces to seal. No thread sealant needed. It is very common and is far superior to NPT. But they make a lot of fittings with NPT. I use it as little as possible and use adapters to get to JIC.
An excellent hydraulic fitting guide:
The first type of fitting they discuss is NPT, and they write:
"National Pipe Tapered Fuel (NPTF) This connection is still widely used in fluid power systems, even though it is
not recommended by the National Fluid Power Association (NFPA) for use
in hydraulic applications. The thread is tapered and the seal takes place by deformation of the threads"
2017 BX2680 Sub Compact Utility Tractor (A63688)
2017 BX2680 Sub...
John Deere 8320R (A64126)
John Deere 8320R...
ATS 60 Gallon 2 Stage Air Compressor (A62679)
ATS 60 Gallon 2...
3 POINT BEAR CAT 71854 WOOD CHIPPER (A65643)
3 POINT BEAR CAT...
2022 EZ-GO ELITE...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
