Who runs a CV joint on their PTO shaft
   / Who runs a CV joint on their PTO shaft #1
sea2summit
Super Member
Left coast of, GA
Kubota 1860->25D, MX5800, M4D
I've got a 9' disc mower for hay I put on a caddy, it has a Walterscheid overdrive shaft from the caddy to the mower but I'm getting some vibration on turns and I'd rather not blow a $2k gearbox if I can avoid it. I think I need to upgrade the PTO shaft form the tractor to the Caddy with a CV joint. Anyone have a preferred one? I'd rather upgrade the shaft just add one on...I think that will be cheaper anyway.
Next question, do I need one on both ends of that shaft? Seems like a lot of the prebuilt shafts have an 80 degree joint on one end and 50 degree on the other.
   / Who runs a CV joint on their PTO shaft #2
CV joints are expensive too. Maybe watch turning so short. I cut the long straight runs. Cut both ends of a field first. Unless it is exactly square, it's gonna have a long side and short side. Real CV joints are a pain to re do. You'll wish you had five hands.
   / Who runs a CV joint on their PTO shaft #3
These people have a good selection of PTO shafts, with one or both ends and sorted by horsepower;
Bare Co USA - Wide Angle CV Shafts
Quite often just the tractor end will have the CV as it is usually the end that gets the most articulation.
   / Who runs a CV joint on their PTO shaft #4
I have a 10' Kodiak pull behind mower and make frequent sharp turns with no issues with the CV pto that came with it.
Idaho2
   / Who runs a CV joint on their PTO shaft #5
So does Agri Supply. I have a double Cardan on my disc bine. So long as you keep it lubricated, it's no issue.
Came close to grabbing one there last weekend but it seems really long requiring a shaft trim so I figured I should research some first.
   / Who runs a CV joint on their PTO shaft #7
My Frontier FM has one and I'm going to put oine on my Maschio flail since that one works so well.
   / Who runs a CV joint on their PTO shaft #8
Cardan is what came with my 10' Kodiak/Mahindra mower.
   / Who runs a CV joint on their PTO shaft #10
I lost a CV joint a while back on a baler, I ran a single joint for years, but severely limited turning radius. I could not rebuilt the original Weasler CV, was completely shot. I also could not easily find the CV end to fit my implement end.
Ended up buying a complete replacement assembly made by B&P(Italy). Spending 4 figures on a driveshaft wasn't fun, but being able turn and not risk vibration was well worth it.
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A56857)
2007 Godwin Pumps...
Enmark Z Spray (A53316)
Enmark Z Spray...
2006 APPA TL (A55787)
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A56858)
2015 Ford F-550...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
