etpm
- Joined
- Jun 30, 2021
- Messages
- 2,399
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Today I needed to start the YM2310 tractor in order to operate the FEL because I wanted to make some measurements before shortening the hydraulic cylinder rods. The temperature outside was about 35 degrees F. The tractor is parked outside in the shade and there was 3 inches of snow on the hood. The thermostart device is broken and I forgot to order a new one. But I figured I could try starting the thing and as long as the starter wasn't cranked too long I wouldn't hurt anything. So I pulled the decompression knob, turned the key, got the engine spinning, and after about 10 seconds the engine started puffing black smoke and trying to run. The RPM climbed and maybe after another 10 seconds the engine was running. It then really started to take off and I had to push the throttle back to keep the RPM at about 1000 RPM. Then, after a couple minutes the diesel rattle sound went away and the engine sounded like it should.
I am really impressed that a 40 year old diesel engine starts this easily in the cold. Yanmar makes some good stuff. I am so glad that the first diesel I bought was this one. I especially lucked out because I knew nothing about diesel equipment in general and Yanmar tractors in particular before I shelled out 2500 bucks for mine last summer.
I used it a bunch last summer moving dirt and drilling holes with the post hole digger. The power shift transmission is fantastic. I like it better than the shuttle shift in my Case 580CK because it has 3 forward speeds. Though it can't move dirt as near as fast as the Case it gets into much tighter spaces and I'm pretty much done with major dirt moving on my place anyway. I can hardly wait to use the rebuilt 5 foot wide Yanmar tiller I bought for it a few months ago.
Eric
Eric
