HYDRAULIC TOP LINK LENGTH
/ HYDRAULIC TOP LINK LENGTH #1
Lakespirit1954
North Idaho
TYM T451
Someone please tell me how to pick correct length of this for my TYM T451, and what size hyd fittings I need.
/ HYDRAULIC TOP LINK LENGTH #2
/ HYDRAULIC TOP LINK LENGTH #3
Look at this link, get the dimension and try to get the hydraulic top link with that dimension at half extension.
As far as couplers, you need 1/2" male poppet type ISO 5675 to plug into your factory rear remote couplers.
I recommend that you go with 3/8" hose.
/ HYDRAULIC TOP LINK LENGTH #4
Also, if you plan to get Pat's or another 3ph quick hitch, that will add another 4". Not sure if you have them or plan to buy them in the future.
/ HYDRAULIC TOP LINK LENGTH #6
4"? I have Cat I and II...haven't measured the II lately but recently measured the I for a neighbor wanting to install a set and it was a 2" extension....I think the mechanical top links sold by TSC came in 25" standard and 27" for longer versions....memory cloudy here and you needed the longer link for use with the Pats.
I ordered a hydraulic top link and waiting for it to arrive.
/ HYDRAULIC TOP LINK LENGTH #9
Where did you order it from? Mt. View Ranch has always been helpful to those inquiring about top links even if they don't order thru him. Did you go thru Jordans?
Spare Parts Holland Hydraulic Top Link Cat. 1-1 with Locking Block 18 1/8" - 26 3/8" with 2 x Hoses through Amazon $253.
Arrived and installed today.
/ HYDRAULIC TOP LINK LENGTH #11
I got the SPH one from Amazon and it leaked from the cylinder right out of the box.
/ HYDRAULIC TOP LINK LENGTH #12
I've got the tsc one for.my L4150, and this one off eBay for my L2850 the tsc one is better quality imo. Had both for over two years no major problems, but prices have went up quite a bit.
Kings Echo,
I am very hard on stuff and the SPH top link hasn't given me any problems thus far.
/ HYDRAULIC TOP LINK LENGTH #15
Kings Echo,
I eneded up getting the longer one from TSC because I have the Pat's QH and it is the perfect length. Works great.
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2019 VOLVO SD115B SMOOTH DRUM ROLLER (A62129)
2019 VOLVO SD115B...
2016 Cadillac XTS Sedan (A61569)
2016 Cadillac XTS...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2025 Swict 84in. Bucket Skid Steer Attachment (A61567)
2025 Swict 84in...
