cmyoung2
- Joined
- Jun 21, 2010
- Messages
- 552
- Location
- North west NC mountains
- Tractor
- BCS 850, Kubota BX2230 w/FEL, mid mount mower, 41" tiller Kubota L3600 w/4-1FEL, Farmi winch
New project, just got a Woodland bandsaw mill, have a bunch of fairly large white pine ready for harvest. Using a BCS 850 with a logging arch I made to get the logs off the hill to the mill. The logs so far are in the 22" size range at the base, right now I am cutting them mostly 10' long just to see if I can handle them. The BCS has duals, all tire foam filled, with weights and chains on the outside tires. I think I have almost 200 lbs of weight over one set of stock tires, and I need every bit. The hill picture looks a little steep, it is steeper than it looks. With single tires/chains, the first trip was interesting, adding the duals made it possible. I actually have trouble getting the tractor to go up parts of the hill empty. I do have to drag the end of the log going down the hill to prevent a run a way, rehook when I get to flatter ground to keep from tracking up the yard. I do have a Kubota BX2230, but I am not sure I want to ride down that hill with a load. With the BCS I am walking beside it and can get out of the way when things go bad. With the weighted duals/chains the tractor is a hand full, takes all of my 200 lbs to horse it around. Should keep this 66 yr old in good shape. The BCS is amazing.
