Kioti filter cross reference number list (all models)
/ Kioti filter cross reference number list (all models) #121
I knew this was coming, do yourself a favor and stick with OEM filters. It's not worth the effort to save 15 bux on a cheaply made filter and have issues then the dealer says BYE-BYE no warranty. Then you go blah blah blah and hire a lawyer, then the lawyer goes BLAH BLAH BLAH and out cometh your wallet.
Have seen it a few times with vehicle warranty issues; it's just not worth the savings. If you want to save a dollar stop drinking beer for a few nights.
/ Kioti filter cross reference number list (all models) #122
I think that argument holds pretty well for individuals, but not so much for fleet owners.
I think the burden of proof is actually on the manufacturer to prove that the filter caused the failure. It would be a pretty open and shut case, if they couldn't produce any tangible evidence, and this would be a small claims case (in Canada at least), so the cost would be minimal, and wouldn't really require a lawyer.
I for one buy aftermarket for my Kubota, which is under warranty, out of convenience, because the dealer is an hour away. For my Kioti, I buy the OEM, because the dealer is close by and the prices are perfectly reasonable. That being said, the Kubota filter prices are also very reasonable. I might save at best $2 on a filter. The Super UDT2 tractor fluid is a spectacular price and one of the top performing fluids, so I have no issue driving an hour to get it if need be.
/ Kioti filter cross reference number list (all models) #123
I personally hate gouging and re-branding, but I have to say until I can find a guaranteed 1:1 equivalent filter for the HST and Hydraulics, I'm sticking with OEM. I just don't know enough about them right now to pick a safe substitute.
Oil filter, now that is a different story. Plenty of excellent filters out there, with teardowns and stated performance levels. So IF the OEM price is out of whack, I won't hesitate to go elsewhere for that.
/ Kioti filter cross reference number list (all models) #124
Hey I'm new to the chat, just purchased a 2017 CK2610, I'm looking for a cross-reference for the T468243172 fuel filter, anyone had any luck with WIX or any other decent brand?
/ Kioti filter cross reference number list (all models) #127
/ Kioti filter cross reference number list (all models) #128
Eric, There isn't one yet. Somewhere on TBN I posted how I drilled and tapped out the bottom hole to fit the water sensor in that filter. I do them in an upright position to allow the chips to fall out. I have been doing this right along and have not had any issues with these filters. According to both Baldor and Kioti the Baldor filter has a very slight advantage over the Kioti filter for micron ratings. I called them both and asked for the micron ratings.
/ Kioti filter cross reference number list (all models) #130
Thanks Eric. I never heard of this company.
/ Kioti filter cross reference number list (all models) #132
I'm looking at the 400hr maintenance for my 2019 NX5010 HST and found a filter kit on Amazon: KIOTI Tractor Parts NX Series HST Maintenance Service Filters. They use the Donaldson HST filter (P573481) instead of the Yellow T4125-38021 FILTER, HST HYDRAULIC and the Donaldson P822768 air filter instead of the Donaldson P827653. Has anyone used these swaps?
/ Kioti filter cross reference number list (all models) #133
TN8Man, I made a comparison write up of this filter a few years back, here is the link Kioti HST filter vs Donaldson HST filter, Opened both.
/ Kioti filter cross reference number list (all models) #135
This thread is a gift that keeps giving. I just ordered a couple of the Hi-Fi fuel filters since they are less money than the Donaldson filters (and since my sister no longer works at Donaldson as an Engineer, heh).
Also, FWIW, it looks like Donaldson's P502142 is a good number for fuel filters with the screw-in water sensor on the bottom.
/ Kioti filter cross reference number list (all models) #136
Confirmation of worky, worky.
/ Kioti filter cross reference number list (all models) #137
Be interesting to eventually cut open both filters and compare them.
1999 JOHN DEERE 344H WHEEL LOADER (A63276)
1999 JOHN DEERE...
Wacker PT3 Water Pump (A65640)
Wacker PT3 Water...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
CASE 850M WT CRAWLER DOZER (A64277)
CASE 850M WT...
Freightliner Tender Truck - Adams Tender (A63689)
Freightliner...
2009 PROCO 130BBL (A65643)
2009 PROCO 130BBL...
