Why would an L3901 feel weaker than a 2003 L3301?
/ Why would an L3901 feel weaker than a 2003 L3301? #1
tractortroof
Gold Member
Jacksonville
kubota b2650
The new one, after 200+ hours is:
Way louder, likelike hearing protection is totally necessary with this thing, and
Weaker, which is really strange to me
I like it, but only ever owned Kubota, so really don’t know.
Can anyone move this to an appropriate place in the forum? Hey a legitimate user of moderation. 🤣
/ Why would an L3901 feel weaker than a 2003 L3301? #3
You might try going to "FORUMS" scroll down until you see "Kubota Owning and Operating" open that and post your question and then delete the thread in "Food Plots"
/ Why would an L3901 feel weaker than a 2003 L3301? #4
Are the two similarly equipped (transmission, etc.)? The older tractor will not have the same pollution controls as the newer one. Compare the torque between the two tractors.
/ Why would an L3901 feel weaker than a 2003 L3301? #5
I have a 2015 L3301HST and won't run it without hearing protection, mostly because of the transmission noise.
It doesn't whine anywhere near as much now though, since I started using the Super HST fluid.
/ Why would an L3901 feel weaker than a 2003 L3301? #6
Was the old one gear and new one HST?
Both are HST. The old one was really smooth and quiet, the new one screams. I changed the fluid with AW68, no change in scream
/ Why would an L3901 feel weaker than a 2003 L3301? #8
I had a L3301 and you can adjust the hydraulic pressure if needed. I think it can be adjusted to 2600 psi. Some owners have reported that their pressure was set at 2000-2200 psi at the factory. High pressure will give you more lifting capacity.
/ Why would an L3901 feel weaker than a 2003 L3301? #9
Interestingly, my Kubota tech at the dealership told me that no 2 tractors will ever dyno the same, some output more, some output less. Case in point is my M9 open station. Had it in for an overhead adjustment and injector pop test and my dealer put it on his pto dyno and it's making 93 pto which is substantially above what Kubota rates it it. Kubota rates it at 82 pto and no, pump has never been fiddled with.
/ Why would an L3901 feel weaker than a 2003 L3301? #10
Well it makes me question just what two tractors you are comparing.
The 3301 and 3901 are only 4hp apart. They have the same engine and transmission. And both came out in 2014. So what tractor you have from 2003 I have no idea
Also worth noting that if you replaced all the hydro fluid with a generic AW68....that is FAR FROM the correct fluid.
People swear by the Kubota branded SUDT. It's what I use also in my HST. I don't drink the Kool aid enough to swear by it....but I would NEVER put a straight AW hydraulic oil in a modern tractor transmission, and especially never in a HST
/ Why would an L3901 feel weaker than a 2003 L3301? #11
Neither would I. Kubota HST's are very sensitive to fluids. I think you are asking for trouble deviating from the OEM juice.
Neither of mine are hydrostats, both are geared with hydraulic shuttles bit I still use a Kubota compatible fluid in viscosity and quality. In my case I use Chevron All weather THC synthetic and it actually costs a tad more than SUDT. I like to clod start flowability of the Chevron plus it comes tinted (orange) so you can see it easily, unlike clear SUDT. Lots of cheap fluids out there, key word is cheap and in most cases, cheap is not compatible.
/ Why would an L3901 feel weaker than a 2003 L3301? #12
Could be wrong but I don't think AW 68 is a tractor/transmission fluid (it's not meant for systems with wets brakes)
That’s good to know, I think I’m going to get some SUDT
/ Why would an L3901 feel weaker than a 2003 L3301? #14
Like I said, Chevron AWS is, so is Rotella Hydraulic oil, so long as it meets or exceeds the Kubota spec and is the correct viscosity, all is good
/ Why would an L3901 feel weaker than a 2003 L3301? #15
Have the 3800, the only thing I hate is the transmission noise
/ Why would an L3901 feel weaker than a 2003 L3301? #16
Very true, the new tractors seem to need the Kubota branded products more so than before, I think its by design but no one can prove it.
/ Why would an L3901 feel weaker than a 2003 L3301? #18
Definitely use the Kubota branded fluids and add the John Deere hydraulic dye(so you can see it).
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
iDrive TDS-2010H...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
Sdlanch SDLGC80 (A60463)
Sdlanch SDLGC80...
167 (A52708)
167 (A52708)
