Why would an L3901 feel weaker than a 2003 L3301?
   / Why would an L3901 feel weaker than a 2003 L3301? #1
tractortroof
Jacksonville
kubota b2650
The new one, after 200+ hours is:
Way louder, likelike hearing protection is totally necessary with this thing, and
Weaker, which is really strange to me
I like it, but only ever owned Kubota, so really don’t know.
Can anyone move this to an appropriate place in the forum? Hey a legitimate user of moderation. 🤣
   / Why would an L3901 feel weaker than a 2003 L3301? #3
You might try going to "FORUMS" scroll down until you see "Kubota Owning and Operating" open that and post your question and then delete the thread in "Food Plots"
   / Why would an L3901 feel weaker than a 2003 L3301? #4
Are the two similarly equipped (transmission, etc.)? The older tractor will not have the same pollution controls as the newer one. Compare the torque between the two tractors.
   / Why would an L3901 feel weaker than a 2003 L3301? #5
I have a 2015 L3301HST and won't run it without hearing protection, mostly because of the transmission noise.
It doesn't whine anywhere near as much now though, since I started using the Super HST fluid.
   / Why would an L3901 feel weaker than a 2003 L3301? #6
Was the old one gear and new one HST?
Both are HST. The old one was really smooth and quiet, the new one screams. I changed the fluid with AW68, no change in scream
   / Why would an L3901 feel weaker than a 2003 L3301? #8
I had a L3301 and you can adjust the hydraulic pressure if needed. I think it can be adjusted to 2600 psi. Some owners have reported that their pressure was set at 2000-2200 psi at the factory. High pressure will give you more lifting capacity.
   / Why would an L3901 feel weaker than a 2003 L3301? #9
Interestingly, my Kubota tech at the dealership told me that no 2 tractors will ever dyno the same, some output more, some output less. Case in point is my M9 open station. Had it in for an overhead adjustment and injector pop test and my dealer put it on his pto dyno and it's making 93 pto which is substantially above what Kubota rates it it. Kubota rates it at 82 pto and no, pump has never been fiddled with.
   / Why would an L3901 feel weaker than a 2003 L3301? #10
Well it makes me question just what two tractors you are comparing.
The 3301 and 3901 are only 4hp apart. They have the same engine and transmission. And both came out in 2014. So what tractor you have from 2003 I have no idea
Also worth noting that if you replaced all the hydro fluid with a generic AW68....that is FAR FROM the correct fluid.
People swear by the Kubota branded SUDT. It's what I use also in my HST. I don't drink the Kool aid enough to swear by it....but I would NEVER put a straight AW hydraulic oil in a modern tractor transmission, and especially never in a HST
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A55315)
2025 Wacker Neuson...
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
