Lock down equipment
/ Lock down equipment #1
888NoTheft
Granite Bay, CA
none
To keep your machine from being used why you're not there, remove the starter relay or Ignition relay is original relay.
Im a security specialist for farm and construction equipment. 9 years in equipment theft prevention.
/ Lock down equipment #3
If I were really concerned about theft - just move the PTO lever to the ON position. Nobody would notice this and my M6040 will not start with the PTO in the on position.
/ Lock down equipment #4
I use a keyed master disconnect on the Negative terminal of the battery and of course they are all insured (I have more than one) and they sit in the fields if I don't finish with my fitting or harvesting that day. Never been an issue with me.
/ Lock down equipment #5
I was looking for the best way to protect my tractor. Makes me nervous being in an unlocked shed when I need to be away for a while. Ended up getting a steering ram lock. Very expensive not to mention the overseas shipping cost because they don't seem to be widely available in the U.S. But it ain't going anywhere with one of these on.
/ Lock down equipment #6
According to a dealer video I watched, criminals are bringing keys, relays, and fuses with them when they steal equipment.
While anything is better than nothing, there is simply no practical way to prevent a determined thief.
I thought about leaving the PTO engaged, but unfortunately my tractor very helpfully tells me it's engaged with a large banner across the LCD screen.
My personal opinion is that tractor security is best achieved in the following order :
1) Insurance
2) out of sight, out of mind
3) video surveillance (for after theft)
/ Lock down equipment #7
I don't worry abut theft, I worry about kids and criminal mischief more than anything else. They are insured against theft anyway.
/ Lock down equipment #8
Thats a bit much on the whole, when you use the tractor daily. But you are right, need to disable it discreetly as everyone has a John Deere tractor (and key) in this part of the woods...
/ Lock down equipment #9
Now that looks like a good idea, found a facebook site with lots of pictures and video.. Tractor & Earthmovers Anti Theft Locking System
/ Lock down equipment #10
I can tell you that the only way my tractor is going anywhere with the ram lock on is if they remove the entire steering ram, or destroy it. Like I sad, it was expensive and I had to arrange special shipping with them.
Yeah, I have insurance, but who the hell wants to buy a new tractor because the odds of getting back the one that was stolen are infinitesimal.
Thefts are on the rise and I looked into this after reading about people bringing keys, fuses and anything else that can be easily removed. Even a hidden kill switch with a key is pretty easily defeated.
/ Lock down equipment #11
Like a manual transmission ending many a joyride before it starts. :LOL:
/ Lock down equipment #12
Are the neighbours near enough to see a van body truck with tail lift ,or hiab truck come and pickup your tractor? With a tractor that small a garage dolly under the front wheels will bypass the locked steering.
/ Lock down equipment #13
If someone is coming to steal your tractor they won't be driving down the road making a getaway with it. They will winch it onto their flatbed and its gone within minutes.
If you are worried about theft top up your insurance. Keep your machine parked in a locked shed out of sight.
/ Lock down equipment #15
When I bought my CUT the neutral switch had been bypassed and the 2 wires simply linked,
So my deterrent is now to simply disconnect those 2 wires when parked.
Also I keep the disconnected ends out of view, mind U I could simply install a discrete switch.
In aviation I used to install a switch that disabled the magnetos and gave it a obscure label, or hid it from view.
Naturally the determined thief will find a way no matter what U do, often a 'tilt and load' is the choice.
/ Lock down equipment #16
When I used to leave my late 70's IH2500b gasoline powered tractor loader out on our property, I'd always take the battery, and pull the rotor from under the distributor. Then I'd park it off in the woods, well off the road.
I figured if someone would want to take the time to haul a battery back there, then diagnose why it wouldn't start, then go out and find the proper rotor for an International C-200 engine, they probably earned it. :ROFLMAO:
/ Lock down equipment #17
I built my tractor barn hidden in the woods, but my brother in law went and told everyone I had a new tractor and worse, were to find it. So looks like I will have to get some lock down mechanism..
/ Lock down equipment #18
And there is another thing. I have neighbors that like to "borrow" things. I don't keep things locked up and don't generally mind. They borrow stuff that they know they can borrow. I don't want them to get the idea that they can borrow my tractor.
/ Lock down equipment #19
Usually it seems that is the first thing they look for, so I would try a little misdirection like putting a good size chain to the poles or steering lock. The more time it takes seems to help discourage most thieves..
/ Lock down equipment #20
I have a pilot friend that had a mag disable switch on his 172 that was labeled "Ejection Seat".
2006 John Deere 250D 25 Ton Articulated Dump Truck (A61567)
2006 John Deere...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1CJ453408 (A61165)
2012 International...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62130)
KNOW BEFORE YOU...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
832747 (A61166)
832747 (A61166)
