Help Finding a Switch
/ Help Finding a Switch #1
TimberXX
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I have a tractor project, and I need a high quality toggle switch for my dash. But the switch needs to fit into a 17 mm hole in the dash, and fit a wiring harness that can accept spades that are 9 mm apart.
I've looked for an hour and can't find anything.
Thanks in Advance!
/ Help Finding a Switch #2
1. Use a washer.
2. Make your own harness.
Very Good Point to make a harness out of jumpers.Thanks! Im thinking a rubber washer from lowes, any other washer suggestions?
/ Help Finding a Switch #4
It's difficult to answer without knowing/seeing the application. Common toggle switches have a 1/2" mount (~13mm). Some are available with a rubber sleeve to make them weather "resistant". Then there's Single Pole Single Throw (SPST), Single Pole Double Throw (SPDT), Double Pole Single Throw (DPST) and Double Pole Double Throw (DPDT). Double throw switches are available in Center-Off or Maintained. Maintained means a circuit remains on with the switch in either throw.
I'm not sure I'd use a rubber washer to take up the 17mm hole. The switch would have a soft/loose feel as the rubber flexed. The switches are typically held in place by a small nut and/or a knurled nut in the case of the weather sleeve. I'd use a couple of thin steel washers, painted if necessary.
More details and/or pictures of your "Custom" modification would help a lot.
Just to stir your thoughts, switches can also be push button, push-pull or rotational. :giggle:
/ Help Finding a Switch #5
When I needed to but a smaller switch into a larger hole I used two fender washers, one on each side of the dash. I had enough threads on my switch to go that distance.
thanks for the replys. I have a few options being mail to my house, i will send pics. I did my Mcmaster and grainger.
This is the switch I'm using. The threads are at 14mm, and the hole is 17mm. I don't have alot to make up. But I'm realizing I can't fit this. The clearance behind the hole is too small. I was hoping to get a marine grade switch, but my clearance inbthe back would very tough. Would I need a marine grade switch Thoughts? I snowblow and will use the machine in light rains. Thoughts?
/ Help Finding a Switch #11
Does your tractor have any blank holes where you can install a factory switch? My Case DX35 had some blanks where I could put a factory switch for an LED light bar.
/ Help Finding a Switch #12
I would not use that switch in a application like yours. You need a switch with the seal on the toggle lever. Moisture will get in there a ruion the switch in short order.
As someone else said, is there another place you can put the switch ? Or drill a new hole in the dash for your switch.
You will want on like this:
Cole Hersee 55021 Standard Heavy Duty Metal Toggle Switch w/ Sealing O-Ring, SPDT, 25A​
From here: Cole Hersee 55021 Standard Heavy Duty Metal Toggle Switch | Waytek
But there are lots of sources for these switches. Maybe even your local ACME surplus store.
/ Help Finding a Switch #13
If you need anything special in switches, your first stop should be Digikey and Mouser Electronics. Their search filters allow you to narrow down what is important to you and they have thousands of options.
