Diagnostic code reader
/ Diagnostic code reader #82
George, Thanks for the info. The reason I'm looking for a code reader is my XG3037 is in engine shut down mode. I was moving snow and it dropped the rpm's to 1800, you could lower the rpm's but not go higher. I quit and headed to the house, I had been plowing for awhile so I shut the tractor off and went in the house. The next day I started the tractor, The dash lights showed the engine warning indicator with 2 second blinks and the regen indicator with 1 second blinks. I let the tractor run (still not over 1800 rpm's) waiting for the regen. It changed to engine warning indicator blinking every 2 seconds, the temp indicator on , the regen indicator on and the inhibit indicator off. It was still at 1800 rpm's and it wouldn't start the regen, finally I went in the house and let it run. When I came out it had stopped running and when I started it the engine warning indicator was blinking every 1 second and the regen indicator was blinking every 1 second which put it in "engine shut down mode". Started it again and it would only run for 30 or so seconds. The tractor has 220 hours and I have owned it for 7 of those. It has done one regen as it should while I was working. The closest dealer is over an hour away, I don't have a trailer and when talking to a tech on Saturday, he didn't think they would send a tech and if they did he thought the charge would be at least 5 or 6 hours and that didn't include fixing the problem. Getting expensive. Anyone out there have any ideas? Thanks much, John
/ Diagnostic code reader #83
/ Diagnostic code reader #84
Sorry to hear this John. I guess I've been lucky with mine. I bought mine new in 2014 and was worried about regen cycles and going into limp mode like yours has. Not sure where you are located. If you were close I could help you haul it to a dealer. From your description it seems like a dealer will have to connect it to his LS computer / analyzer.
I just passed 365 hours on mine and have seen many regens and running between 2200-2600 RPM's they have always completed their cycles. My main use is snow plowing and occasional summer use lifting heavy items and gravel work. I wish there was a way for us users to reset the CPU but so far no one has come up with a solution.
/ Diagnostic code reader #85
George, Thanks for your empathy. I wouldn't expect anyone to haul it for me. Although your kind words make it a little easier to swallow. Thought if I bought a code reader it might allow me to reset the code and do the regen. Oh well, I'll figure it out once I talk to a couple of dealers. Thanks again, John
/ Diagnostic code reader #86
I have the same engine shut down problem onn my XR 3037H. I bought the Nexas NL 102 diagnostic tool but the adaptor I bought is the wrong one from Grandview They sent a GES031A and the pin configuration is wrong. (Fits but the metal pins are wrong. Does anyone know what adaptor works with this tool to read the tractor codes? All I get is no connection detected.
/ Diagnostic code reader #88
I'm really late to this party, but I know I'm not the only one reading this thread for info, so I want to chime in. Like @George2615 , my 2016 LS XR4145 has an automotive-style 16-pin OBD2 connector hidden behind the center kick panel. I'm guessing it does use the J1939 "heavy duty" protocol, though, because my normal OBD2 scanner (Innova 3140) won't talk to it.
On a whim, I plugged in my little $15 Amazon Panlong bluetooth OBD2 dongle:
and connected to it with the Car Scanner Pro app on my Android phone. I'm not sure if the $6 "Pro" upgrade had any effect.
To my surprise, the app connected right up to my LS tractor. I was able to scan codes and view live data. I'm not having any problems with the tractor, so I couldn't do any exhaustive testing, but it seems to work at least for that simple stuff.
New/Unused Wolverine 72in Quick Attach Brush Cutter (A61166)
New/Unused...
8075 (A61165)
8075 (A61165)
UNUSED WOLVERINE SB72-72" ROCK BKT (A62131)
UNUSED WOLVERINE...
2007 Blue Bird All American/All Canadian Bus (A61568)
2007 Blue Bird All...
2019 Ford E-450 Shuttle Bus (A61568)
2019 Ford E-450...
WOODS TBW144 TURF BATWING ROTARY MOWER (A62130)
WOODS TBW144 TURF...
