Winter Field Mowing
/ Winter Field Mowing #1
Hay Dude
Epic Contributor
The Last Red State in the Northeast
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
Anyone mowing brush, large fields in winter with frozen ground?
We have about 150 acres to cut when the ground freezes. Too soft/delicate to cut unless frozen.
We have one property with a few large retention pond basins we can only cut when the ground freezes.
Some areas overrun with blackberry
These were once hay fields, now contract cut Conservancy Lands.
Will add more with todays mowing. Gonna be low 20’s so great time to mow normally damp ground.
/ Winter Field Mowing #2
I have done some wintertime waterway mowing, frozen ground can be your friend.
/ Winter Field Mowing #3
I don't go out when it's that cold. 😜 I've been trying to cut since before Christmas but too wet/soft. I just got a new clutch for the brush mower I haven't even installed yet. Had to take it apart to clean the paint out of it. It was double dipped and stuck together. It was supposed to be pre-adjusted for 45hp but I doubt 100hp could break it loose.
It says to adjust by spring height but the free height of the springs are all different. How would that work? o_O
/ Winter Field Mowing #4
Doing rear implement work with the loader on would drive me absolutely nuts. If I'm not using the loader it's parked.
/ Winter Field Mowing #5
I hope to have something done also since it is frozen. They are going to look at it today and advise. Hope it goes well for you.
I love having a loader on in 8’ tall grass.
Works like a cow catcher for a locomotive sometimes. ;)
Also allows me to break off those pesky, cab destroying limbs. (y)
/ Winter Field Mowing #8
LOL, I can take my loader off/on faster than I can remove/install the bucket or just as fast. Both have single point connectors and my loader is as easy as can be to connect and disconnect. With the loader on and a bush hog or finishing mower attached my tractor is so long and awkward that manuvering around is difficult. Bottom line is I just don't want it up there.
/ Winter Field Mowing #9
I've never removed the loader on my tractors unless a repair required it.
I do drop the bucket often to reduce the weight hanging off the front.
/ Winter Field Mowing #10
Ever since I ordered my cabbed tractor, I keep thinking of how productive I could be on those days that are too cold to do anything outside. I've tried bundling up, but it's just a matter of time until the cold works its way in, and then it becomes a test of how long I can last. Usually not very long!!!
/ Winter Field Mowing #11
I don't have to wait for freezing. But, I do typically plan for cutting right at the end of deer gun season...
/ Winter Field Mowing #12
I am planning on the same, but this foot of show isn't cooperating just yet. I do hope things can at least stay cold this winter. Last winter was tough and we had more 40 degree days and rain than anything.
Few more pics from today. Heres a shot from just arriving and starting a few passes to open up the bottom of this 35 acre parcel. Sorry for the crummy windshield.
Cutting mostly goldenrod and blackberry and some milkweed. This used to be a productive hayfield. It was purchased by a local conservancy. They allow me to hay about 50 acres and they keep this part in back out of hay for wildlife habitat. It also has some wet areas better suited for winter/frozen mowing.
Making some progress. I was able to mow about 4MPH.
Now its a “back & forth” mowing pattern with headlands established.
Finishing up its about 3PM. Took about 6-7 hours. You can see the hay lands in the background.
Heading home. Bringing a bale to the barn for the critters….
Even the windshield wiper & washer cant help my windshield much LOL
/ Winter Field Mowing #14
I've mow in weather condition as you and found out much easier when it comes to seeing rocks ditches better traction with out making ruts tractor runs cooler,and no sudden surprise from ground bees,only down side weeds high grass etc. doesn't get chop.
Hoping to do some “winter hay” in a few weeks. I have a 35 acre stand that I can possibly get baled if we have dry weather and frozen ground. This particular conservancy will allow, IF conditions are just right. Otherwise it has to be mowed.
It’ll be interesting making hay in February!
/ Winter Field Mowing #16
What sort of wildlife do they leave the natural habitat for? We have a conservation program here in SC but it calls for dividing the parcel in thirds and mowing a third a year. This allows wildlife to always have a three year old section. I don't know if it works but it sounds good. I remember growing up my granddad about this time of year would go just strike a match to the woods and fields as would all of the farmers in our area. We never had wildfires, ever. Wildlife was abundant. If you struck a match around here now you would burn half the county and get arrested. We have no small game anymore.
Mostly Deer, Coyote, Fox, Pheasant, Rabbits, turtles, hawks, eagles, owls… the typical wildlife you and I are both familiar with.
The place I showed in the pictures has 3 open parcels, about 100 acres total and quite a bit of woodlands.
I will hay 2 of them and mow the 3rd one every year. They haven’t “rotated” the parcels at all. They seem to be satisfied leaving the same 2 in hay and the 3rd one as a wildlife habitat.
The Land manager is very keen on ground nesting birds. He doesn’t want them disturbed and they are vulnerable to hay farming, so we come in and hay them late.
/ Winter Field Mowing #18
Yea, the CPS program here was introduced to save the quail population. Problem is, they waited about 20 years too late to implement it. You could walk your legs down to nubs around here and not see a single bird. Typical DNR problem solving. I'm not in the CPS program but I practice the land rotation. It seems to have helped with the rabbit population.
I will be starting a much larger winter mowing project in about a week. About 60 acres.
Will be back to post pictures.
/ Winter Field Mowing #20
Interesting to hear about the selective mowing for wildlife habitat improvement. I try to manage 30 hilly acres that used to be hay field this way, by establishing several main roads relatively level across the contour of the land to access the property. From there I can mow small parts here and there to promote pasture-like diversity patches among the trees and bushes I'm trying to let re-grow.
It's cool to see the deer, turkey, quail, coyote and fox starting to utilize the paths and different elements of cover throughout the property now.
One thing I've found about frozen ground is that if that top 1-2" layer starts to thaw but remains frozen underneath, it gets very slippery and makes hills pretty dangerous to navigate.
2012 Ford E-350 16ft. Box Truck (A64556)
2012 Ford E-350...
1500 gal Poly Tank (A66408)
1500 gal Poly Tank...
2007 HEIL TRAILER (A65643)
2007 HEIL TRAILER...
2016 P.J. Trailer Trailer, VIN # 4P5F8202XG1252798 (A65563)
2016 P.J. Trailer...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
2012 Ford F350 (A62679)
2012 Ford F350...
