Fence Line App for my phone?
   / Fence Line App for my phone? #31
I don't suppose you can see headlights looking from on end to the other? Project a Laser Level vertically from one point on a misty night? One thing that I've learned is that it's harder than you think to walk in a straight heading.
   / Fence Line App for my phone? #32
Not sure how much help this might be but I found it recently while trying to locate my property lines. In our case I've found the necessary pins but am struggling to connect them due to line of sight issues. We have trees and a hill between pins. As mentioned earlier our local GIS map online is very inaccurate. Very certain our neighbor's driveway isn't mostly on our land.
   / Fence Line App for my phone? #33
I use an app called HuntStand. On Android. It allows me to edit and place markers on property. It's primary use of course was for hunting. It has various map overlays, one of which is property lines. I used that, in conjunction with my plot survey, GPS and compass to find my property lines. It was pretty accurate since I found most iron rods. My only issue was water. As in moving creeks. I question now as to where the survey claims the creek is, and actually where it is. But a survey is recorded, Mother Nature has her ways.
I suggest using it as a trial and see if it will suffice to meet your needs.
I would be very hesitant to trust a property line overlay layer on a consumer grade gps system. I went to the county records office, and got their property layer with all the recorded property lines in the county.
I’m highly confident in where my corners are because the rebar with survey caps are still in place.
I can turn on the property layer in Google Earth and zoom in. The property lines are displayed about twenty feet west, and 15 north of where they actually are.
   / Fence Line App for my phone? #34
I used a combo of the mapping layers, my survey and a compass.
The mapping overlay gave me the quick "path" to walk down as it identified the actual tree line a pin was set into. And believe it or not the software image was an older photo of google maps at the time, taken in fall. That identified an area between hardwoods and cedars for another property line. Since I had the "photo" with the property overlays I had a better reckoning of where I was.
Heck, I got lost back there walking one day, totally disoriented, had to follow the creek home. LOL.
   / Fence Line App for my phone? #35
I use Gaia GPS…but these GPS apps areNT perfectly accurate.
Eddie - How accurate do you want?
GPS-enabled smartphones are typically accurate to within a 4.9 m (16 ft.)
The problem is not JUST with the smartphone accuracy (and BTW, handheld dedicated GPS units have the same problem. You don't get better until you upgrade to the really expensive equipment and have some sort of augmentation system and/or post processing in play.)And that 16 ft accuracy is for when you are standing in an open field with good satellite connections.
Further, the initial data showing up no most of these maps is not survey grade to begin with. I can find lot of places in my rural community where the parcel boundaries shown are off by 25 feet or more. 50 feet is not uncommon, and I have seen greater errors. Most of the data in these apps comes from old local town or county tax maps, which never were intended to be survey grade.
   / Fence Line App for my phone? #36
Like anything, its only as good as what goes into making it.
   / Fence Line App for my phone? #37
Did you ever come uo with a strategy for mapping out your fence line?
I have a landmark that I can measure from that should put me within a foot or two of where it is. The landmark is a marker for an underground natural gas pipeline. If the marker is accurate, then it should be good. If the marker is in the wrong place, then I could be off more then I want to be.
The marker is on my neighbors land. He said that it has never been moved. The pipe line people have been out several times in the last decade to make sure it's accurate.
I have to trust that it's accurate, or I can try to create a line between the two pins. Just standing at one of the pins and looking towards the other pin, it all seems to be about right.
I might hire a surveyor, but I haven't approached anybody yet. My place is a muddy mess right now. To install this section of fence, I have 7 big oak roots in the way, and probably 30 small to medium trees to remove and haul to the burn pile.
   / Fence Line App for my phone? #39
I keep thinking it would be nice to have a straight line between your two pins. How much does the elevation change between them? I keep thinking about using lights (or a beam from a laser level) to do it. If you had a drone and a few friends with flashlights you could get it :sneaky:
First picture shows the outline of my place and where I am going to put my fencing.
Fencing is red
Gates are green
The area that I'm trying to figure out is the North East line. I have the pin at the far right, near the road, and the one going North West along the line. Both pins have blue circles around them.
The area circled in yellow is a cliff that drops off quickly. The trees along it are all that's holding it in place. My neighbor and I have spent years trying to get more to grow there, and keeping what's there alive. I plan to run my fence around this area, into my side of the property line. On his side is a Natural Gas Pipeline, so fencing on that is a really bad idea.
The area with the orange circle drops down quite a ways, and then comes back up. That is where the remaining trees are that I have to take out. Then are blocking my view from the pin on the left and looking to the right to the purple circle.
I want to run my fence from the pin on the left ( blue circle) to the purple circle, where I will put a fence post and create a corner for my fence.
Figuring out where the fence post will go in the purple circle is my goal. If I go into my neighbors land, I'm going to be on the Gas Pipeline Right of Way. If I go into my land, I'm giving up my land. A foot doesn't matter too much, but several feet makes me uncomfortable.
Just outside the yellow circle, close to the purple circle, is a metal post in the ground that marks the Gas Pipeline. The survey says that my property line is 25 feet from the middle of the pipe, which also the edge of the 50 foot wide Pipe Line easement.
My original plan was to run a wire from pin to pin, but once I started dealing with all the trees along the top of the cliff, I abandoned that idea. I can easily take them all out, but I really want to keep them there.
If the marker is accurate, them I'm golden. If the marker is off, I'm stressed. I was hoping that a GPS program existed that I could draw a straight line between pins on my phone and then figure out where the line is by walking between the pins. That isn't realistic, so I have to hire somebody to figure it out, or trust the marker.
Detroit Hydraulic Power Unit (A53316)
Detroit Hydraulic...
2017 KOMATSU PC290LC-11 EXCAVATOR (A52706)
2017 KOMATSU...
2022 Polaris Ranger Utility Cart (A53421)
2022 Polaris...
2012 Cadillac SRX SUV (A55758)
2012 Cadillac SRX...
Giyi 49" Vibrating Bucket (A53316)
Giyi 49" Vibrating...
Giyi Pile Hammer (A53316)
Giyi Pile Hammer...
