Kubota vs Kioti?
/ Kubota vs Kioti? #61
This is yet an other myth that doesn’t seem to hold true around here.
It seems that when you use a percentage scale based on the actual selling price you don’t really make out any better.
Seems foolish to me on two fronts. Pay more for less up front, then have to wait for the right cool aid drinker to pay more for less when you sell and there are other choices that reflect the same savings the original purchaser of alternate brand had.
It does around here. There is 1 dealer that sells LS/TYM/Kioti and Has been in business for less than 3 years. There are 3 JD and 3 Kubota dealers conveniently located around the state. Kubota lots are almost empty. Same with JD and Massey. The 1 dealer has a bunch of LS/TYM/Kioti sitting around…and have had them for some number of months (same machines in the same spots). I drive by these dealers weekly. How likely is a dealer that sells 3 different brands to have the parts you need or expertise to service/repair all 3 separate brands? For me time is money…I’m not retired yet. I dont have time to fiddle with a machine for 2 weeks or wait a month for parts. I need a robust support network. To each his own of course.
Same in Central TX where our farm is…JD rules but Kubota has a good presence. Most of the other brand dealers are smaller operations, some have closed in the past 2 years.
I am sure it is just because the right buyers havent come along yet….
/ Kubota vs Kioti? #62
With me, everything hinges on the dealer and not the brand. If I have an issue, any issue, time is money for me and I need a quick resolution, one reason I have multiple tractors and multiple implements (especially the PTO driven ones). I can ill afford a breakdown. Now if it was a small
hobby' type unit that probably would not apply but I don't have hobby tractors.
/ Kubota vs Kioti? #63
I have owned my Kioti for over 20 years.
I buy any part I have ever needed online.
I have never waited more than a few days for a part to be mailed to my door
/ Kubota vs Kioti? #65
Today, you might find that scenario to be different.
How so? I can get parts as fast as you can. I can get parts from a LS dealer or Bobcat dealer if Kioti is out of stock.
/ Kubota vs Kioti? #66
Actually Kioti parts are VERY available more so than my kubota Parts.
/ Kubota vs Kioti? #71
So then what is the kubota reverse engineered after? You know they were not the first!
That would be Yanmar, and the time is roughly the 1980s. By 1990 the reverse engineering was completed, and a decade after that Kubota was well in the lead in popular compact tractors.
Kubota beng so much better at merchandising didn't hurt either.
No reason why Kioti can't do the same.
All three companies do a lot of their own manufacturing in house. That's a plus for them all.
/ Kubota vs Kioti? #73
Well, it would be bad if you needed parts for your Kubotas, considering that you sell them with less than 250 hours... :)
Guess you beat me to it.
I've put more hours on an engine oil change than he does on most of his tractors before trading/selling it off.
/ Kubota vs Kioti?
Well I'm sitting on the quote/application now until Monday. Looks like it will be the Kioti 2610 unless something happens between now and then to change my mind. In large part, the decision was made easier because of the lack of Kubotas anywhere near me.
It looks like it will be a good fit as far as size, accessories, dealer, etc...
One question: the dealer suggested a 'bolt-on 60 inch cutting edge' for the front loader. What is this and do I need it for $335...?
/ Kubota vs Kioti? #78
I agree, however you might want to consider a bolt on tooth bar (piranha, Titan, Everything Attachments, Amazon, etc.) It will increase your ability to dig int sod, roots, etc.
/ Kubota vs Kioti? #79
I did the bolt on edge w my deere along (I think??) the “heavier” bucket at the time??? (I believe there were 2 options)
the edge is great and it is reversible (never done in 10yrs)
I wouldn’t get one without it. I don’t worry about curling an edge etc
tooth bar would also be a consideration as noted above
I would do one or other imho
/ Kubota vs Kioti? #80
You really can’t go wrong with the 2610. Great tractor!
Mike
2001 Ford F-650 18ft Rollback Truck (A61573)
2001 Ford F-650...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
29 x 9.0 x 15 Tires with 5 Lug Wheels (A61573)
29 x 9.0 x 15...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
Metal Bigfoot Lawn Art (A61574)
Metal Bigfoot Lawn...
