Seats for your Yanmar
/ Seats for your Yanmar #1
richriddle
Gold Member
Taylorsport, Kentucky
Kubota L4330 with LA853 Loader, Yanmar YM276D with YFL1000 Loader, Yanmar YM276D, Yanmar YM147D, Case 1845C
Do any of you like a particular brand or type of seat for your Yanmar? I spend a fair amount of time in them mowing and such. As I creep up in age, the seat becomes more important. I am specifically looking for the YM276D, but it seems like most seats are universal in nature.
/ Seats for your Yanmar #2
I know you're looking for ths YM276 seats but I did a whole seat / suspension set up on my 147. Kinda applies to any tractor I suppose. Took some redoing but makes a big difference. Got some pictures around if you think they'd be helpful.
I would appreciate that a lot. The YM147 seat is setting on a set of homemade Lincoln logs, no kidding. Apparently, it had a very portly owner two owners prior who made the modifications. The picture isn't good, but you might be able to see his modifications. Needless to say, the original brackets are not there any longer.
/ Seats for your Yanmar #4
I swapped out my Ym2310 seat which is basically the same as your 276. Picked up a generic seat and just re-drilled the existing mount to accept the new one. I'll look up the seat when I get back to the house later.
Here are a few better pictures of the Lincoln log methodology applied to the YM147D seat.
Your YM147D looks quite different than the Lincoln log YM147D.
/ Seats for your Yanmar #7
/ Seats for your Yanmar #8
I used freeze plugs similarly to Menagerie-Manor's. I like the looks of his seat!! Made a big difference in the way the seat cushioned the ride. Esp. on the Org. huge lug Bridgestone's. I said for yrs. it rides like the Flintstone's mobile going slow. I have the Standard seat from Fredricks or Hoye from the looks. It was new so no doubt Fredrick's being from Spalding.
/ Seats for your Yanmar #9
Back in 2016 seat prices were reasonable for a high back at $49. Today it's over $100.
My new seat went badly outside of warranty. Reason, UV rays. I began looking at seats and noticed not many at all had UV protection except the Marine seats.
Wise makes several that would work and are extremely comfortable. I chose red because of Yanmar. They have black, gray, green for JD, and other colors too.
And just like the Yanmar option for many of the YM2xxx models, you can get the seat to swivel to help get in and out of the machine or to help turn somewhat backwards to look behind. The YM2310 was the first listed model with the option.
Thank you for the seat information. I like that look. Do you have a link to where they sell them? It must be late, because I can't read some of those words.
Because of the comment below, I now blame you for both of the other YM276D Yanmars, a Case 1845C, and a Toro Workmaster 3200 model. If I get any other wheeled farm implements you will be blamed for those as well.
........and from 3/23/2017 when you asked....."Maybe it's time to upgrade to a larger Yanmar," when discussing limitations of the YM147D.
/ Seats for your Yanmar #11
Thank you for the seat link. I like that look.
I will gladly take blame for Yanmars. :) There needs to be more of them.
Once you have two or more, you need the indoor model as well.
Yanmar_YM3110_Model_Farm_Vehicles_and_Equipment_f3fec192-5f7b-444c-951d-383d26282109.JPG
And if you have the Yanmar Fever badly, then get the whole family for the past 100 years!
/ Seats for your Yanmar #12
Bailey's Hydraulic Supply carries a useful selection of machinery seats. Worth a look.
/ Seats for your Yanmar #13
Had a Ranger bass boat. It was older so I went through the boat seat replacement. William Pain was the Org. owner. Augusta PGA... Motor was pretty much Destroyed. It cleaned up nice. Seats was To Big for my YM2000. Kept two that was still good Org. Ranger $ in the shed. No Go!!! to wide. Major head and neck injury's that disabled me and it's still on there same setup.............. the Log seat wouldn't fit from the looks.........
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
HAMM 2420D SMOOTH DRUM COMPACTOR (A62129)
HAMM 2420D SMOOTH...
RHINO G300' AUGER (A62130)
RHINO G300' AUGER...
Toyota 2FGC20 4,000lb. Propane Forklift. (A61567)
Toyota 2FGC20...
Solesbee Hydraulic Thumb (A61166)
Solesbee Hydraulic...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
